    How to fold a plane around a curved surface?
    15 Posts 6 Posters 5.3k Views 6 Watching
      Michel,
      Could you build a dodger for my Catalina 27? πŸ˜„
      So did you try turning the dodger face so it is "horizontal" for Super Drape? Maybe you said this and I didn't catch it. You might try Shape Bender to bend the flat version to match.
        mac1
        Look at the plugin tools on surface or just draw widow and then extrude thru dodger and intersect. You have a window plane intersecting with what looks like a truncated cone and the intersect should give the vertical sloped lines you want ?
        You could also draw them with the line tool( make sure you use the correct inference). However from the pronounced arc at the their bottom I think you are using very high poly surface. Is it possible to post model at least the dodger portion?
        Here is one concept using the line tool. Only one window drawn the rest made with radial copy. Not the lat line for ref.
          Try ExtrudeEdgesByVectorToObjects...
            TIG, does that not result in a projection on the surface? That would be different from wrapping the flat windows around the dodger, no?
            Tools on Surface could be good if you know where the lines need to go on the curved surface.
            Shape Bender should allow you to take the flattened dodger surface with the glazing and wrap it back up. I would probably only work with the part of the dodger that has the glazing and not include the bit that wraps over the top.
            On the other hand, I wonder if it wouldn't be easier to create a pleasing line by laying the glazing out on the curved surface. Seems it would be a bit like creating the proper sheer line. Much easier to get right on a 3D boat that on a flat drawing.
            • B
              bjornkn
              I think I would've tried with Shape bender, with a slightly scaled curve (up or down). And then use Joint Push Pull to extrude those windows through the windshield/front wall. An Intersect-with-model would then stamp the windows nicely into the windshield?
                Yes it is a projection from EEbyVectorToObjects .
                BUT how is anyone supposed to devise a 'flat' set of windows to wrap around a curved hull anyway ?
                If you have an elevation [properly drawn] of these windows then you use those as the EEbyVectorToObjects edges it will project that truly onto the curved surface.
                But how might someone otherwise decide on the form of the windows as a flat object that's floating in space that will somehow miraculously wrap onto an arbitrary surface to give the 'expected' result like any applied decal ?
                  mac1
                  TIG is on the money. It appears to me the confusion comes from the fact the OP presents the windows on developed surface which one gets when the surface of a cone is developed =>aka fattened. In actually one needs to ask the question how would this been done for an actual build or does one care?? The issue with the intersection I did not like when tried initially is the widows stiles will be warped because one is dealing with a double curved surface
                  Dave R. how would you actually build this??
                    Mac1, I'd pay the canvas guy up the road from the marina. πŸ˜„
                    The frame would be set up on the boat first and then the fabric would be pinned up over it--much like fitting a suit on a dress dummy. The lines for the openings would then be marked out on the fabric while it is in place. Everything would be sewn on the flat but obviously tucks and darts would need to be put in the right locations to make the think fit.
                      mac1
                      Got It Dave. Like me when all else fails hire some one πŸ’š
                      Is he the same guy that makes the curved glass for you ❓ ❓
                        Some things I could do but it would take me much longer so I figure it's better to pay a guy to just git 'er dun.
                        The glazing on the dodge is a flexible plastic--often vinyl so it corners to the shape just fine. πŸ˜‰
                        • broomstickB
                          broomstick
                          How to fold a plane on a curved surface?
                          Nothing more simple:
                          http://pad.mymovies.it/filmclub/2006/05/271/locandinapg1.jpg
                          Forgive me.. I couldn't resist πŸ˜„
                            πŸ‘ 🀣
                              MichelC
                              Dave, I tried laying out the windows on the dodger front but i couldn't get curved (horizontal) lines on the dodger front because the dodger front is not a neat arc. It's a mix of two arcs and two straight lines nearing the aft end of the sides of the dodger. I still haven't figured out how to do this. I'm now trying to place the windows separately in front of the surface and then push/pull them through the dodger surface and then intersect. See what happens.
                              Michel
                                mac1
                                It would help greatly if you posted your model or portions thereof so we know what you are really trying to do. Otherwise it is a guessing game πŸ˜’
