    Render Question
    42 Posts 9 Posters 3.1k Views 9 Watching
    • irwanwrI Offline
      irwanwr
      btw, what rendering method did you use there, Dave?
      i like the soft shadow.
        This last one was done in KT using preset #8. there are two spotlights both set to cast soft shadows. The radius of the light more to the front is set at 0.15 and the other light is set to 0.10.
        • irwanwrI Offline
          irwanwr
          πŸ‘
          Thank you, Dave. I've never thought of using either soft shadows or lights.
          Mostly using the preliminary custom preset for quick setting and rendering.
            Having been a professional photographer in a former life, I tend to think in terms of studio lighting for renders so Massimo's suggestions make a lot of sense to me. Still, I much prefer the sketchy stuff I normally do.
              Roger
              Model the tabletop surface instead of using a bump map. Also light from the top left rear (shadow cast forward) and set up a reflector off camera to bounce light back into the resulting dark front of the box.
              Trust me. πŸ˜„
              http://www.azcreative.com
              • boofredlayB Offline
                boofredlay
                Here is a quick go with Photoshop and Dave's rendering. Posted with his permission of course.
                  Roger
                  That is pretty close to what I had in mind. Nice word to the Dave/Eric team.
                    Well, I'm getting closer. I changed the style of the box back closer to the original. I still need to work on the materials a bit but I think it is getting better. Thanks to all for the suggestions.
                    http://farm8.staticflickr.com/7038/6864671773_3f88fa508f_z.jpg
                    πŸ˜„
                      So that means I've taken a step or two back?
                      • bazB Offline
                        baz
                        That would depend on which way you were facing in the first place.
                        • bazB Offline
                          baz
                          Totally unconvincing render Dave. And where did you get that woodgrain material, awful!
                          Baz
                            πŸ˜†
                              Final.
                              http://farm8.staticflickr.com/7196/6867171161_bf035f371c_z.jpg
                                Sublime πŸ‘
                                • 2 / 3
