    [Plugin] TextureRandomizer
    52 Posts 16 Posters 55.6k Views 16 Watching
    • massimoM
      massimo Moderator
      Now seems to work fine. Thank you. ๐Ÿ˜„
      It would be nice if it worked also with groups...
        A textured-material applied to a group is non-editable.
        Only textured-materials applied directly onto to faces are editable.
        If you mean it working on textured-faces that are inside groups, then if you edit the group/component you can randomize the textures on selected faces within the edit session...
        It would be possible to add extra code to process selected textured-faces AND textured-faces inside selected groups/components...
        Does this method appeal to anyone else ?
        • massimoM
          massimo Moderator
          That's what I meant.
            Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=392834#p392834
            If there are any groups/component-instances in the selection, and they
            contain textured-faces a dialog asks if you want to include those faces
            too, answer 'No' to process selected faces only or 'Yes' to process all
            textured-faces, including those inside other selected objects...
            It does not 'mine' down beyond the selected context - so nested groups are
            never affected.
              Cool effect! โ˜€
              Before use your plug above
              [REQ]
              Does it possible to apply to a selection of faces some textures randomly from the Texture library ?
              • massimoM
                massimo Moderator
                Great. ๐Ÿ‘
                Now the problem is that all the selected groups are "randomized" in the same way (I've tried with an array of the same textured group). So at the end you have... a different uniformity. ๐Ÿ˜„
                • EarthMoverE
                  EarthMover
                  Nice plugin TIG. Thanks! Possible to add an option for color variation by HSB? Perhaps random slide by percent for Hue,Saturation or black value. Would be great for leaves, brick, stones, etc.
                  Content Creator at Skapeup
                    @massimo said:
                    Great. ๐Ÿ‘
                    This is NOT a problem with the tool, rather one with the model itself.
                    So this is not entirely true. ๐Ÿ˜ฎ
                    If groups are multiple instances of the same group-definition they are just like component-instances of the same component-definition, so all changes to one will look just the same across all instances.
                    BUT if groups are unique because they have been edited [equivalent to what you can do with component-instances and 'make-unique' in the context-menu]... then the texture changes WILL be unique to each unique instance of the group.
                    So in essence what you are saying is, "Multiple copies of a group which refer to the same group-definition [which you can see in the 'Entity Info' count!] will display the same random-texture changes, because they are all 'clones'..." - which is exactly as you should expect. ๐Ÿ˜’
                    So you need to edit the groups [without making any significant changes] which will make them unique, and then redo the texture-randomization and then each one will get a unique texture randomization...
                    To make your groups unique you can try this simple one-liner in the Ruby Console, use it on a preselected set of entities which include the groups you want to 'make unique'...
                    Sketchup.active_model.selection.each{|e|e.make_unique if e.class==Sketchup;;Group and e.entities.parent.instances[1]}
                    You might get messages about '...deprecated methods...', but just ignore these as there's a long standing balls-up in the API ! ๐Ÿค“
                      This would require a new textured-material [which is of course quite possible] - but this specific tool only randomizes the position/scale/mirroring/rotate of the one textured-material without changing it in any other way except for its UV-mapping...
                      • massimoM
                        massimo Moderator
                        Ok, ok...As I suspected. Now your one-liner works like a charm. Any possibility to "incorporate" it in the plugin perhaps as an option? ๐Ÿ˜„
                          Here's v1.3 http://forums.sketchucation.com/viewtopic.php?p=392834#p392834
                          If there are non-unique groups in the accepted selection then you are asked
                          if you want to make them unique, so that their randomized-textures are also
                          unique... [groups should be 'unique', BUT Sketchup can have more than one
                          instance of a group !!]
                          If there are multiple instances of the same component in the accepted
                          selection then you are asked if you want to make them unique, so that their
                          randomized-textures are also unique... [use this with care as the advantage
                          of components - edit one, edit all - is lost by making instances unique!]
                            Give a random colors to a volume is easy with the Random Painter by Chris Fullmer
                            but random textures from the Library of textures?
                            • EarthMoverE
                              EarthMover
                              Thanks for the reply. I guess it would be best served as a separate plugin called "Texture Variator" or something similar where one could enter the number of variations desired and the range of HSB, thus producing copies and replacing the existing. Texture Randomizer as you have created it works great in my tests and again I thank you for your efforts and generosity! It is a handy addition to your texture toolset which I use everyday. ๐Ÿ‘
                              • massimoM
                                massimo Moderator
                                Thanks again TIG. Your patience is equal to your abilities... ๐Ÿ‘
                                  TIP: Using the same value for the 'max' AND 'min' settings will make that change with no randomization, e.g. set UXmax=1 and UXmin=1 will jump all of the selected faces' textures across by +1 unit.
                                  • guanjinG
                                    guanjin
                                    The plane can not be adjusted, the tool does not work
                                      Explain how it is "not working" !
                                      Your bug reports can be annoyingly brief and unclear. ๐Ÿ˜’
                                      Is your textured-material applied directly to a face and NOT a group/component-instance - remember that you CANNOT adjust textures unless they are applied directly to a face - that applies to either with this tool or using the native Texture tool available through the context-menu...
                                      Is the texture-material applied to a 'front' face - you cannot adjust the texture that are incorrectly applied to a 'back' face.
                                      If your rectangle was drawn on the ground and you haven't reversed the face then you have textured the back NOT the front !
                                      To check this... ensure your Style has a distinct color difference between front and back default materials - typically an off-white and a blue-gray respectively - now toggle the view between Monochrome mode and Textured mode. Faces that are textured incorrectly on their backs will show 'blue'; they need to be Reversed [context-menu] and the texture applied to their fronts - it will now be editable using this tool ๐Ÿค“ Capture.PNG
                                      If this is not the case [my best guess!]...
                                      What values do you have in the tool's dialog?
                                      If the max/min for a pair of setting are the same number [that is NOT 0] then the texture[s] WILL change by the fixed amount [without any randomization].
                                      If you are working in mm and enter 1 then the 1mm jump could be hard for you to see unless you are close to it as it changes.
                                      Also, if your pattern repeats at say 150mm and you also enter 150... then although the texture will jump over by that value it will once again starting in the same place... so you will see no change.
                                      I know this tool works perfectly well - I have tested it extensively - so you must be doing something wrong. ๐Ÿ˜•
                                      • guanjinG
                                        guanjin
                                        Thanks TIG ๐Ÿ‘
                                          Can you provide a simpler example.
                                          [Reread my previous post about 'reversed' faces]
                                          Unless you have a face selected that has a front-material with a texture the tool won't run.
                                          I can't see exactly what you are doing to get nothing happening...
                                          Regarding the rotation - remember that there is no way of knowing a textures current rotation - so any rotation you apply is relative to its current transformation, it is not 'absolute' - so rotating a texture by 45 then by 45 later is equivalent to one rotation of 90; you do not set the texture's rotation to 45, rather you change it by 45 degrees. [also remember that positive angles rotate counter-clockwise, negative angles clockwise]
                                          • guanjinG
                                            guanjin
                                            2D plane can not use this tool.
                                            • 1 / 3
