    HI and a question
    20 Posts 7 Posters 996 Views 7 Watching
      Why not start off from the 'square court' and seek where it takes you.
      If you are convinced of that forms accuracy start with that and see where the error is is what's left over...
      If you have 'surveyed' the rooms carefully you ought to have taken the dimensions of the main rooms' rectangles - ignoring the bay-windows etc and add those on to the main rectangle, erasing unwanted lines as you complete.
      Where are the wall thicknesses ?
      Presumably you won't have two rooms adjoining each other with paper thin walls ?
      This is not really a SUp issue more a surveying and drawing up problem ???
        dom86
        TIG,
        It is losing 58 inches somewhere and it is me- not sketchup - but I cannot understand why.
        I know my measurements are correct - but I will just close that gap for now and use what is - since I am totally happy with the rest of the model - perhaps it is an error I am doing on the computer and just not seeing it! πŸ˜’
          mac1
          Why in the world do you refuse to post your simple model? The guys here would probably find the answer in secs or do you just to like to ask questions and in the process waste peoples time 😒
          BTw you can use the entity info to get a measure of each line length or the text tool and display the x, y,z value for each end point and quickly find the problem.
            dom86
            mac1:
            If you can point me where to post the skp to, I will.
            • BoxB
              From another thread.
                dom86
                OK thanks - here we go:
                u001.skp
                  OK...
                  Since we don't have any 'original' dimensions how might we know the 'errors'?
                  I have marked where you assume a paper thin wall, that will have a real thickness...Capture.PNG
                  • GaieusG
                    I am almost certain that no-one but you know what these dimensions should be. I suggest to start adding real dimensions to your floorplan and somewhere you will find the mistake. You can snap dimensions to anywhere: endpoints, midpoints, intersections (with guides for instance) to be precise. Somehow like this (I converted all dimensions to simple inches as my brain cannot work with feet & inches)
                      dom86
                      Tig,
                      Yes, there are lot of walls which are between 8 and 16 inches thick in the building.
                      The two lines in the centre are the entrance hallway (5'). The building is to the inch.
                      The 'square' is divided in two down the middle with a 6" wall. At the rear are two 42" windows, framed with 6" frames - exactly in the middle of the building opposite the front door (which is two 2.5' doors).
                      The rear walls join to the extension of the box at precisely 31' 10".
                      At each corner (on the rear of the square) it is 103 inches to the window frames.
                      The actual measurement is 103-6-42-6-42-6-103
                      You will see that the rear walls align with the front walls with an offset - this is correct - and you will see it is symmetrical as you would expect.
                      If I draw to here, and do not insert the 'square' - the whole building is perfectly OK - but the measurements I have taken (most recently a recheck on friday) doesn't align the 'box'.
                      • pbacotP
                        I could not help wondering what side of the walls were being measured. I drew in some walls-- arbitrarily in hopes of finding the discrepancy in a way that would be favorable (I made a further guess and extended the alcoves each side of the central square), but perhaps not enough length. So that's the question I'd have: If you draw in the walls, even temporarily, which sides of the measurement are they?
                        Sometimes in measuring a building we measure wall thicknesses at doorways. In conventional homes, to save time, I usually just assign the standard wall thickness when drafting, knowing that I want a "square" plan that ignores those as-built discrepancies that would be insignificant to the builders--then I might check it further against overall measurements. Either way, I draw the wall space into my site sketch. These things can be vexing, back at the office.
                          mac1
                          dom86;
                          One other thought. You are measuring an imperfect building and then modeling it perfectly. I have not done any analysis ,but form my intuitive thinking the wall thickness may not account for such a large error. The thought is a small racking of the building can give large errors over the long distances you are dealing with. If you have any chance it may help to measure some diagonals to get some idea how square the building is. I don't think you want to model on that basis but could help understand the issue.
                            dom86
                            Guys
                            Thanks. I will pop another file up soon. I have discovered that what it seems to be is that the measurement on the front is off.
                            The two extensions off the main block at the front actually sit over part of the main building: this is the same on both sides - since I have measured outside only this is where the gap (seems) to be coming from - I will draw up an example
                              dom86
                              OK: I think this is where the problem is: I have 'counted' the distance around the wall (highlighted in yellow) - but as they are effectively bits that are 'added on' they are not part of the building itself, and what's more some measuring matches the discrepancy to the inch....
                                mac1
                                Some thoughts for you. Aligned square and front entrance per your 2 26 616am post and added double jack studs and trimmers for the two window case.
                                Just some thoughts.
                                u001_mac1B.skpdom86
                                  dom86
                                  Mac1
                                  Thanks. I've had a look, my skp was not marked correctly from the window aspect.
                                  I am now working an a new plan, but without side extrusions, it should look a little more accurate
