    Render Question
    42 Posts 9 Posters 4.5k Views 9 Watching
      Your model is placed at the absolute level. Impossible in the real world. I'd raise it 0.1mm off the ground.
      Frederick had a tut on this either on the KT or Thea forum using ceiling lights. He mentioned gaps are necessary to express realism. No objects adhere perfectly unless machined to micron level of tolerances.
      Thats my 2 cents
        Thanks Rich. I thought about moving it up slightly, too. Maybe I need to crank up the bump on the woven texture.
          If you had displacement then you could raise the carpet pile. The bump won't do much for the grounding element. Is your bump grayscale or normal?
          • N Offline
            notareal
            I'd bevel all those sharp edges. That can make a huge difference. Naturally bump and specular maps for materials would help also. Take a look on this basic diffuse specular material http://www.kerkythea.net/phpBB2/viewtopic.php?t=9768
              Thanks guys. when I get back to it, I'll see if I can incorporate that info.
                I think the edges PP'd there do not help on the "realism" front either. (Although I like these mixed styles myself). Look at the bottom left corner where the edge extension adds a visual extra to the box while the shadow is still cast from the "real" corner. That's why it looks floating. Also, what will you do to it when bevelled? doubling those edge lines (or simply using the profile lines only)?
                  It looks like it is floating without the lines, too.
                  Csaba, you know me well enough by now to know that I have no interested in extreme realism in my drawings. If I wanted it to really look like a photograph, I'd be building the real thing and taking a picture of it. πŸ˜‰
                    No, I did not mean that but I suspected that the small edge extension also has a role in it.
                      Well Massimo is lurking so except another viewpoint soon πŸ˜‰
                      I'd like to see it in a nice studio with a HDR lighting and clay output with opacity to 35% and blend to overlay on SU output. I like your Line Styles overlays alot.
                      Anyway, me and Csaba are far from Pro's we just regurgitate very eloquently
                      • massimoM Offline
                        massimo Moderator
                        You're doing well Rich. You have my absolute approval. πŸ‘
                          • massimoM Offline
                            massimo Moderator
                              Put it on the calendar.
                                  MArk down the date that Massimo praised your abilities. πŸ˜‰
                                  • boofredlayB Offline
                                    boofredlay
                                    Well it is 2012 and the world is about to end so anything is possible.
                                    Dave I look forward to seeing your rendering progress.
                                      Thanks Eric,
                                      I've got one cooking now after adding some tiny bevels to the edges and modifying the materials a bit. We'll see what it looks like. My sketchy looking drawings don't take anywhere near this much time to create even including making the line style form scratch.
                                        http://farm8.staticflickr.com/7146/6838558269_992f83ea6b_z.jpg
                                        Still playing with it.
                                          That's massively better. Especially the shadows.
                                          I think sitting on a plain diffuse 75% grey would make you look at the box more.
                                          What did you change?
                                            Thanks Rich.
                                            I put a very tiny bevel on all the edges that would get eased if it was real. The bevel is 1/64" but then the box is only 4" long. I edited the face grain material to give it a slightly golden cast as if it had been varnished. I also made a separate end grain material that I darkened a bit more than the face grain since the end grain would absorb more of the finish.
                                            The box was moved up very slightly so it is actually floating off the ground plane. I exchanged the sun for two spot lights, gave the face grain material a bit of shininess and did the same for the woven background.
                                            You may be right about the flat gray background instead. There's another version cooking. That one only had the lights moved a little bit.
                                            • 1 / 3
