    I invite for acquaintance with Russian plug-in
    77 Posts 18 Posters 28.6k Views 18 Watching
    • bigstickB Offline
      bigstick
      This looks amazing!
      • yad2000Y Offline
        yad2000
        Posted Demo YouTube video
        CoolPipe Plugin
        • halroachH Offline
          halroach
          Wow!
          Very nice plugin indeed!
          I noticed in incorporates all kinds of round pipe standards. Does it also support profiles like I and U... like in Profile Builder?
          Are you working on an English version? 😄
          FlexTools - Super Quick Windows, Doors, Slats...
          • yad2000Y Offline
            yad2000
            Good day! I am glad that the plug-like. While the plug-in supports only the pipes and taps, the profiles are not supported. The English version will be developed later, when the ideas will be fully realized (native language). Everything is just beginning - the next version will appear: transitions, tees, flanges, plugs. It also will be able to define their own norms and standards.
            Thanks to all who follow the updates.
            CoolPipe Plugin
            • irwanwrI Offline
              irwanwr
              👍 good to know that comrade
              • yad2000Y Offline
                yad2000
                @irwanwr said:
                :thumb: good to know that comrade
                what you had in mind 😒
                CoolPipe Plugin
                • irwanwrI Offline
                  irwanwr
                  if the plugin will be available in English version and shared here too.
                  if it is true.
                  • yad2000Y Offline
                    yad2000
                    if it is true.
                    this is true, but it will probably not soon. Will take some time to create a fully functional version of the native language, only then do the translation. It is possible I will ask for help - if you do not mind
                    CoolPipe Plugin
                    • halroachH Offline
                      halroach
                      It would be nice to have in addition to the standard diameters an option for user defined diameters, either that the user adds his own diameters or his own library, or a simple type at the keyboard, just like when you draw a simple circle.
                      "Profile builder" has a nice interface for adding user defined shapes, and has the ability to add whole standard libraries.
                      Nice Work! I just showed your plugin at work to a Russian speaking fellow worker and he's already sending links to friends of his, who may find your plugin very useful... 👍
                      • yad2000Y Offline
                        yad2000
                        Ability to edit a list of items will be in the next version. Now just working on a new interface that will provide such opportunities. The new version will have several elements of drawing, the announcement of the new version features expected in 2-3 months
                        CoolPipe Plugin
                        • yad2000Y Offline
                          yad2000
                          See the next version
                          http://coolpipe.ru/ToolBar_foto.jpg
                          #-Changes in the structure of the database elements
                          #-Drawing and editing lines
                          #-Drawing and editing taps
                          #-Drawing and editing transitions
                          Drawing and editing-tees
                          Drawing-caps
                          Drawing-flange
                          Create spec-
                          #-Copy function properties (layer / material) for the objects and groups CoolPipe
                          CoolPipe Plugin
                            jorge2011
                            thanks for the update. very interesting.
                            a query:
                            The plugin generates the following error:
                            Error: # <ArgumentError: Not enough-at least 3 edges required>
                            C 😕 Program Files / Google / Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb: 552: in add_face ' C :/ Program Files / Google / Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb: 552: in cp_create_pipe_geometry '
                            C 😕 Program Files / Google / Google SketchUp 8/Plugins/CoolPipe/PipeTool.rb: 110: in `OnLButtonDown '
                            you can fix that? thank you very much
                              driven
                              hi,
                              it looks great but doesn't run on mac.
                              what does the .dll and .so contain, is there a mac equivalent?
                              • yad2000Y Offline
                                yad2000
                                a query:
                                What are you trying to do when there was this error?
                                @driven said:
                                hi,
                                . dll and. so standard libraries contain Iconv, to work with different encodings. The plugin was created for the Russian language for Windows, unfortunately for MAC to configure the plugin I have no technical ability (I hope to understand.)
                                Iconv needed to process W-1251 encoding in UTF from time to time by the return webdialog
                                CoolPipe Plugin
                                  jorge2011
                                  try to draw a pipe, and just draw a vertical line and generates the error
                                  • yad2000Y Offline
                                    yad2000
                                    very strange ...
                                    probably something with the settings of the sketchup
                                    or platform
                                    or something else))
                                    CoolPipe Plugin
                                    • yorik1984Y Offline
                                      yorik1984
                                      I tested plugin. If you have in your plugin directory this plugin:
                                      http://forums.sketchucation.com/viewtopic.php?t=41840
                                      http://rhin.crai.archi.fr/rld/plugin_details.php?id=219
                                      SU shutdown with error!
                                      • yad2000Y Offline
                                        yad2000
                                        plug-in works correctly on a 32 - x bit Windows, sometimes there is an incompatibility with some third-party plug-ins
                                        CoolPipe Plugin
                                          driven
                                          I had to change all the Sketchup:: require'' to require '' to return true and see the Toolbar.
                                          If I comment out all 'Iconv' references in all the files, Webkit on mac appears to handle the Cyrillic encoding without any issues.
                                          Is
                                          <script type="text/javascript" src="js/documets_pack.js"></script>
                                          still needed? I get an error.
                                          If I change ini.rb to "Lang=en", on start I get a message box Did not load RB script&#058; /Library/Application Support/Google SketchUp 8/SketchUp/plugins/CoolPipe/coolpipe_Start.rb
                                          if I start with Lang=ru and then change ini.rb and reload, I get
                                          Error: #<TypeError: /Library/Application Support/Google SketchUp 8/SketchUp/plugins/CoolPipe/coolpipe_Start.rb:81:inadd_item': can't convert nil into String>`
                                          I can't get much further without English, but will keep trying.
                                          • Dan RathbunD Offline
                                            Dan Rathbun
                                            OMG! WHAT A PIECE OF CRAP.
                                            Denis .. you MUST wrap all your code inside a module.
                                            You are defining class veriables and all your methods within Object, and they propagate into everyone else's classes and modules.
                                            I do not recommend anyone use this plugin until it is fixed, and properly module wrapped !!
                                            I'm not here much anymore.
                                            • 1 / 4
