    [Plugin]ArcCurve-set_segments.rb & changearcsegments 130830
    32 Posts 11 Posters 68.7k Views 11 Watching
      Some of these methods can be simplified with the aid of Curve.is_polygon? added in Google SketchUp 7.1 - Maintenance 1.
      Here's a set I made for my TT_Lib:
      	def self.is_curve?(entity)
      		return false unless entity.is_a?(Sketchup;;Edge) && entity.curve
      		return false if entity.curve.respond_to?(;is_polygon? ) && entity.curve.is_polygon?
      		return true
      	def self.is_arc?(entity)
      		return self.is_curve?(entity) && entity.curve.is_a?(Sketchup;;ArcCurve)
      	def self.is_circle?(ent)
      		# (i) A bug in SU makes extruded circles into Arcs with .end_angle of 720 degrees when reopening the file.
      		# Instead of checking for 360 degrees exactly, we check for anything larger as well. A 2D arc
      		# can't have more than 360 degrees.
      		# This doesn't work. Maybe due to rounding errors?
      		# return (arc_curve.end_angle - arc_curve.start_angle >= 360.degrees) ? true ; false
      		return false unless self.is_arc?(ent)
      		return ((ent.curve.end_angle - ent.curve.start_angle).radians >= 360) ? true ; false
      	def self.is_polygon?(ent)
      		return ent.is_a?(Sketchup;;Edge) && ent.curve && ent.curve.respond_to?(;is_polygon? ) && ent.curve.is_polygon?
      	def self.is_ngon?(ent)
      		return false unless self.is_polygon?(ent) && ent.curve.is_a?(Sketchup;;ArcCurve)
      SU versions prior to this .is_polygon? will not be able to tell a Circle or Polygon apart, but no error is thrown.
        Here's an updated version that avoids other method clashes... http://forums.sketchucation.com/viewtopic.php?p=158903#p158903
        IF you have the older script ArcCurveTests.rb installed please remove it as it might clash with some other methods...
        • E Offline
          eskis
          great! great! great! that is what i was looking for!!!!!!
          thank you...
            ahnvtk
            I've tried making a script that automatically creates an 8-sided circle in a group at sketchup start, to see if all circles created by a user would then be 8-sided as well. They aren't - scripting an 8-sided circle still leaves the default sides at 24. 😞
            I tried changing the sides of a circle with this script as well - Sketchup still leaves the default at 24.
            How can I change the default sides of a circle? ❓
              You can't.
                ahnvtk
                At least this script here just saved me time reducing polys from extruded circles.. thanks!
                  boilingsnow
                  TIG it's nice of you to share this with us. I think this ruby is very useful but it's convenient to use because everytime I have to type "changearcsegments NNN" in the ruby console...Why not make it possible to be added in the plugin menu and works with a popup window to type in the segment number.
                    Edit the script with a plain-text editor [Notepad/Notepad++.exe] and add this code at the end
                    unless file_loaded?(File.basename(__FILE__))
                      UI.menu("Plugins").add_item("Change Arc Segments"){
                        segments=inputbox(["Segments; "],[12],"Change Arc Segments")
                        changearcsegments(segments[0])if segments
                    file_loaded(File.basename(__FILE__))
                      boilingsnow
                      > end
                      Thank you!
                        LorenzoS
                        Hi!
                        Is Anyone so kind to tell me how to use this plug-in.
                        I get an error that says
                        Error Loading File ArcCurve-set_segments=.rb
                        no such file to load -- ArcCurveTests.rb
                        any help?
                        thx!
                        p.s.
                        I downloaded the script from the first post.
                          It doesn't even use ArcCurveTests.rb or mention it in its code - in fact in earlier posts [in this thread] you are recommended to remove that very file from your Plugins folder, because changes to the API have meant that it might clash and updates of this tool no longer need it anyway.
                          So it is not 'required' by the recent versions of this script...
                          Your error message leads me to think that you have an old version of the tool loading...
                          Are you sure you have got the latest one in the Plugins folder? Windows Vista/Win7 can 'play tricks' if you don't have full access rights to the Plugins folder - it looks like you have added/updated a file/subfolder... but there's a 'Compatibility Files' button added to the folder's window-bar and they have actually gone into a side folder, IF you haven't got full security access rights to a folder [right-click context-menu Properties > Security]
                          Here's the latest version http://forums.sketchucation.com/viewtopic.php?p=158903#p158903
                          It has the Plugins menu item added to the code as discussed a few posts back...
                          Download the latest file from this link.
                          It should make a Plugins menu item which opens a dialog into which you type the number of arc segments required to process all selected arcs/circles...
                            theotses
                            Hi!
                            I downloaded the plugin and istalled it. I have a big drawing with many arcs and is nearly impossible to select them all. So i select the whole drawing as i imported it and then i use the plugin. But the plugin works only with some of the arcs and the others remain with the default number of segments.
                            How can i use the plugin on all the arcs?
