    [Plugin] CleanUp
    974 Posts 217 Posters 833.6k Views 217 Watching
      No, the model looked fine. But the errors are the most bizarre I've ever seen. They make no sense what so ever! 😲 πŸ˜• 😞
      @mp1963 said:
      undefined method `current=' for #Sketchup::Face:0xdcbe564
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/tt_cleanup.rb:564:in `cleanup!'
      Line 564 in the plugin is: model.materials.current = nil Which would imply that model.material are returning a face instead of the model's material list. πŸ˜• 😲 It's crazy!
      And the other errors says when when the script iterate the model entities it's getting vertices and attribute dictionaries... there is no way that should happen.
      Sound like there's some wires getting crossed here - by the SketchUp core itself...
      Could you try, for the sake of it, to reinstall SketchUp? Completely remove the old and try with just CleanUp? (I'm sorry about the awkwardness of doing that, but I really have no idea to what this could be. The old, "reset" and try again is the only thing I can think of.)
      I might try to see if I can grab hold of a Googler and see if they know of any Lion issues.
      I'm baffled...
        mp1963
        Will reinstall Sketchup later on today and let you know what happens.
          mp1963
          Ok, did a complete reinstall of Sketchup Pro. Installed only your Cleanup plugin. Same problems I am afraid 😒
            I need to prod some Google minds on this I'm afraid.
            Is there any other users out there with similar problem?
              mp1963
              Will wait in eager anticipation. If there is anything I can do to help please let me know.
              • PixeroP Offline
                Pixero
                12 january 2012 !! Wow, time travel. 😲
                  mp1963
                  Time travel ?? πŸ˜•
                  • TIGT Online
                    The last update on the 12 January was some days ago; it's now 6 February 2012 ?
                    Jan, are you in a parallel dimension ?
                    πŸ˜•
                      I think Sweden's clocks run about 390 days behind the rest of the world. πŸ˜†
                        Sshhhhh! Let's impress him with all the amazing technology he haven't seen yet!
                        • TIGT Online
                          It's the long dark winter nights... but hang on... thomthom is up near the Arctic Circle 😲
                          • PixeroP Offline
                            Pixero
                            • Y Offline
                              yanakhokho
                              I'm new here, please: help. I copy the downloaded file (tt_cleanup.rb) to plugin. When i get inti Scetch up (8 pro) a window pops up ERROR LOADING.
                                Does it also say what the error is? I mean error loading what?
                                Have you also installed the TT_Lib library as it says in the instructions?
                                • Y Offline
                                  yanakhokho
                                  Yes, I TT_Lib libraries properly installed, but after that I lost the button Plugins from the control panel(including V-ray). After that, I have properly installed other plugins for sketch up, they have successfully copied to the Plugins folder, but when I run the program do not appear (and yes, I restarted the program)))))
                                  http://www.imagebar.net/out.php/t105394_1.jpg
                                  EDITED: link TIG... still unreadable !
                                    That image is unreadable. You can upload image directly to the forum.
                                    I'm sorry, but I don't understand what you mean by this. "button Plugins" ? What do you mean by "control panel" in SketchUp"?
                                    This confused me. Have you installed any plugins that has worked? Or does everyone fail?
                                    Maybe you can post a screenshot of your Plugins folder?
                                    Here are some general instructions for installing plugins for SketchUp: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
                                      @Marek: You're on OSX Lion, right? And do y ou have the latest update to SketchUp? Maintenance Release 2?
                                      • Y Offline
                                        yanakhokho
                                        sorry for my bad english πŸ˜„
                                        my problem is that - after the installation tt_library at startup i see a screen with an error(print screen in the attached files). an installed other plugins just not displayed. problem can be solved only after a complete reinstall the program.
                                        this is what i see when i start sketchup
                                        • Y Offline
                                          yanakhokho
                                          i can see all my pligins.
                                            I suspect you placed the content of the TT_Lib2 folder directly into your plugins folder.
                                            See the footprint:
                                            Notice the TT_Lib2 folder.
                                            I recommend you remove the files from TT_Lib2 and install using my Simple Plugin Installer utility. (Assuming you have the latest update to SketchUp 😎
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 48
                                            • 49
                                            • 34 / 49
