    Shadows not appearing
    7 Posts 5 Posters 4.3k Views 5 Watching
    • eidam655E
      eidam655
      hello all,
      does anyone have any idea why the only shadows i can see are the ones on the ground and none on the faces? also, why could the "On Faces" option in Shadow Settings be greyed out?
      thanks for any answers.
      I'm using SketchUp 2017, V-Ray 3.4
      • soloS
        Click the icon on top left (box).
          sonder
          Yes, you have shadows turned off.
          • eidam655E
            eidam655
            i am sorry for the bad screenshot, i must have taken it while trying to figure the shadows out.
            i would be very glad if the icon would solve the problem, but sadly, it doesn't. so thanks for the answers thus far and here's a new screenshot.
              Where is your SKP you geo-referenced ?
              If you toggle the top-left button on the dialog what happens to the settings?
              They should become available/unavailable to edit...
              • GaieusG
                In the last screenshot > bottom, where shadows are turned on, shadows on faces (bottom left) is not checked. However it is weird as when shadows are on, that option should be active (and turned on) but it seems to be greyed out (unavailable) for you. πŸ˜•
                • eidam655E
                  eidam655
                  the model is at 49.190966N,16.611552E so the UTC+1 time zone should be fine - the shadows appear correctly at rendertime, i just miss them in the preview. no other view mode (shaded/textured/monochrome...) brings them back.
                  as for the toggle - as is seen on the screenshot, only the 'From Edges' option switches its state.
                  EDIT: ha, i found the solution; see attached screenshot. thanks everyone for answers πŸ˜„
