    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    SU 9 Wishlist
    436 Posts 99 Posters 85.7k Views 99 Watching
    • oganocaliO Offline
      oganocali
      My computer is not that bad (i7 2600 with 8 gig ram). In my case it takes over 30 seconds to explode.
      24K faces should be nothing with these computers. This case is complex only by SketchUp standards.
      Apparently SketchUp takes several million instructions per face for the explode operation (for this case).
      I did a quick experimentation varying the size
      face count |  explode time (secs)
           3K        ------|      < 0.5
           6K        ------|         2
           12K       -----|         8
           24K       -----|        30
           48K       -----|          ?
      Admittedly the times are only approximate but seems to me the explode operation has n^2 complexity. Double the size -> quadruple the time (which should be fixable).
        SketchUp also takes longer to add geometry the more geometry already exist in the context its added it.
        I'm guessing that it's due to SketchUp's nature of automatically merge and intersect geometry. This differs from most other 3D modellers where you explicitly needs to tell it to split and merge.
          oganocali
          @thomthom, I would expect the incremental merge/split/intersect cost to increase with increasing size but my suspicion is that incremental cost is linear for SU (whereas it should be sub-linear). Explicit split/merge would be a nice workaround indeed.
          Ogan
            Well I really hope there is room for improvements, because as you say, Explode becomes horribly slow very quickly.
            • onzkiO Offline
              onzki
              My wishlist:
              1. CAD file and Sketchup file XREF feature
              2. CAD import improved.. don't break cad lines please, circles are circles not dodecagons ๐Ÿ˜„
              3. No more Bug Splats
              4. Option to autosave to lower version
              5. Option: to prompt Select layers to show (rest are hidden) when opening of a file. (this option has bypass- just open it, no more prompting)
              6. Ghost / Invisible layer override! I cant think of a name.. but this layer setting temporarily or permanently disables "Snaps" thereby making it behave like an image underlay as long as you want.
              [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
              • john2J Offline
                john2
                whoa.!! long list of wishes. do the google su devloper guys actually read this ๐Ÿ˜ฎ if yes then perhaps they incorporate all this ๐Ÿ˜
                Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 โ€“ 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                  They read it and we even get them to prepare weekly reports on where they are at. ๐Ÿ˜‰
                  • john2J Offline
                    john2
                    wow!! ๐Ÿ˜„ and where are they at now ๐Ÿ˜‰ ? you must be knowing about su 9 release date.
                      SU 12 to be more precise... ๐Ÿ˜‰
                        You're a wicked man Csaba, wicked.
                          Aerilius
                          If SketchUp joined the version number race (Chrome&Mozilla), we would see new versions more often ๐Ÿ˜„
                          • john2J Offline
                            john2
                            just tell me about 9 ๐Ÿ˜‰
                            • TIGT Online
                              Those [if any] who are involved in the beta-testing of new versions of Sketchup, Layout and even other Google Tools [if any], will almost certainly have signed an NDA [Non-Disclosure-Agreement], and therefore they will not even be able to tell you about their involvement in this process, let alone to provide any details of their [limited] knowledge [if any] of potential forthcoming changes that could be anticipated [if any], in these products.
                              ๐Ÿ˜ฒ
                                TIG is right. I was obviously joking with version 12 but even if anyone had any knowledge of what is coming up in version 9, (s)he would not be allowed even to hint that there is a new version around the corner - let alone details of the new features.
                                • TIGT Online
                                  Used my best 'legalese' for Csaba's benefit ๐Ÿ˜‰
                                  โ˜€
                                  PS: Csaba IS [probably] secretly working on "version X" !
                                  I am.
                                  ๐Ÿ˜‰
                                    That version is still in the X Files... ๐Ÿ˜’
                                      andras2
                                      SU9 Would be Great with a built in realSection to be associated with materials. If I use the section tool after I can see the material of the sliced objects something like advanced zorro. and more more BIM BIM BIM BIM ... object list BOM (bills of material).
                                        Bert
                                        Would be nice if when creating a new scene that the insertion pointer switch to the name window for the new scene
                                        Salutations (Best regards) Bert
                                        • fouronethirtyF Offline
                                          fouronethirty
                                          im going to wait for sketchup 9 to come out, hehehe, come on su 9, show us what you got
                                            gistman
                                            As I sit here waiting for SU to finish it's current operation, I've had time to think about signing on and posting a wish... I was wishing it would take advantage of 64bit OS... How hard can that be? It's really really difficult to sit here and watch one core bang away while the other 15 just sit there idle... * sigh *
                                            • 21
                                            • 22
                                            • 2 / 22
