    Components along path problems
    21 Posts 5 Posters 1.6k Views 5 Watching
      driven
      there's some excellent experiments by Simon Le Bon around this page..http://forums.sketchucation.com/viewtopic.php?f=323&t=23616&hilit=Component+Stringer&start=30#p201164 some of mine in there as well.
      • mitcorbM Offline
        mitcorb
        Here is just an image using bezier converted to polyline divider, Component Stringer with some odd sized tube section. I forgot that you place the component in some relation to the path. So instead I just moved the path after, to align with the pipe sections, then did Tube Along Path.
        As you can see, if you use too tight a curve, the components in the string wander off.
        • mitcorbM Offline
          mitcorb
          And while I was dithering around, I missed your reply. Sorry about that. And you ain't dumb, no way.
          • hellnbakH Offline
            hellnbak
            This is going to sound strange, but I cannot see the image unless I am posting a reply, then I can scroll down and see it. Weird.
            Anyhow, that looks promising. I've never used bezier spine, guess I'll have to see if I can figure it out. Thanks for your timely replies.
            Driven, I am working my way thru the thread that you referenced. Thanks.
            • hellnbakH Offline
              hellnbak
              Ah, now that I've posted my reply I can see your image. Feel like I have one foot in the Twighlight Zone
                What makes you think you don't? 😄
                  chrisjk
                  That doesn't seem to be the case for me, Instead, the components just scrunch up and intersect one another
                  http://content.screencast.com/users/chrisjk/folders/Jing/media/5ee8e41f-992e-4bc5-812a-b3b108817546/00000019.png
                  • hellnbakH Offline
                    hellnbak
                    Well, I finished what I needed to do, but just did it manually, one component at a time. I know that some of the suggested methods would have been much more efficient, and accurate, but I just needed to get this done and it will take time to learn any of these new methods.
                    It ain't perfect, but it won't be viewed close up so I guess it's close enuf for my purposes.
                    Thanks to everyone for all the input, very much appreciated, as always.
                    • mitcorbM Offline
                      mitcorb
                      Hi, hellnbak:
                      Your results look right enough. Is this supposed to be like a shielded tubing?
                      • hellnbakH Offline
                        hellnbak
                        @mitcorb said:
                        Hi, hellnbak:
                        Thanks. Yeah, something along those lines.
                        • mitcorbM Offline
                          mitcorb
                          I kept the model file that I made the my above image from. Because I didn't feel I was finished. Last night I moved one by one the stray components into their "right" positions. All by eye.
                          I guess you have to plan the path and set the segments of that path just so, in order to get the results.
                          I had the same experience as you on the intersecting and overlapping on the unpainted example, so I edited the component and move stretched the end face so that there was no overlap.
                          As for the inner tube, there is no reason not to use follow me but maybe the ends won't be quite right.
                            Tim, I'm curious about your model. Where is the component's origin located?
                            • mitcorbM Offline
                              mitcorb
                              Hi, Dave:
                              I will have to look at it when I get to the house and respond. I am stealing a "minute" at work to see what's been happening here. 😄
                              • mitcorbM Offline
                                mitcorb
                                Hi, Dave:
                                Sorry for the delay.
                                Attached is another view of the file. I did not take the time to set the component axes when I started the model, so I have the axes on display, now. Is this what you seek?
                                A few minutes ago, I saw the last posts in ComponentStringer thread, and got re-informed.
                                spinaltaptohellnbak2
                                • mitcorbM Offline
                                  mitcorb
                                  Well, I see that axes are not displayed in the image. I wonder if I should have used a .bmp instead. Attached is the .skp
                                  spinaltaptohellnbak.skp
                                    Aha! If you're interested in running the tubes down the path again, try this. Move the component's origin to the centerline of the tube. You'll get slightly different results if the origin is at one end of the tube or midway down its length. Maintain the same axis orientation you have now, though.
                                    • mitcorbM Offline
                                      mitcorb
                                      Thanks, Dave.
                                      Just lack of practice, no excuse.
