    SU 9 Wishlist
    436 Posts 99 Posters 85.9k Views 99 Watching
      Anton_S
      @dave r said:
      @anton_s said:
      Calculate center of area/volume
      There are tools for that already. Try here, here, here, here...
      The only 'here' I was talking about was the first and the last one...
        dsarchs
        @ thomthom
        Thanks for the correction.
        Knowledge is a polite word for dead but not buried imagination.
        -e.e.cummings
        • oganocaliO Offline
          oganocali
          My list is soo short.
          PERFORMANCE!
          There... I had to shout it aloud. Specifically I wish to be able to explode the silly tiny (ish) attached one component with 24K faces faster than fixing myself a cup of coffee. My guess is if this is fixed scaling rotating, and editing will also speed up.
          performance_problem.skp
            PERFORMANCE!
            But 100s for something this complex seems acceptable to me - my PC is pants too ! ๐Ÿ˜•
              oganocali
              My computer is not that bad (i7 2600 with 8 gig ram). In my case it takes over 30 seconds to explode.
              24K faces should be nothing with these computers. This case is complex only by SketchUp standards.
              Apparently SketchUp takes several million instructions per face for the explode operation (for this case).
              I did a quick experimentation varying the size
              face count |  explode time (secs)
                   3K        ------|      < 0.5
                   6K        ------|         2
                   12K       -----|         8
                   24K       -----|        30
                   48K       -----|          ?
              Admittedly the times are only approximate but seems to me the explode operation has n^2 complexity. Double the size -> quadruple the time (which should be fixable).
                SketchUp also takes longer to add geometry the more geometry already exist in the context its added it.
                I'm guessing that it's due to SketchUp's nature of automatically merge and intersect geometry. This differs from most other 3D modellers where you explicitly needs to tell it to split and merge.
                  oganocali
                  @thomthom, I would expect the incremental merge/split/intersect cost to increase with increasing size but my suspicion is that incremental cost is linear for SU (whereas it should be sub-linear). Explicit split/merge would be a nice workaround indeed.
                  Ogan
                    Well I really hope there is room for improvements, because as you say, Explode becomes horribly slow very quickly.
                    • onzkiO Offline
                      onzki
                      My wishlist:
                      1. CAD file and Sketchup file XREF feature
                      2. CAD import improved.. don't break cad lines please, circles are circles not dodecagons ๐Ÿ˜„
                      3. No more Bug Splats
                      4. Option to autosave to lower version
                      5. Option: to prompt Select layers to show (rest are hidden) when opening of a file. (this option has bypass- just open it, no more prompting)
                      6. Ghost / Invisible layer override! I cant think of a name.. but this layer setting temporarily or permanently disables "Snaps" thereby making it behave like an image underlay as long as you want.
                      [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
                      • john2J Offline
                        john2
                        whoa.!! long list of wishes. do the google su devloper guys actually read this ๐Ÿ˜ฎ if yes then perhaps they incorporate all this ๐Ÿ˜
                        Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 โ€“ 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                          They read it and we even get them to prepare weekly reports on where they are at. ๐Ÿ˜‰
                          • john2J Offline
                            john2
                            wow!! ๐Ÿ˜„ and where are they at now ๐Ÿ˜‰ ? you must be knowing about su 9 release date.
                              SU 12 to be more precise... ๐Ÿ˜‰
                                You're a wicked man Csaba, wicked.
                                  Aerilius
                                  If SketchUp joined the version number race (Chrome&Mozilla), we would see new versions more often ๐Ÿ˜„
                                  • john2J Offline
                                    john2
                                    just tell me about 9 ๐Ÿ˜‰
                                      Those [if any] who are involved in the beta-testing of new versions of Sketchup, Layout and even other Google Tools [if any], will almost certainly have signed an NDA [Non-Disclosure-Agreement], and therefore they will not even be able to tell you about their involvement in this process, let alone to provide any details of their [limited] knowledge [if any] of potential forthcoming changes that could be anticipated [if any], in these products.
                                      ๐Ÿ˜ฒ
                                        TIG is right. I was obviously joking with version 12 but even if anyone had any knowledge of what is coming up in version 9, (s)he would not be allowed even to hint that there is a new version around the corner - let alone details of the new features.
                                          Used my best 'legalese' for Csaba's benefit ๐Ÿ˜‰
                                          โ˜€
                                          PS: Csaba IS [probably] secretly working on "version X" !
                                          I am.
                                          ๐Ÿ˜‰
                                            That version is still in the X Files... ๐Ÿ˜’
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 17 / 22