                            Thank you in advance.
                              SketchUp's Arcs/Circles can have their 'segmentation' set as they are made OR later on by using 'Entity Info', OR bu using this tool.
                              BUT Arcs that have been scaled, exploded into edges OR are now incorporated into 3d geometry [extrusions etc] are never changeable.
                              So if you can't change your Arc's segmentation using 'Entity Info', then you can't change it with anything else either: its properties have been fixed by your earlier actions.
                                theotses
                                I can change the segmentation from entity info but the arcs are too many. So I tried to select the whole drawing and change the segmentation with the tool but only few of the arcs got the segments I wanted.
                                  Wireframe mode will avoid picking faces, then select-by-fence, missing out anything that is obviously not an edge/curve...
                                  Any errors in the Ruby Console ?
                                    theotses
                                    Thank you for your instant replies.
                                    I don't have any faces in my model. I don't really understand what you mean with the fence selection. (This is my first model in SketchUp 😳 )
                                    I don't get any errors at all. I just select all the lines and arcs (because i said in the first post that it is impossible to select every arc with clicks), then i use the plugin and i set the desired number of segments. Unfortunately not all the arcs get the number of segments I set in the plugin dialog box.
                                      Can you attach your SKP to a post so we can see what's up...
                                        theotses
                                        Thank you for your will to help me. As I understood the plugin can handle max 100 arcs at a time. I partially selected the whole model and everything was ok!
                                          Slight update - rev 'a' - http://sketchucation.com/forums/viewtopic.php?p=158903#p158903
                                          ArcCurveTes.rb added for compatibility with v7 etc...
                                            mbastian
                                            First of all: I am NOT a programmer, so there is ZERO error handling on this quick-and dirty script. I had tried TIG's solution, but did not work on my DWG because some of the arcs would "clip" others as they were rebuilt by the script.
                                            So I wrote this small routine to:
                                            • loop through imported AutoCAD entities.
                                            • select curves and group them (individually)
                                            • create a more refined clone of the curve (the number of segments is controlled by two parameters. See script)
                                            • Delete the original curve.
                                            Anyone is welcome to turn this snippet into something better and more reusable.
                                            Best,
                                            Marcos.
                                            theModel = Sketchup.active_model
                                            #selEntities = theModel.selection
                                            theModel.selection.clear
                                            allEntities = theModel.entities
                                            Collect user values:
                                            prompts = ["Minimum number of segments:", "Minimum Segment Length:"]
                                            defaults = [36, 10]
                                            input = UI.inputbox(prompts, defaults, "Enter Desired Settings")
                                            #set minimum length for each arc segment (in model units)
                                            userSegs = input[0]
                                            minLen = input[1]
                                            #UI.messagebox(userSegs.to_s)
                                            #UI.messagebox(minLen.to_s)
                                            allEntities.each do |i|
                                            if (i.typename == "Edge")
                                            aCurve = i.curve
                                            if (aCurve)
                                            Sel = theModel.selection unless defined?(Sel)
                                            Sel.add (aCurve.edges)
                                            newGroup = allEntities.add_group (theModel.selection)
                                            Sel.clear
                                            else
                                            #not a Curve
                                            Loop through all entities
                                            #open Groups, search for Curves
                                            if (i.typename == "Group")
                                            #Loop through array of Entities inside each Group
                                            subset = i.entities
                                            subset.each do |s|
                                            curve = s.curve
                                            if it is a curve, collect a few properties
                                            if (curve)
                                            get coord. transformation, since entities are in a group
                                            #use "transform" below to translate to global coordinates
                                            tr=i.transformation
                                            cCenter = curve.center.transform! (tr)
                                            cSangle = curve.start_angle
                                            cEangle = curve.end_angle
                                            cRadius = curve.radius
                                            cNormal = curve.normal.transform! (tr)
                                            cXaxis = curve.xaxis.transform! (tr)
                                            cYaxis = curve.yaxis.transform! (tr)
                                            cLength = curve.length
                                            #UI.messagebox(" Curve Length is " + cLength.to_s)
                                            #divides arcs in minLen(model unit) increments
                                            divSegs = (cLength / minLen).to_i
                                            #UI.messagebox("Divided Result is " + divSegs.to_s)
                                            #for very small arcs, sets a minimum number of segments
                                            if (divSegs <= userSegs)
                                            numSegs = userSegs
                                            UI.messagebox("Using: " + numSegs.to_s)
                                            else
                                            #subdivides larger arcs using target length
                                            numSegs = divSegs.to_i
                                            UI.messagebox("using Divided total" + numSegs.to_s)
                                            myarc = allEntities.add_arc cCenter,cXaxis,cNormal,cRadius,cSangle,cEangle,numSegs
                                            #Erases original
                                            i.erase!
                                            end # if curve
                                            end # entities inside group loop
                                            end # if it is a group
                                            end #loop through all entities
                                            • 2 / 2
