    I invite for acquaintance with Russian plug-in
    77 Posts 18 Posters 26.7k Views 18 Watching
    • yad2000Y Offline
      yad2000
      Good day! I am glad that the plug-like. While the plug-in supports only the pipes and taps, the profiles are not supported. The English version will be developed later, when the ideas will be fully realized (native language). Everything is just beginning - the next version will appear: transitions, tees, flanges, plugs. It also will be able to define their own norms and standards.
      Thanks to all who follow the updates.
      CoolPipe Plugin
      • irwanwrI Offline
        irwanwr
        ๐Ÿ‘ good to know that comrade
        • yad2000Y Offline
          yad2000
          @irwanwr said:
          :thumb: good to know that comrade
          what you had in mind ๐Ÿ˜’
          CoolPipe Plugin
          • irwanwrI Offline
            irwanwr
            if the plugin will be available in English version and shared here too.
            if it is true.
            • yad2000Y Offline
              yad2000
              if it is true.
              this is true, but it will probably not soon. Will take some time to create a fully functional version of the native language, only then do the translation. It is possible I will ask for help - if you do not mind
              CoolPipe Plugin
              • halroachH Offline
                halroach
                It would be nice to have in addition to the standard diameters an option for user defined diameters, either that the user adds his own diameters or his own library, or a simple type at the keyboard, just like when you draw a simple circle.
                "Profile builder" has a nice interface for adding user defined shapes, and has the ability to add whole standard libraries.
                Nice Work! I just showed your plugin at work to a Russian speaking fellow worker and he's already sending links to friends of his, who may find your plugin very useful... ๐Ÿ‘
                FlexTools - Super Quick Windows, Doors, Slats...
                • yad2000Y Offline
                  yad2000
                  Ability to edit a list of items will be in the next version. Now just working on a new interface that will provide such opportunities. The new version will have several elements of drawing, the announcement of the new version features expected in 2-3 months
                  CoolPipe Plugin
                  • yad2000Y Offline
                    yad2000
                    See the next version
                    http://coolpipe.ru/ToolBar_foto.jpg
                    #-Changes in the structure of the database elements
                    #-Drawing and editing lines
                    #-Drawing and editing taps
                    #-Drawing and editing transitions
                    Drawing and editing-tees
                    Drawing-caps
                    Drawing-flange
                    Create spec-
                    #-Copy function properties (layer / material) for the objects and groups CoolPipe
                    CoolPipe Plugin
                      jorge2011
                      thanks for the update. very interesting.
                      a query:
                      The plugin generates the following error:
                      Error: # <ArgumentError: Not enough-at least 3 edges required>
                      C ๐Ÿ˜• Program Files / Google / Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb: 552: in add_face ' C :/ Program Files / Google / Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb: 552: in cp_create_pipe_geometry '
                      C ๐Ÿ˜• Program Files / Google / Google SketchUp 8/Plugins/CoolPipe/PipeTool.rb: 110: in `OnLButtonDown '
                      you can fix that? thank you very much
                        driven
                        hi,
                        it looks great but doesn't run on mac.
                        what does the .dll and .so contain, is there a mac equivalent?
                        • yad2000Y Offline
                          yad2000
                          a query:
                          What are you trying to do when there was this error?
                          @driven said:
                          hi,
                          . dll and. so standard libraries contain Iconv, to work with different encodings. The plugin was created for the Russian language for Windows, unfortunately for MAC to configure the plugin I have no technical ability (I hope to understand.)
                          Iconv needed to process W-1251 encoding in UTF from time to time by the return webdialog
                          CoolPipe Plugin
                            jorge2011
                            try to draw a pipe, and just draw a vertical line and generates the error
                            • yad2000Y Offline
                              yad2000
                              very strange ...
                              probably something with the settings of the sketchup
                              or platform
                              or something else))
                              CoolPipe Plugin
                              • yorik1984Y Offline
                                yorik1984
                                I tested plugin. If you have in your plugin directory this plugin:
                                http://forums.sketchucation.com/viewtopic.php?t=41840
                                http://rhin.crai.archi.fr/rld/plugin_details.php?id=219
                                SU shutdown with error!
                                • yad2000Y Offline
                                  yad2000
                                  plug-in works correctly on a 32 - x bit Windows, sometimes there is an incompatibility with some third-party plug-ins
                                  CoolPipe Plugin
                                    driven
                                    I had to change all the Sketchup:: require'' to require '' to return true and see the Toolbar.
                                    If I comment out all 'Iconv' references in all the files, Webkit on mac appears to handle the Cyrillic encoding without any issues.
                                    Is
                                    <script type="text/javascript" src="js/documets_pack.js"></script>
                                    still needed? I get an error.
                                    If I change ini.rb to "Lang=en", on start I get a message box Did not load RB script&#058; /Library/Application Support/Google SketchUp 8/SketchUp/plugins/CoolPipe/coolpipe_Start.rb
                                    if I start with Lang=ru and then change ini.rb and reload, I get
                                    Error: #<TypeError: /Library/Application Support/Google SketchUp 8/SketchUp/plugins/CoolPipe/coolpipe_Start.rb:81:inadd_item': can't convert nil into String>`
                                    I can't get much further without English, but will keep trying.
                                    • Dan RathbunD Offline
                                      Dan Rathbun
                                      OMG! WHAT A PIECE OF CRAP.
                                      Denis .. you MUST wrap all your code inside a module.
                                      You are defining class veriables and all your methods within Object, and they propagate into everyone else's classes and modules.
                                      I do not recommend anyone use this plugin until it is fixed, and properly module wrapped !!
                                      I'm not here much anymore.
                                        Dan Rathbun
                                        WARNING !!
                                        This "plugin" (term used loosely,) does very bad things to SketchUp's Ruby environment !
                                        It includes Math module into Object, which will propagate into EVERYTHING else.
                                        Also it modifies Integer, Float and Fixnum baseclases, by including Math (again), and defining plugin specific methods (that are not really needed anyway.)
                                        • yad2000Y Offline
                                          yad2000
                                          @driven said:
                                          Is
                                          Work on the multi-language version is started, the news wrote about this on your site. Much more needs to be done (not without some help users of course).
                                          The plugin is provided as is and use it to recommend your own risk.
                                          @dan rathbun said:
                                          OMG! WHAT A PIECE OF CRAP......
                                          Please calm down!
                                          I am not a programmer proffessionalny Ruby, do what learned.
                                          I do not claim to uniqueness and correctness of their decisions. Your comment will take into consideration and try to make changes with the next version.
                                          As the saying goes do not like do not eat, and you should not call all the crap.
                                          CoolPipe Plugin
                                          • yad2000Y Offline
                                            yad2000
                                            #-v1.2.1
                                            Multi-project choice of language in the process of working with the plugin
                                            Calculation of the mass-removal (steel), raschityvatesya of geometrical parameters (may not fit with factory products)
                                            #-The structure of the code changes: there is no change in the standard classes, all of the code integrated into classes and modules
                                            #-correction made for loading iconv.so: The MAC does not load, only on Windows
                                            edit-elements located outside the Observer in the allocation of a separate command button
                                            #-fixed principle of sorting elements of the standard specification. sort (to avoid memory leaks in the process of counting and hangs SketchUP)
                                            CoolPipe Plugin
                                            • 1 / 4
