    New project, Advise on layout
    layout
    24 Posts 7 Posters 5.9k Views 7 Watching
    • C
      caronte01
      Hi Saurus, yes, that´s what i´ve been doing for other projects, but usually end up with an out of date model, elevations not matching floor plans etc.... Sketchup is not bim, but i would like to get the advantage of having coordinated plans, sections and elevations without the hassle of going back and forth, and redrawing.
      Mike, your drawings are beautiful, and the projects you work on are very cool. I´ll certainly save a copy of those for inspiration. Do you exchange .dwg with consultants? Or do you send them pdf´s? Any tips?
      I´ve used layout for details, but not yet for an entire project. I´m leaning more on the side of sketchup. I have a couple of weeks to think about this, and will let you know. I´ll try and keep you updated.
      Cheers, and a merry Christmas to all!
      • pbacotP
        What do you mean? Are you leaning towards using SU rather than LO or...?
        You're brave to consider using an untried workflow for a paid project. Look forward to seeing what you come up with.
        These sheets so far LOOK GREAT! (Only I would not use the fat cut-out guys.)
        Peter
          sonder
          I am doing this same thing right now with three home projects. I really like it compared to utilizing sketchup only for design. It certainly eliminates the potential for errors between the formats. I have found that limiting layout files to single pages really increase the speed drastically.
          • C
            caronte01
            Not a lot of progress so far. For now, I´m testing dwg exports from layout. I don´t need them to be perfect, but I do need to have readable files so that external consultants have something to work from. One thing i found is that text export is not perfect as far as formatting goes, so a couple of workarounds have to be used so that dwg output resembles the original pdf/lo file:
            • text exported to dwg will always become an mtext, top left justified. The origin of this text is set to the left upper corner of the text box in layout. So, in layout, try and make the text box as small as possible, to avoid having the text in the wrong place.
            • Text background colors are not exported. An additional box needs to be used to achieve the same effect.
            • Borderless boxes and shapes in layout export as hatches with borders. The workaround is to set the outline the same color as the fill and use the thinnest profile possible.
            This so far. Will keep you updated.
            • T
              thomaselsmore
              caronte01 those plans are really impressive! Amazing work! What style are you using?
              Kind regards,
              Tom
              • C
                caronte01
                Hi Tom,
                here you go...
                PRESENTACION.style
                • C
                  caronte01
                  Hi Sonder. I really like those elevations! How are you achieving the fog effect? Section planes?
                  Are you using hybrid or raster for sketchup views?
                  Thanks for sharing
                    sonder
                    Thanks for sharing
                    The fog is in sketchup saved settings specific to the scene. I use raster rendering, edit quality low, export quality high.
                    • T
                      thomaselsmore
                      @caronte01 said:
                      Hi Tom,
                      here you go...
                      [attachment=0:332x77z6]<!-- ia0 -->PRESENTACION.style<!-- ia0 -->[/attachment:332x77z6]
                      Thank you very much for the style! Keep posting up your work as it is inspiring!
                      Kind regards,
                      Tom
                      • RichardR
                        Richard
                        caronte01 - stunning use of Layout there mate!! VERY well done!
                        BUILTBRAND.COM.AU
                        • C
                          caronte01
                          Thanks Richard!
                          Here's some of the components used for furniture. I like them because they are very simple graphically.
                          BLOQUES.skp
                          Cheers
                          s
                          • C
                            caronte01
                            Quick update.
                            I´ve sent dwg´s to consultants already. They were not the prettiest dwg´s I´ve seen, but they worked.
                            So far, layout has done it´s job perfectly well. That does not mean i´d like to see some improvements.
                            Floorplans:
                            • C
                              caronte01
                              Elevations and sections:
                                sonder
                                Looking beautiful Pablo! Very nice work.
                                • pbacotP
                                  Bellissimo! Go SU + LO! Peter
                                  • RichardR
                                    Richard
                                    Mate these plans are stunning! Really GREAT WORK!
                                    Mate the only thing that I wonder and would love to see a version of - without so much background! There is a relevant graphic term - "make white space your friend!".
                                    BUILTBRAND.COM.AU
                                    • C
                                      caronte01
                                      Thanks guys! I´m now starting details, after that i will return to the main model and update/reference all the changes made.
                                      Richard, I removed the sky from sections and elevations. I like them!
                                      • RichardR
                                        Richard
                                        Yeah me too mate - just cleaner! And more ESD - less ink! 😉 We have to be mindful of contractors writing notes on the plan, often some printers add such gloss to printed areas that the surface doesn't take a pen well. Looks like you still have a background.
                                        Hey you checked tones in greyscale as this is always 99% of printing throughout the job!
                                        BUILTBRAND.COM.AU
                                        • C
                                          caronte01
                                          @richard said:
                                          I did print some elevations in greyscale, to see how they looked. I had to increase contrast a bit. In color, they appeared ok, in bw they looked a bit washed out. Also, elevations looked great with shadows on; sections, I turned them off.
                                            sonder
                                            @caronte01 said:
                                            For BW increase brightness along with contrast at the printer level. I only print my color sets for the permit sets, 1 for the owner and 1 for the contractor. The rest are all BW and look really good with both fog and shadows on. Thankfully my printer has it down now, so I just send over the files and order at will. They are really good at making adjustments and testing before final printing.
