    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.0m Views 183 Watching
      tfdesign
      This is a brilliant plugin. Thanks Fredo6! When I've got some money again, I'll send you a donation πŸ˜„
      (In fact I'll send donations to all whose plugins I use, once the work gets flowing again! 😳 πŸ˜„ ).
        Scott M
        @gaieus said:
        efw? I have never seen that. Maybe try to rename it to rb (or rbs)?
        Also, Bezier Spline may need to be enabled under Window > Preferences > Extensions (and then you find a whole toolbar for it under View > Toolbars)
        If you go to the download link clik on save it will show the file type as a EFW file. When I save it too my desk top it is a EFW file. I then clck on send too zip folder.Then extract all into plugin folder. It showes up in this folder as a EFW file type.Am I doing something wrong.
        https://www.youtube.com/user/ecabinetstips
          When you click the "BezierSpline 1.4 - 02 Sep 10.zip" link you get an .eft file?
          That is odd. Are you using some download manager that might be interfering?
          When I click I get the expected "BezierSpline 1.4 - 02 Sep 10.zip" file...
            Scott M
            When I clik on the download link this is what I see.
            File Download
            Do you want to open or save
            Name:BezierSpline 1[1].4-02 Sep 10.1.321C02.efw
            type:unknown File Type,108MB
              108MB! 😲 That is just wrong. You either got a download manager interfering, or a virus/malware. Something is not right there.
              Can you try with a different browser? Or from a different machine?
                Here's what I found in regard to EFW files:
                http://knightknetwork.com/2008/01/31/fix-your-efw-file-problems/
                http://discuss.extremetech.com/forums/thread/1004400807.aspx
                  Scott M
                  Thanks went to the first link and fixed the problem it was my ca settings every thing worked this time thanks again
                  • fredo6F Offline
                    NEW RELEASE 07 Nov 2010
                    This release mainly fixes a performance issue with the contextual menu in models having a huge number of elements, whether you use BezierSpline or not (see discussion at http://forums.sketchucation.com/viewtopic.php?f=180&t=31788#p280335).
                    Download new release at [url=http://forums.sketchucation.com/viewtopic.php?f=323&t=13563&p=100509#p100509:2ep6sbf2]main post[/url:2ep6sbf2]
                    • utilerU Offline
                      utiler
                      Thank you Fredo, Thank you, thank you, thank you.....
                      Just Curious...
                      • fredo6F Offline
                        @oxer said:
                        Hi Fredo!
                        Thanks for the plugin, i have introduced the spanish language to the BezierSpline v1.4 - 07 Nov10, i upload it here for share with all users.
                        Oxer,
                        I have published an update with the Spanish translation integrated.
                        see main post
                        Could please edit the previous post and remove the attachment (actually, there are some issues with the files you posted).
                        • fredo6F Offline
                          NEW RELEASE 1.4e - 10 Nov 2010
                          This release just integrates a Spanish translation kindly provided by Oxer
                          Download new release at main post
                          • OxerO Offline
                            Oxer
                            Hi Fredo!
                            Thanks for the plugin, i have introduced the spanish language to the BezierSpline v1.4 - 07 Nov10.
                              theark
                              Thank for your sharing.Great work. πŸ‘ πŸ‘
                                poohnut
                                thankssssss 😍 πŸ˜›
                                  Krypt
                                  Thank you very much for this. πŸ‘
                                  • Q Offline
                                    queti2000
                                    Fredo6,Thank You very much!
                                    • ElibjrE Offline
                                      Elibjr
                                      Thank you very much! 😍
                                        aswas
                                        HThe link for this [Plugin]is not working, is there a reason for this? I would realy like to try the bezier tool.
                                          Hi aswas,
                                          The link does work for me. What do you see in place of the download link to the zip archive under that big, yellow, download label?
                                            Hi Fredo
                                            I have 1.4e - 10 Nov 2010 installed, but I still experience the context handler to lag on larger models.
                                            Example: ~92.000 entities:
                                            ### Context Handler ### bezierspline_main.rb:2465:inload_all_menus' [...] bezierspline.rb:50
                                            3.013 seconds`
                                            • 22
                                            • 23
                                            • 8 / 23
