    What happens when....
    71 Posts 14 Posters 5.7k Views 14 Watching
    • GaieusG
      I understand that they do not supply (free) beverages and food and I would even support this on other flights to keep costs lower but charging for the loo is too much. And one loo per plane? What if someone has constipation (or diarrhea)? πŸ˜•
      • Alan FraserA
        Alan Fraser
        Completely OT...but funny anyway.
        [flash=640,390:1uc64bm6]http://www.youtube.com/v/ZAg0lUYHHFc?version=3[/flash:1uc64bm6]
        So back on-topic; ponder what would happen if the moon suddenly disappeared.
        3D Figures
          Oooh, good one!
          Tides would stop?
          • Alan FraserA
            Alan Fraser
            That would be just the start of our problems. It exerts a gyroscopic stabilizing effect.
            3D Figures
              Well, I'd imagine the missing stabilizing effect would cause our orbit to shift, maybe even lose orbit completely. This could mean our rotation is affected which affects everything. Having no tides has a huge wildlife impact.
              You've just wiped us out Alan....well done
              It's an interesting one though as I scurry off to google the answer
                Starling75
                @tig said:
                If you were to go 'off-center' so as to link specific places, then you'll start to 'scrape' down the walls of the tunnel as you fall further in, as the Earth's center of gravity will exert an uneven pull off to the side nearest the 'core'. πŸ€“
                ... and don't forget about conservation of angular momentum.
                If the tunnel is not collinear with Earth axis of rotation, any object falling through the tunnel will be inevitably pushed against wall of the tunnel.
                This effect will be strongest in a tunnel perpendicular to the equator.
                http://www.starlingarch.cz
                  Aerilius
                  Assuming that we are not falling through solid air... πŸ˜„
                  The air pressure should be around 1.88*10^11 bar, that is either super critical or solid, I couldn't figure that out:
                  http://www.wolframalpha.com/input/?i=phase+diagram+of+air
                  • utilerU
                    utiler
                    @mike lucey said:
                    @tig said:
                    I
                    Note: if you were agile enough... on the first 'fall', just as you approached the other end and slowed to a standstill you could 'grapple' onto the tunnel's wall just below the rim, so with a little climbing 'up' you could pop out at the other end... but I suspect you'd be a bit knackered by then [if not dead] !!!
                    πŸ€“
                    There must be easier way to get to Oz 😲
                    Go via Indonesia, guys. There is a huge industry of smugglers taking thousands of refugees from the Middle East to Asia and put them on rickety old boat and send them our way..... they get intercepted by Border Control and sent to Christmas Island [detention Centre] for processing [which by the way costs the Australian tax payer millions each year!] and in time they get bought in the back door.....
                    The previous government had the right idea but when this bloody Labor government came to power they relaxed the policy and HELLO!!!, the boats came a sailin....
                    Just Curious...
                      Everytime I see you talk about Oz politics I'm reminded of this...
                      [flash=600,450:27axgr11]http://www.youtube.com/v/aFV2QYsw9yo[/flash:27axgr11]
                        Speaker
                        How long would it actually take an object to get through? Shouldn't the trajectory be bent a little if you take in account the gravitational force of the moon? If there was a solar eclipse on the other end of the hole, would that be enough to get you through? If one end is in an ocean and the other on land, wouldn't that make a one heck of a whirlpool and a geyser? πŸ˜„
                        http://www.youtube.com/user/latvietis1234
                        • andybotA
                          andybot
                          apparently this is a frictionless medium (considering the speed with which Rich dismissed my answer πŸ˜‰ ) also perfectly aligned to negate rotational forces, etc.
                            Your in my world now where trivial matters like fact are dismissed.
                            What happens when you try to locate the position of the colour grey in 3D space? Is white at 0,0,0?
                            • andybotA
                              andybot
                              grey is a line extending from white to black. 1,1,1; 2,2,2; 3,3,3; etc.
                              • Alan FraserA
                                Alan Fraser
                                Black would be 0,0,0; white would be 255,255,255.
                                3D Figures
                                • chrisglasierC
                                  chrisglasier
                                  The TREMULATION (as prophetised)?
                                    Your viewing colour as a hue, which is something we use to visualise variation.
                                    Your taking the piss but that's expected since this thread is turning into an episode of QI. where's my moon answer?
                                    Your wasting my time as much as I'm wasting yours. You should give this a go....
