    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.4m Views 342 Watching
      davelee100
      Hello everyone
      I have just registered after purchasing Sketchup Pro 8.
      I do have experience with sketchup having played with the free versions in the past but now I am ready to get serious with this software.
      I have seen the video clips on Fredoscale and this is definitely something I need in my work but because I am a complete newbie with installing sketchup tools I wonder if some kind person would post up an idiots guide to downloading and installing Fredoscale for the first time.
      I really need a blow by blow breakdown on all the steps and if there is any other software I need to make it simpler.
      Thank you for your patience
      David
        Hi David and welcome.
        First of all, this is the place you need to install your plugins on Mac:
        Macintosh HD/Library/Application Support/Google SketchUp 8/SketchUp
        Then here is a forum post about how to install more complex plugins (which are generally consist of several files therefore zipped):
        http://forums.sketchucation.com/viewtopic.php?f=323&t=35746
        Also note that in order for FredoScale to work, you need an additional plugin library LibFredo (linked from his first post)
        • pbacotP Offline
          David,
          I see you are using Mac OS. One thing I find useful is to put the (alias of) the Plugins folder into my sidebar. Then I can drag from the downloads folder to the plugins folder any time. Makes the whole process pretty painless. If the files are zipped, I usually unzip it in the downloads folder and take the files I need from there. Note that when you unzip in Mac it creates a folder, when there are multiple files. You want what is in that folder--not that folder itself.
          This is a great plugin. Takes some learning. But save before you use, especially on complex objects.
          Peter
            davelee100
            Thanks guys... good information.... i will try this in the morning
            • dereiD Offline
              derei
              I used FredoScale - stretching with orientation of scaling box on this model and caused bugsplat. Is it possible to fix the plugin? It's a group that has inside some components. I applied FredoScale on a copy of that group.
              EDIT: if I enter the group, it becomes unique and it can be stretched. My suggestion: FredoScale to make it unique group prior editing. Maybe SU tries to update Group's definition and that is why it ends in bugsplat.
              bugsplat.skp
                bricofranck59
                Hello
                Merci beaucoup, ce plugin est vraiment formidable
                Francis
                  griffeur
                  Hi!
                  Do you know how can I do something like the "scaling by reference" in autocad? The scaling target mode doesn't seem to work in the same way. Thanks!
                  • fredo6F Offline
                    @griffeur said:
                    Hi!
                    This is an interesting function which is not supported by FredoScale exactly in the same way. The Scale to Target requires that you scale in the same direction than the target points (even if they can be taken from anywhere in the model).
                    The idea behind is to perform the scaling (or other) transformation which brings the origin to the target.
                    Maybe I'll add the feature in a next release.
                      griffeur
                      Thanks! This kind of Scaling is realy important for me in architecture modeling(plan scaling, etc...)
                      • pbacotP Offline
                        Giffeur,
                        Meanwhile you might want to make use of the tape measure tool for this sort of scaling. In this case you would work inside a group. It would require (in the example of the door) first measuring the opening, then rescale the door using the tape measure tool (from inside door group) to define the opening width. You then have to move the door back into position. Much longer than autocad version but works, and might be quite fast for some uses, once you are used to it. It will scale in all directions though. There are videos showing how to use the tape measure tool this way.
                        It is a good way to rescale a whole 2d plan using a known dimension.
                        Peter
                          ByKAz
                          Hi Fredo, I have been using the FredoScale on my Imac OS 10.5 (Leopard) without any problem.
                          I change it for a new Imac OS 10.7 (Lion) and FredoScale crashes a lot, I'm not sure whats happening...
                          Could you help me with this issue!??!?!
                          Anyway, the FredoScale is the best plugin ever...
                            racer13
                            For some reason the plugin stopped working for me. I don't know what happened. There isn't any error message that comes up or anything, it just doesn't work properly. For example, when I try to use the radial bend tool on say a long rectangular box, my complete process is
                            1. draw a rectangle that is long on the red axis and very skinny on the green axis.
                            2. push/pull that rectangle to a height that makes the vertical green axis, the skinny one, almost a square, so you have a long bar, not a tall plane.
                            3. select the radial bend tool from the toolbar.
                            4. select the box just made on the red axis face.
                            5. drag the line to bend from away from the center axis, or away from the person.
                            6. tell it to bend up.
                            7. confirm.
                            Result is a diagonal box with the face along the green axis line vertical and normal and the opposite face at some weird angle up in the air. No curve or bend at all. But the weirder thing is that really weird that confuses me is that if I try it on person then it works fine. I added other plugins and already tried disabling those, but it still didn't work. And it used to work before. Can someone explain to me what to do or even whats wrong? Thanks, because I love this plugin!
                            • fredo6F Offline
                              You need to activate the slicer (Key F4) to slice automatically the shape. Otherwise, since there is no intermediate slice, it would not bend, but just shear.
                              • fredo6F Offline
                                I don't know too much, except that there have been many problem reported with OS X Lion. I think they are somehow solved with SU8 M2.
                                Anyway, it would be good to give some details on the circumstances of the crashes you have.
                                  racer13
                                  Thanks, that fixed everything! Lesson: Don't play with settings you don't understand! Now I can use this fantastic plugin again! Thanks for creating such a wonderful and simple plugin that's free! I love it! It makes everything so much easier!
                                    ByKAz
                                    I'll keep you posted, thanks for your time and consideration
                                    • pep75P Offline
                                      pep75
                                      Hi SU-pers!
                                      I've a little question and it's probably asked before. But I can't find it in this forum nor an answer in the manual. I want to scale a box(for instance) with the FredoScale-tool, and I want to scale that from the Centre (with the ctrl-key) and then input(TAB) ONLY the width(along the red axis). But this seems to be not possible without a length-input...It's hard to explain....But I only want to have one dimension fixed while scaling the object proportionally around its centre.
                                      How can this been done, does anyone know that?
                                      Thanks in advance!
                                      Pep
                                        jcastro.arch
                                        I am having a bit of an issue. I am running Mac OS Lion and I just tried to install your Fredo Scale 2.2 a and LibFredo6 and placed the folders in the approiate plugins... but I dont see any of the tools when I start up SketchUP. I was hoping someone had come accross this issue and found a fix, or knows something about this occurance. Any help would be greatly appreaciated. Thanks!
                                        • pbacotP Offline
                                          Jonathan please post the file path. Click on the FredoScale_Dir22 folder and get info (command "i") and look at "where". The total path should read /Library/Application Support/Google SketchUp 8/SketchUp/plugins
                                          • TIGT Online
                                            At the risk of repeating ourselves yet again...
                                            Are you extracting files from the zip correctly ?
                                            Are you also getting and installing the required Lib' folder of supporting tools as advised on the download page ?
                                            What 'Plugins folder' are you putting things into on your MAC ?
                                            The root[HD]...Library...Plugins is good, user...Library...Plugins is bad.
                                            There are several helpful posts about how to extract and install plugins...
                                            Once everything is in the right folder[s] a restart will make the tool available.
                                            Activate it from Preferences > Extensions.
                                            Active it toolbar from View > Toolbars [slightly different name on a MAC ?].
                                            Customize what appears on the tool's toolbar using the special menu items as explained in the tools help docs/pages...
                                            • 11
                                            • 12
                                            • 56
                                            • 57
                                            • 10 / 57
