    [Plugin] CleanUp
    974 Posts 217 Posters 861.9k Views 217 Watching
      It's the long dark winter nights... but hang on... thomthom is up near the Arctic Circle 😲
      • PixeroP Offline
        Pixero
        • Y Offline
          yanakhokho
          I'm new here, please: help. I copy the downloaded file (tt_cleanup.rb) to plugin. When i get inti Scetch up (8 pro) a window pops up ERROR LOADING.
            Does it also say what the error is? I mean error loading what?
            Have you also installed the TT_Lib library as it says in the instructions?
            • Y Offline
              yanakhokho
              Yes, I TT_Lib libraries properly installed, but after that I lost the button Plugins from the control panel(including V-ray). After that, I have properly installed other plugins for sketch up, they have successfully copied to the Plugins folder, but when I run the program do not appear (and yes, I restarted the program)))))
              http://www.imagebar.net/out.php/t105394_1.jpg
              EDITED: link TIG... still unreadable !
                That image is unreadable. You can upload image directly to the forum.
                I'm sorry, but I don't understand what you mean by this. "button Plugins" ? What do you mean by "control panel" in SketchUp"?
                This confused me. Have you installed any plugins that has worked? Or does everyone fail?
                Maybe you can post a screenshot of your Plugins folder?
                Here are some general instructions for installing plugins for SketchUp: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
                  @Marek: You're on OSX Lion, right? And do y ou have the latest update to SketchUp? Maintenance Release 2?
                  • Y Offline
                    yanakhokho
                    sorry for my bad english πŸ˜„
                    my problem is that - after the installation tt_library at startup i see a screen with an error(print screen in the attached files). an installed other plugins just not displayed. problem can be solved only after a complete reinstall the program.
                    this is what i see when i start sketchup
                    • Y Offline
                      yanakhokho
                      i can see all my pligins.
                        I suspect you placed the content of the TT_Lib2 folder directly into your plugins folder.
                        See the footprint:
                        Notice the TT_Lib2 folder.
                        I recommend you remove the files from TT_Lib2 and install using my Simple Plugin Installer utility. (Assuming you have the latest update to SketchUp 😎
                          It looks like your Plugins folder might NOT be where it should be in the Sketchup folder - otherwise there would be at least a menu and one or two plugins listed in it ??
                          Where is your Plugins folder?
                          Can you post the full Windows [text] path to it please...
                          You can find this also by copy/paste this into the Ruby Console + <enter>
                          Sketchup.find_support_file("Plugins")
                          It should be something like
                          C:/Program Files/Google/Google SketchUp 8/Plugins
                          Errors Report:
                          Is that the very start of the error messages ?
                          Does it start with #extrusionToolbar.rb ?
                          If so that error [at least] results from there being files missing in the installation or they are not found.
                          So are the files there?
                          Have you extracted all of the files that come with this toolset in the correct way - putting some files in the Plugins folder BUT others must remain inside their subfolder as supplied in the ZIP file...
                          If they appear to be there, then do you have 'full permissions' to read/write/etc to the Plugins folder and it's subfolders ? Otherwise Windows might have placed some files or folder in side-folders to protect you - but it still looks like they are there; if there's a button in the top bars of the Plugins folder window saying something like 'Compatibility Files' that is a sign, click on it.
                          Another thought... I'm guessing that your locale is somewhat exotic, if you have any non-ASCII characters in file-paths used by Ruby this can cause issues...
                          An error loading one script can affect other scripts loading, BUT it might well be that you have multiple errors overlaid here... we can but see...
                          The 'TTerror' looks like an issue loading one of thomthom's libraries ?
                          • Y Offline
                            yanakhokho
                            Thank you very much! You are doing an excellent job!
                            and a special thank you for your patience and quick responses! I will try next time do not be silly!
                              It is working now?
                                AlainBo
                                Hello,
                                When I export my model with LumenRT, it fails because it finds a zero length vector !?!
                                It seems Cleanup cannot find such problem.
                                How to find it?
                                Is it possible to improve cleanUp to take it in account?
                                Alain
                                  Hello,
                                  How to find it?
                                  Alain
                                  Can you provide a sample model?
                                  This zero length vector - is that from an error you get? Can you post the whole error?
                                  It could be that it is a bug in LumenRT's exporter - and not a model problem.
                                    AlainBo
                                    I found the problem, not precisely but it was related to a scene and not to the model.
                                    I did't really understand what caused the bug but it's sure it's not a geometry issue.
                                    Thanks a lot.
                                      tspco
                                      What did I do wrong? I just downloaded and installed cleanup 3.1.9 and latest ttlib 2.6 I open the model and run the plugin, The screen goes gray, and a long gray box appears with no options to select from. The ttlib file goes into the compatibility files folder, I think that is the problem. I cannot move in back into the regular plugins folder
                                      SU make 2017, /Twilight Render Hobby
                                      Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
                                        tspco
                                        I read back a few pages and found the issue, I now have the tt simple installer, and all "appears" as it was.
                                          Ensure that you have 'full access rights' to the Plugins folder [select its icon Properties > Security ...].
                                          Also do the same for Components, Materials and Styles...
                                          This will stop 'Compatibility Files' issues - where Vista stops you moving files/folders into certain 'program' folders to protect you from yourself if you have limited access rights... With full-rights it should behave...
                                            tspco
                                            I apparently already set permissions for everyone but the creator owner will not change, I am sure it is a windows thing I really don't need to know.
                                            • 36
                                            • 37
                                            • 38
                                            • 39
                                            • 40
                                            • 48
                                            • 49
                                            • 38 / 49
