    How to get from 3D model to 2D construction plans?
    23 Posts 7 Posters 32.3k Views 7 Watching
      It is a pretty nice lake. Techincally it's a wide area in the Mississippi River.
      So to thicken the skin to represent it's real thickness, you could use Joint Push/Pull. Hit Tab before starting the push/pull operation and choose Thickening. That ought to get you what you need for the skins.
      There are many benefits to using components in your model but the editing thing is huge.
      TTFN
      Dave
        MichelC
        Dave, another great tip, the joint push/pull plugin! Many thanks! I should have known this weeks earlier.
        Michel
          At least it exists now for you. A number of years ago, before it was around I drew the hull of the little boat I designed and built as a cradle for my son. I created the thickness by hand. Lots of work.
          http://farm6.staticflickr.com/5218/5383695337_554183f1ac_z.jpg
            Wow πŸ‘
            That's superb Dave
              What? The lake? I didn't make it.
                The crib. It's really nice.
                  Thank you. It was fun to build, too. The planks are clear pine that I resawed and planed to 1/8" thick. It's amazing how strong it is considering how thin the planks are. The worst part was planing the rolling bevels on the planks and the gains at the ends. The planks are so thin, it only took a couple of swipes with the plane to cut them. It was easy to get too much off.
                    MichelC
                    That's a sweet little swinging bunk!
                    Michel
                      Thank you Michel.
                        MattC
                        Hi MichelC
                        I think I could help.
                        I am busy with creating tools to make paper scale models in Sketchup.
                        You can see examples how my scripts work here: http://www.screenr.com/user/SketchupPP
                        In fact it covers quite a lot of what you are asking for.
                        One thing that is missing is a nesting algorithm, but it is very complex story.
                        Greets
                        Matt
                          chad3006
                          I have a related question. Is there a way to export a picture from SU that would eliminate perspective distortions (parts of a model that are further away look smaller), so all visible surfaces of the model in the exported picture keep their β€œtrue” size? For my purposes the model doesn’t have to be unfolded into its various parts, just a flat picture. Does that make sense?
                            Chad, you can set the camera to Parallel Projection. Look in the camera menu. Perhaps that will do what you want? another thing you can do is reduce the "wide angle" distortion by adjusting the field of view. Select the Zoom tool from the Camera toolbar. The measurements box will indicate either an angle of view or a focal length (degrees or mm). You can enter a low angle of view or a higher focal length to reduce the appearance of things receding into the distance.
                            Here's an example:
                            http://farm3.staticflickr.com/2427/5850582777_c4c61b6e7d_z.jpg
                            28mm focal length
                            http://farm3.staticflickr.com/2646/5851134266_e751b1dfff_z.jpg
                            85mm focal length
                              chad3006
                              Yes! Switching to parallel projection did the trick. Thanks!
                                Cool! πŸ‘
