    Photo merge... HELP!!!
    Scheduled Pinned Locked Moved Post Processing
    28 Posts 11 Posters 14.5k Views 11 Watching
      1. I don't know how that relates to SU's FOV toggle as it is in degrees (I think)
      Tool Zoom : "xx.deg." inside the VCB page right bottom
      here maybe 40 Β° ?
        Roger
        Have you tried going to google earth and grabbing vertical views to set up your base model?
        http://www.azcreative.com
        • RichardR
          Richard
          Import the photo as a foreground watermark in SU and make it transparent then rotate and zomm your model to match!
          BUILTBRAND.COM.AU
          • oganocaliO
            oganocali
            Tgi3d photoscan may be of some help here especially if you have more than one aerial photos. Learning Tgi3d can take some time, but in a pinch I can try calibrating the aerials if you somehow (post/pm/dropbox) send them to me. To get the object scale right I would need correct distance between two visible features or coordinates of some visible features. Once you have a calibrated photomatch scene you need to rotate/translate your built model to match the existing features.
            Ogan
            • DareDevilD
              DareDevil
              Photomerge is not the good tool for your project. It works fine on orthogonal objects.
              For your problem, I will use the coastal navigation way to locate a point. We use alignments of land object like towers or mountains. In your aerial view, we can also use planar object like roads or river.
              • First search "vertical" alignments in the aerial view
              • Next, report alignments on the SU model. They would intersect in a point (or nearly)
              • Finally, the point of view would be on a vertical line over this intersection. Turn off the background model and place the aerial photo on background in the style setup panel.
                Use the "place camera" tool on the intersection and use the Value Control Box to enter and test altitude and the Look Around tool too find the good direction and type angle of view in the VCB with the Zoom tool activated to find the right field of view. Don't use zoom tool directly on the model because it change the camera position (is not a real "zoom" tool, it's a "walk ahead" tool !).
                If you have some data about the aerial photo (altitude, angle of view...), that will help you to find the right place and view.
                Hope that can help you.
              • B
                bjornkn
                @utiler said:
                Well it should seeing each photo is generally taken with a different FOV.... Believe me, when i try to match the photo with the model it becomes severely distorted!!
                That's because when using zoomm in Su it isn't really zoom, but moving the camera, which changes the perspective. Change the FOV to "scale" it, and the zoom to change perspective/position.
                Edit: That technique posted by @daredevil is a very good one πŸ˜„ I often use a similar one, but haven't actually drawn those lines. Next time I will πŸ˜„
                Using the Walk tool (or Look-Around) you can type in the eye altitude, or use the mouse+shift to change it.
                • RichardR
                  Richard
                  Daredevil! πŸ‘ πŸ‘ πŸ‘
                  BUILTBRAND.COM.AU
                  • utilerU
                    utiler
                    Cheers guys!! Gee some neat ideas there....!
                    Here's where I got to with it:
                    1. Imported hi-res watermark image into the model
                    2. Fiddled with FOV settings to manipulate the model and WHA-LA!!
                    That is a good process, daredevil!!
                    πŸ‘ to you all; legends!!
                    Just Curious...
                      Wha-La?
                      Surely voilΓ  πŸ˜’
                      • utilerU
                        utiler
                        Only problem with bringing in a hi-res image as a watermark is that the export is only as good as SU exports your viewport... not good if you want to maintain pixel size. πŸ‘Ž
                        Just Curious...
                        • RichardR
                          Richard
                          Do the merge in Photoshop post pro mate!
                          BUILTBRAND.COM.AU
                          • utilerU
                            utiler
                            I tried that but the problem is exporting a high enough image from SU.... When I exported and got rid of the background the edges were way too pixelated....
                            Just Curious...
                            • RichardR
                              Richard
                              Drag it into layout with no background, convert to vector export hi res PNG from there!
                              BUILTBRAND.COM.AU
                              • utilerU
                                utiler
                                Thanks smart-arse...... I'll try that!! πŸ‘
                                Just Curious...
                                • GaieusG
                                  Two Aussies are being polite to each other while talking... 🀣
                                  • DareDevilD
                                    DareDevil
                                    Nice job !! πŸ‘ πŸ‘ πŸ‘
                                    • B
                                      bjornkn
                                      Did you use anti-alias in SU?
                                      Or didn't you use any feather selection in PS?
                                      Or did you perhaps export as a compressed jpg? Not a good idea if you want to do any masking afterwards.
                                      Often it is better to export a big image without AA from SU and then scale it down smoothly in PS.
                                      What exactly are we talking about here when you say "highres"?
                                      BTW, there's no point in importing any highres images into SU, as they will be scaled down anyway, to what OpenGL can handle on your machine (max 2048px?)
                                      • RichardR
                                        Richard
                                        Bjorn
                                        Mate I think Utiler is talking evry large images! SU can never match the output one can achieve going through the Layout option particularly if you export to PDF and then open that in Photoshop.
                                        BUILTBRAND.COM.AU
                                        • RichardR
                                          Richard
                                          Funny thing - he actually is being polite in Aussie speak! πŸ˜„
                                          BUILTBRAND.COM.AU
                                          • utilerU
                                            utiler
                                            πŸ‘
                                            Just Curious...
