    Photo merge... HELP!!!
    Scheduled Pinned Locked Moved Post Processing
    28 Posts 11 Posters 13.9k Views 11 Watching
    • RichardR Offline
      Richard
      Import the photo as a foreground watermark in SU and make it transparent then rotate and zomm your model to match!
      [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
      • oganocaliO Offline
        oganocali
        Tgi3d photoscan may be of some help here especially if you have more than one aerial photos. Learning Tgi3d can take some time, but in a pinch I can try calibrating the aerials if you somehow (post/pm/dropbox) send them to me. To get the object scale right I would need correct distance between two visible features or coordinates of some visible features. Once you have a calibrated photomatch scene you need to rotate/translate your built model to match the existing features.
        Ogan
        • DareDevilD Offline
          DareDevil
          Photomerge is not the good tool for your project. It works fine on orthogonal objects.
          For your problem, I will use the coastal navigation way to locate a point. We use alignments of land object like towers or mountains. In your aerial view, we can also use planar object like roads or river.
          • First search "vertical" alignments in the aerial view
          • Next, report alignments on the SU model. They would intersect in a point (or nearly)
          • Finally, the point of view would be on a vertical line over this intersection. Turn off the background model and place the aerial photo on background in the style setup panel.
            Use the "place camera" tool on the intersection and use the Value Control Box to enter and test altitude and the Look Around tool too find the good direction and type angle of view in the VCB with the Zoom tool activated to find the right field of view. Don't use zoom tool directly on the model because it change the camera position (is not a real "zoom" tool, it's a "walk ahead" tool !).
            If you have some data about the aerial photo (altitude, angle of view...), that will help you to find the right place and view.
            Hope that can help you.
            bjornkn
            @utiler said:
            Well it should seeing each photo is generally taken with a different FOV.... Believe me, when i try to match the photo with the model it becomes severely distorted!!
            That's because when using zoomm in Su it isn't really zoom, but moving the camera, which changes the perspective. Change the FOV to "scale" it, and the zoom to change perspective/position.
            Edit: That technique posted by @daredevil is a very good one πŸ˜„ I often use a similar one, but haven't actually drawn those lines. Next time I will πŸ˜„
            Using the Walk tool (or Look-Around) you can type in the eye altitude, or use the mouse+shift to change it.
            • RichardR Offline
              Richard
              Daredevil! πŸ‘ πŸ‘ πŸ‘
              • utilerU Offline
                utiler
                Cheers guys!! Gee some neat ideas there....!
                Here's where I got to with it:
                1. Imported hi-res watermark image into the model
                2. Fiddled with FOV settings to manipulate the model and WHA-LA!!
                That is a good process, daredevil!!
                πŸ‘ to you all; legends!!
                Just Curious...
                  Wha-La?
                  Surely voilΓ  πŸ˜’
                  • utilerU Offline
                    utiler
                    Only problem with bringing in a hi-res image as a watermark is that the export is only as good as SU exports your viewport... not good if you want to maintain pixel size. πŸ‘Ž
                    Just Curious...
                    • RichardR Offline
                      Richard
                      Do the merge in Photoshop post pro mate!
                      • utilerU Offline
                        utiler
                        I tried that but the problem is exporting a high enough image from SU.... When I exported and got rid of the background the edges were way too pixelated....
                        Just Curious...
                        • RichardR Offline
                          Richard
                          Drag it into layout with no background, convert to vector export hi res PNG from there!
                          • utilerU Offline
                            utiler
                            Thanks smart-arse...... I'll try that!! πŸ‘
                            Just Curious...
                              Two Aussies are being polite to each other while talking... 🀣
                                DareDevil
                                Nice job !! πŸ‘ πŸ‘ πŸ‘
                                  bjornkn
                                  Did you use anti-alias in SU?
                                  Or didn't you use any feather selection in PS?
                                  Or did you perhaps export as a compressed jpg? Not a good idea if you want to do any masking afterwards.
                                  Often it is better to export a big image without AA from SU and then scale it down smoothly in PS.
                                  What exactly are we talking about here when you say "highres"?
                                  BTW, there's no point in importing any highres images into SU, as they will be scaled down anyway, to what OpenGL can handle on your machine (max 2048px?)
                                  • RichardR Offline
                                    Richard
                                    Bjorn
                                    Mate I think Utiler is talking evry large images! SU can never match the output one can achieve going through the Layout option particularly if you export to PDF and then open that in Photoshop.
                                    • RichardR Offline
                                      Richard
                                      Funny thing - he actually is being polite in Aussie speak! πŸ˜„
                                      • utilerU Offline
                                        utiler
                                        πŸ‘
                                        Just Curious...
                                        • masoM Offline
                                          maso
                                          Hello guys
                                          not exactly on the topic, but i couldnt find any tool that would work this problem out. Is it possible to zoom the window somehow (actual cutout of a view)?
                                          • utilerU Offline
                                            utiler
                                            @maso said:
                                            Hello guys
                                            Not sure what you mean by that maso...?
                                            Just Curious...
