    I invite for acquaintance with Russian plug-in
    77 Posts 18 Posters 26.7k Views 18 Watching
    • yad2000Y Offline
      yad2000
      It would be nice to have in addition to the standard diameters an option for user defined diameters, either that the user adds his own diameters or his own library, or a simple type at the keyboard, just like when you draw a simple circle.
      "Profile builder" has a nice interface for adding user defined shapes, and has the ability to add whole standard libraries.
      Nice Work! I just showed your plugin at work to a Russian speaking fellow worker and he's already sending links to friends of his, who may find your plugin very useful... πŸ‘
      Ability to edit a list of items will be in the next version. Now just working on a new interface that will provide such opportunities. The new version will have several elements of drawing, the announcement of the new version features expected in 2-3 months
      CoolPipe Plugin
      • yad2000Y Offline
        yad2000
        See the next version
        http://coolpipe.ru/ToolBar_foto.jpg
        #-Changes in the structure of the database elements
        #-Drawing and editing lines
        #-Drawing and editing taps
        #-Drawing and editing transitions
        Drawing and editing-tees
        Drawing-caps
        Drawing-flange
        Create spec-
        #-Copy function properties (layer / material) for the objects and groups CoolPipe
        CoolPipe Plugin
          jorge2011
          thanks for the update. very interesting.
          a query:
          The plugin generates the following error:
          Error: # <ArgumentError: Not enough-at least 3 edges required>
          C πŸ˜• Program Files / Google / Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb: 552: in add_face ' C :/ Program Files / Google / Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb: 552: in cp_create_pipe_geometry '
          C πŸ˜• Program Files / Google / Google SketchUp 8/Plugins/CoolPipe/PipeTool.rb: 110: in `OnLButtonDown '
          you can fix that? thank you very much
            driven
            hi,
            it looks great but doesn't run on mac.
            what does the .dll and .so contain, is there a mac equivalent?
            • yad2000Y Offline
              yad2000
              a query:
              What are you trying to do when there was this error?
              @driven said:
              hi,
              . dll and. so standard libraries contain Iconv, to work with different encodings. The plugin was created for the Russian language for Windows, unfortunately for MAC to configure the plugin I have no technical ability (I hope to understand.)
              Iconv needed to process W-1251 encoding in UTF from time to time by the return webdialog
              CoolPipe Plugin
                jorge2011
                try to draw a pipe, and just draw a vertical line and generates the error
                • yad2000Y Offline
                  yad2000
                  very strange ...
                  probably something with the settings of the sketchup
                  or platform
                  or something else))
                  CoolPipe Plugin
                  • yorik1984Y Offline
                    yorik1984
                    I tested plugin. If you have in your plugin directory this plugin:
                    http://forums.sketchucation.com/viewtopic.php?t=41840
                    http://rhin.crai.archi.fr/rld/plugin_details.php?id=219
                    SU shutdown with error!
                    • yad2000Y Offline
                      yad2000
                      plug-in works correctly on a 32 - x bit Windows, sometimes there is an incompatibility with some third-party plug-ins
                      CoolPipe Plugin
                        driven
                        I had to change all the Sketchup:: require'' to require '' to return true and see the Toolbar.
                        If I comment out all 'Iconv' references in all the files, Webkit on mac appears to handle the Cyrillic encoding without any issues.
                        Is
                        <script type="text/javascript" src="js/documets_pack.js"></script>
                        still needed? I get an error.
                        If I change ini.rb to "Lang=en", on start I get a message box Did not load RB script&#058; /Library/Application Support/Google SketchUp 8/SketchUp/plugins/CoolPipe/coolpipe_Start.rb
                        if I start with Lang=ru and then change ini.rb and reload, I get
                        Error: #<TypeError: /Library/Application Support/Google SketchUp 8/SketchUp/plugins/CoolPipe/coolpipe_Start.rb:81:inadd_item': can't convert nil into String>`
                        I can't get much further without English, but will keep trying.