                                    http://www.wired.com/wired/archive/9.12/aqtest.html
                                    • andybotA
                                      andybot
                                      But grey isn't just one value. Also, having 3 variables implies hue doesn't it? (red green blue I assume) Oh well, we must be talking about different things.
                                        No, you're absolutely right. A recent study has shown 50% grey is located at 0,0,0. It's what happens next that I found interesting.
                                        Since we show colours in hues it easy imagine each hue stacked one on the other to create a cylinder of colour. When colour is actually filling 3D space as a sphere (of sorts).
                                        I was surprised, as Alan's suggestion πŸ˜• of white at 0,0,0 was my initial thought if asked. I was hoping someone had link to the study since I've never seen an image of this color ball.
                                          This is a non-sequitur. A colour is a property of an object and so it has no independent existence - an object can be said to exist in 3d space, a colour might belong to an object, but it cannot be thought of as being in 3d space itself. Used as an abstract concept a 'colour' becomes like 'beauty' or 'width' - and none of these have a physical presence in the real world - only as the property of a real 3d object. So the answer is, 'Nothing happens, as you cannot locate a color in 3d space; and therefore the 'non-change' cannot change its properties.' If you were to change the question to, 'What happens when you try to locate the position of an object that has the colour grey in 3D space? Is white at 0,0,0?', then the answer is also that it's illogical, moving an object does not imply its colour will change - although of course given external influences [not mentioned in the question at all!] like proximity to some other agent like a source of light/heat etc the object's colour may well change depending on its relative location - as it heats up it might glow differently...
                                          On a note of 'convention' - [0,0,0] would normal be thought of as 'black' - i.e. there is no red/green/blue, while 'white' is [255,255,255] using RGB or [1,1,1] OR [100,100,100] using unity/%; because the question does not clarify this issue we can only assume, but there are no common conventions where the absence of colour is 'white'... So an adjunct to the answer could also be, 'There is no logical reason in the framing of the question that suggests that being at a particular 3d coordinate would affect an object's colour, and there is no conventional reasoning to make 'white' as [0,0,0] .'
                                          If you 'corrected' the inversion in the colouring and substituted 'black' for 'white' the first part stands, about 'no reason to suppose location affects colour', but you can omit the second part about 'convention for [0,0,0]'...
                                          πŸ˜•
                                          Stacking coloured objects in space is completely arbitrary - depending on your rules any one of your collection of 'all coloured objects' could be at located [0,0,0] X/Y/Z, irrespective of its actual RGB or any other color-classification system you've adopted. If you then adjust your colour-referencing system to match how you've stacked everything, then you've just invented another reference system, you have NOT found some deep meaningful inter-relationship between these stacked objects and their colours. Whether it's a sphere, a disk, a rectangle, a line, a double-helix, a pyramid etc, and where this collection then stands in 3d space, is determined by the stacker and not by the inherent property of the colours themselves ???
                                          πŸ˜•
                                          • Alan FraserA
                                            Alan Fraser
                                            Solve that problem and you'd probably find God. Grey is 42.
                                            I dug this out on the effect of no moon:-
                                            The first natural phenomenon that would give out is the tides. The sudden disappearance of the moon would completely upend the tidal system. There would still be some movement. Waves would still break on the west sides of continents, due to the rotation of the earth.
                                            Or at least they would at first, since the motion of the earth would become unpredictable. Once the moon kicked out the earth would precess like a top which has spun down enough to wobble, but not topple over. This would be a heck of a wobble. The earth would move so radically that it could sometimes spin perpendicular to the plane of its orbit. In other words, the southern or northern hemisphere would be exposed to the sun at all times, while the other hemisphere would be perpetually dark. At other times, it would spin exactly parallel to the plane of orbit, eliminating the seasons by making all days equally long.
                                            The world-killing precession would take a long time to murder the last of the human race, but in the meantime we'd be entertained by ordinary disasters. The moon exerts gravitational stress on the earth as well as the sea, and some consider it a factor in continental drift. As a result, we might see an uptick in volcano and earthquake activity. Meanwhile, any plants and animals which had their reproduction or migration scheduled tied to the lunar cycle would be completely scrambled. The collapse of fish, bird, and insect populations would put a strain and local ecology and result in starvation and social disintegration.
                                            ......Oh! and it would also be harder to see at night. πŸ˜„
                                            3D Figures
                                            • 3 / 4
