    How would you model this one?
    14 Posts 6 Posters 509 Views 6 Watching
    • dfswyfD Offline
      dfswyf
      Any plugins recommened? Many thanks!
        Grow
        Matrix
        etc
        • dfswyfD Offline
          dfswyf
          @tig said:
          Grow
          Matrix
          etc
          Thank you so much, TIG! But Matrix can array, scale, rotate randomly, grow does not work for these images showing below. Could you give me more information about how to model it? Thanks again!
          • soloS Offline
            Protrude? ๐Ÿ˜‰
            really? how?
              Protrude? ๐Ÿ˜‰
              Or the sand box for move the cylinder?
                really? how?
                Damned: Protrude works but gives a randomly result ๐Ÿ˜ฎ
                Don't remember that it have not a progressive function ๐Ÿ˜ž
                  Using Grow on a component... process it 16 times to 'east', incrementing it to 'north' in each step; using the min to max values across half width, incrementing the Z values for each set.
                  Then copy/mirror all to 'east', then for all of the results you copy/mirror them to 'north', forming the 'mound'...
                    Yes grow can make it but not in one time ๐Ÿ˜‰
                    I have used the "Exponential ZScaling" By lines / by quarter aera
                    And also Extrude edges by vector to Object by Tig ๐Ÿ˜‰
                    You must draw the curvated plan of the ceiling of the cylinders top by the Smoove tool of the Sand box or other tool!
                    http://forums.sketchucation.com/download/file.php?id=69199&t=1
                    If you don't want to have your cylinders truncated
                    maybe you must first project a circle at each point of the vertex of the curvated ceiling made by the Smoove tool
                    the plug Component Spray by Didier Bur makes that
                    then use the Extrude edges by vector by from top to ground ๐Ÿ˜‰
                      Another method
                      As the Plug "Drop" can't intersect with vertices must make this little trick and so don't use "Drop":)
                      Object of the Extrude Edges is a simple plan as ground
                      Component circle must have axis at the middle of the circle!
                      For replace component : Select all components Lines
                      Menu Component / right click on the Component Circle / Replace Selected ๐Ÿ˜‰
                      Edit : in fact you can directly make the Spray with the Component Circle on the mountain! ๐Ÿ˜ณ
                      So more speedy! ๐Ÿ’š
                      • dfswyfD Offline
                        dfswyf
                        Another method
                        [attachment=0:2lbzwogw]<!-- ia0 -->spray.jpg<!-- ia0 -->[/attachment:2lbzwogw]
                        Thank you so much, Pilou!
                        • dfswyfD Offline
                          dfswyf
                          Thanks, TIG! I did some of them, but I could not make No.2
                          • dfswyfD Offline
                            dfswyf
                            Another method
                            [attachment=1:ij9juqvg]<!-- ia1 -->spray.jpg<!-- ia1 -->[/attachment:ij9juqvg]
                            Thanks, Pilou!
                            • H Offline
                              harnstein
                              These pictures were taken from this thread http://forums.sketchucation.com/viewtopic.php?f=289&t=30749 about parametric modeling in SU.
                              If you have a look at other 3d programs, or. eg. grasshopper for rhino, you'll find that these results were archieved with the use of an "attractor" in conjuction with "chained" elements.
                              I cannot explain this in detail (i didn't how anyway ๐Ÿ˜‰ ) but if you're interested just give it a look.
                              I find it very interesting as well as it gives you designing opportunities which are very hard to achieve by hand.
                              Good luck!
                              still sketchin'
                              • mitcorbM Offline
                                mitcorb
                                I have seen something similar at tgi3d. Not sure if these figures specifically can be done.
