    [Plugin] IGES Export - 27 February 2012
    58 Posts 32 Posters 69.6k Views 32 Watching
      Exported data/files are not subject to an undo or an abort call...
      IF your exporter must change the model's data so it can work successfully, then the correct way to proceed is to satrt ALL of its actions after a Sketchup.active_model.start_operation('IGESexport') and after it's made the export use a closing Sketchup.active_model.abort_operation, which undoes ALL of the changes you have made to the model BUT leaves the external file[s] alone...
      That way you get your data exported correctly but the user gets no nasty surprises when he finds his model has be tampered with !
      πŸ€“
        rainer.ochs
        Of course the exporter should not modify the model. It does it during work but afterwards undoes the changes. In V0.4 the undo was made a comment for testing, in V0.5 this is corrected.
        TIG: is there a difference whether I use "model.abort_operation" or "model.commit_operation" and "Sketchup.undo" as I do?
        thomthom: the exporter never was optimized for fast operation, I wanted to keep it simple. As I undo the changes it is no problem to adhere attributes to the entities, they never will be saved. IGES is constantly referring with pointers to its structural elements, keeping track with attributes was simpler to implement and more descriptive. I agree that hashes might be faster. But as the structure is still growing when I am going to implement splines I still prefer the more understandable approach.
        What do you recommend to use instead of "typename"?
          Use .is_a?( Sketchup::Face ) etc...
          • Z
            Zacchia
            I have some files in iges format I would like to import in SU, so an importer would also be nice to have...
            • AnssiA
              Anssi
              One interesting part in this is that it creates "real" solid geometry out of SU "solids". Could it be expanded into the DXF format too? That would add a useful feature that the current DWG/DXF exporters lack.
              Anssi
                rainer.ochs
                I got good results with HeeksCAD ( http://heeks.net) a freeware CAD program.
                It can import iges and once in Heeks you can save it to step, dxf and stl.
                The programs file converting is based on open cascade (http://www.opencascade.org) a very sophisticated system. As far as I have been testing, the results are reliable.
                  rainer.ochs
                  There is a description on http://eagleup.wordpress.com/?s=iges&searchbutton=go%21
                  on Importing a STEP or IGES file into Sketchup using FreeCAD and MeshLab.
                  file.step => FreeCAD => file.stl => MeshLab => file.dae => Sketchup => file.skp
                  • Z
                    Zacchia
                    Thank you for this information, it works! I already knew meshlab, freecad not...
                      sepo
                      I tried to open .igs export from SU in Rhino. It bring geometry but geometry is broken. The model is made of separate surfs and some surfs (curved) are missing.
                        DavidVT
                        Nice addition!
                        I am struggling to find the size limit that will work.
                        I have a very complex model the size of an aircraft that seems to lockup everytime.
                        I test this with a small box and it works great.
                        Suggestions???
                          jonorman
                          This plugin is amazing. The possibility to export "solids" out of SU is for me close to the holy grale πŸ˜„ Thank you so much..
                            rainer.ochs
                            I do not think, that the size itself is a problem. I usually scale my models in micron so I also have fairly big numbers and this worked fine. I think the problem is more the complexity. To convert from a face-model to solid it is very important that the outer shell has no gaps and no inner geometry. The exporter removes all parts it cannot convert to real shells.
                            Suggestion 1: Try redo to see what the exporter does to the model. If the parts are deleted there it is a problem with the geometry.
                            Suggestion 2: Try HeeksCAD to open the iges. If it is ok there, convert to step and import from there. If it is not ok the iges is the problem. Feel free to send me your model to the email that is given in the code.
                            • G
                              gordon_smith
                              I haven't tried the plugin yet, but it is very exciting. This could make sketchup much more useful for me. Where I work the mechanical engineers use Catia, and it would be awseome to be able to send them my drawings in a format that they can use.
                              I also want to second the FreeCad & MeshLabs method as a great way to get IGES files into sketchup. πŸ‘
                              Irrationally held truths may be more harmful than reasoned errors.
                              Thomas Huxley
                                rainer.ochs
                                There is also a direct importer plug-in for stl into sketchup:
                                http://sketchuptips.blogspot.com/2010/03/sketchup-stl-importer-redo.html
                                A direct export to stl can be found at http://www.guitar-list.com/download-software/convert-sketchup-skp-files-dxf-or-stl
                                STL from other formats can be converted with FreeCAD or the above mentioned HeeksCAD.
                                All of these tools do not segment the model into different objects and the exporter does not generate a solid.
                                The importer generates a lot of nasty inner edges, but with a small tweeking of the script this can be fixed.
                                Just add the following lines into main after the import:
                                a = Array.new
                                Sketchup.active_model.entities.each{|e|
                                if (not e.deleted?) && (not e.hidden?)
                                  if e.is_a? Sketchup;;Edge
                                     if e.faces.size == 2
                                        if e.faces[0].normal == e.faces[1].normal
                                           a << e
                                Sketchup.active_model.entities.erase_entities(a)
                                  Adrian Berghorst
                                  This has helped me a LOT! Thank you very much.
                                    realwarder
                                    Great plugin. Helped me. Thank you!
                                    My model does export with one problem. If you want the file to test with, let me know.
                                      You need to describe what this problem is. Otherwise it's completely impossible to know what is going on.
                                        realwarder
                                        The first problem I was having was a section that was a long PCB cutout shaped with half-circle ends and straight sides was exported as curved sides.
                                        I got around that by manually fixing in the destination CAD.
                                        Current issue is a metric sized drawing is exporting to inches. Not sure how this plugin determines the units.
                                        I.e. my PCB which is 72mm wide, after exporting to an IGS, imports as a 72" wide drawing.
                                          I have just found the free Creo element who can reload a cube from this iges export β˜€
                                          • T
                                            tmiehle
                                            This plugin is great !
                                            I use it with the "EagleUp" script to build 3D models out of PCB layouts.
                                            Now I have one feature request:
                                            Is it possible to generate a list of the components which are buggy?
                                            It is a little frustrating to check the output visually and try to find out which elements are meant by "Model contains non-solid elements" which will not be exported?
                                            Best regards
                                            Tom
                                            • 1 / 3
