    [Plugin] TextureRandomizer
    52 Posts 16 Posters 55.6k Views 16 Watching
      AcesHigh
      Awesome TIG! I am sure this can be used by a lot of people to leave their projects more realistic!
        Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=392834#p392834
        I fixed a stupid typo [and some incorrect 'default values'] that meant it didn't work if you use a ',' as a decimal point instead of a '.' is fixed...
        [I hope this address's massimo's report]
          Does this a variation of only one texture or several textures ?
            It affects ALL textured materials on ALL selected faces [fronts].
            So if you want to tweak one particular face+material combo then 'select by same material' before running the tool...
            Otherwise it randomizes everything !
            Any selected non-faces, or faces with non-textured materials, are ignored anyway...
            • massimoM
              massimo Moderator
              Now seems to work fine. Thank you. ๐Ÿ˜„
              It would be nice if it worked also with groups...
                A textured-material applied to a group is non-editable.
                Only textured-materials applied directly onto to faces are editable.
                If you mean it working on textured-faces that are inside groups, then if you edit the group/component you can randomize the textures on selected faces within the edit session...
                It would be possible to add extra code to process selected textured-faces AND textured-faces inside selected groups/components...
                Does this method appeal to anyone else ?
                • massimoM
                  massimo Moderator
                  That's what I meant.
                    Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=392834#p392834
                    If there are any groups/component-instances in the selection, and they
                    contain textured-faces a dialog asks if you want to include those faces
                    too, answer 'No' to process selected faces only or 'Yes' to process all
                    textured-faces, including those inside other selected objects...
                    It does not 'mine' down beyond the selected context - so nested groups are
                    never affected.
                      Cool effect! โ˜€
                      Before use your plug above
                      [REQ]
                      Does it possible to apply to a selection of faces some textures randomly from the Texture library ?
                      • massimoM
                        massimo Moderator
                        Great. ๐Ÿ‘
                        Now the problem is that all the selected groups are "randomized" in the same way (I've tried with an array of the same textured group). So at the end you have... a different uniformity. ๐Ÿ˜„
                        • EarthMoverE
                          EarthMover
                          Nice plugin TIG. Thanks! Possible to add an option for color variation by HSB? Perhaps random slide by percent for Hue,Saturation or black value. Would be great for leaves, brick, stones, etc.
                          Content Creator at Skapeup
                            @massimo said:
                            Great. ๐Ÿ‘
                            This is NOT a problem with the tool, rather one with the model itself.
                            So this is not entirely true. ๐Ÿ˜ฎ
                            If groups are multiple instances of the same group-definition they are just like component-instances of the same component-definition, so all changes to one will look just the same across all instances.
                            BUT if groups are unique because they have been edited [equivalent to what you can do with component-instances and 'make-unique' in the context-menu]... then the texture changes WILL be unique to each unique instance of the group.
                            So in essence what you are saying is, "Multiple copies of a group which refer to the same group-definition [which you can see in the 'Entity Info' count!] will display the same random-texture changes, because they are all 'clones'..." - which is exactly as you should expect. ๐Ÿ˜’
                            So you need to edit the groups [without making any significant changes] which will make them unique, and then redo the texture-randomization and then each one will get a unique texture randomization...
                            To make your groups unique you can try this simple one-liner in the Ruby Console, use it on a preselected set of entities which include the groups you want to 'make unique'...
                            Sketchup.active_model.selection.each{|e|e.make_unique if e.class==Sketchup;;Group and e.entities.parent.instances[1]}
                            You might get messages about '...deprecated methods...', but just ignore these as there's a long standing balls-up in the API ! ๐Ÿค“
                              This would require a new textured-material [which is of course quite possible] - but this specific tool only randomizes the position/scale/mirroring/rotate of the one textured-material without changing it in any other way except for its UV-mapping...
                              • massimoM
                                massimo Moderator
                                Ok, ok...As I suspected. Now your one-liner works like a charm. Any possibility to "incorporate" it in the plugin perhaps as an option? ๐Ÿ˜„
                                  Here's v1.3 http://forums.sketchucation.com/viewtopic.php?p=392834#p392834
                                  If there are non-unique groups in the accepted selection then you are asked
                                  if you want to make them unique, so that their randomized-textures are also
                                  unique... [groups should be 'unique', BUT Sketchup can have more than one
                                  instance of a group !!]
                                  If there are multiple instances of the same component in the accepted
                                  selection then you are asked if you want to make them unique, so that their
                                  randomized-textures are also unique... [use this with care as the advantage
                                  of components - edit one, edit all - is lost by making instances unique!]
                                    Give a random colors to a volume is easy with the Random Painter by Chris Fullmer
                                    but random textures from the Library of textures?
                                    • EarthMoverE
                                      EarthMover
                                      Thanks for the reply. I guess it would be best served as a separate plugin called "Texture Variator" or something similar where one could enter the number of variations desired and the range of HSB, thus producing copies and replacing the existing. Texture Randomizer as you have created it works great in my tests and again I thank you for your efforts and generosity! It is a handy addition to your texture toolset which I use everyday. ๐Ÿ‘
                                      • massimoM
                                        massimo Moderator
                                        Thanks again TIG. Your patience is equal to your abilities... ๐Ÿ‘
                                          TIP: Using the same value for the 'max' AND 'min' settings will make that change with no randomization, e.g. set UXmax=1 and UXmin=1 will jump all of the selected faces' textures across by +1 unit.
                                          • guanjinG
                                            guanjin
                                            The plane can not be adjusted, the tool does not work
                                            • 1 / 3