                        • Dan RathbunD Offline
                          Dan Rathbun
                          OMG! WHAT A PIECE OF CRAP.
                          Denis .. you MUST wrap all your code inside a module.
                          You are defining class veriables and all your methods within Object, and they propagate into everyone else's classes and modules.
                          I do not recommend anyone use this plugin until it is fixed, and properly module wrapped !!
                          I'm not here much anymore.
                            Dan Rathbun
                            WARNING !!
                            This "plugin" (term used loosely,) does very bad things to SketchUp's Ruby environment !
                            It includes Math module into Object, which will propagate into EVERYTHING else.
                            Also it modifies Integer, Float and Fixnum baseclases, by including Math (again), and defining plugin specific methods (that are not really needed anyway.)
                            • yad2000Y Offline
                              yad2000
                              @driven said:
                              Is
                              Work on the multi-language version is started, the news wrote about this on your site. Much more needs to be done (not without some help users of course).
                              The plugin is provided as is and use it to recommend your own risk.
                              @dan rathbun said:
                              OMG! WHAT A PIECE OF CRAP......
                              Please calm down!
                              I am not a programmer proffessionalny Ruby, do what learned.
                              I do not claim to uniqueness and correctness of their decisions. Your comment will take into consideration and try to make changes with the next version.
                              As the saying goes do not like do not eat, and you should not call all the crap.
                              CoolPipe Plugin
                              • yad2000Y Offline
                                yad2000
                                #-v1.2.1
                                Multi-project choice of language in the process of working with the plugin
                                Calculation of the mass-removal (steel), raschityvatesya of geometrical parameters (may not fit with factory products)
                                #-The structure of the code changes: there is no change in the standard classes, all of the code integrated into classes and modules
                                #-correction made for loading iconv.so: The MAC does not load, only on Windows
                                edit-elements located outside the Observer in the allocation of a separate command button
                                #-fixed principle of sorting elements of the standard specification. sort (to avoid memory leaks in the process of counting and hangs SketchUP)
                                CoolPipe Plugin
                                  jorge2011
                                  thanks for the update. But still generates the same error, when using the tool "tube":
                                  Error: #<ArgumentError: Not enough edges - at least 3 required>
                                  C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:569:in add_face' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:569:in cp_create_pipe_geometry'
                                  C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/PipeTool.rb:110:in `onLButtonDown'
                                  C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:247
                                  you can fix it?
                                  I use:
                                  windows xp in Spanish
                                  sketchup 8 pro in Spanish
                                  • kenK Offline
                                    ken
                                    I receive the following error code after installing.
                                    Thanks you in advance for your help.
                                    Ken
                                      jorge2011
                                      Ken
                                      You must copy the file "iconv.so" in the folder:
                                      windows/system32
                                      • kenK Offline
                                        ken
                                        Jorge
                                        Will thanks for the advice, however I still have the same error code.
                                        Ken
                                        • guanjinG Offline
                                          guanjin
                                          Site not open
                                          • yad2000Y Offline
                                            yad2000
                                            you can fix it?
                                            I use:
                                            hmm ...
                                            very strange ...
                                            I was not able to repeat that mistake, I can recommend:
                                            Line number 569 is:
                                            face = entities.add_face circle
                                            Try replacing the line number 557:
                                            circle = entities.add_circle pt1, vecbegin, radius, numsegs
                                            on the line
                                            circle = entities.add_circle pt1, vecbegin, radius, 24
                                            or if not, then the line
                                            language is not involved, but rather a problem of API in your version of SketchUP, although the design:
                                            works with the version of SketchUp 6.0+, can you have an earlier version, not 8.0 PRO? in a previous version of the plug CoolPipe 1.2.0 you have the same problem was, nobody else it is not repeated
                                            CoolPipe Plugin
                                            • 2 / 4
