    Making tyres in SU
    65 Posts 11 Posters 7.9k Views 11 Watching
    • L
      lecra
      Gaieus,
      @gaieus said:
      Something like this?
      Exactly that! Tell me!
      KR; Lecra
      I'm new to SU but so thirstily to learn all the stuff. Help me fighting against my thirst
      • GaieusG
        Well, here are some steps (it could have been done differently, too - but this was the easiest from an already existing shape you made). The plugin I used can be downloaded here (note that some additional plugin is also needed and read the instructions carefully).
        This is the weakest part of SketchUp and if you want to nicely position some texture on a more complex, curved shape than a simple cylinder, you really need plugins.
        • L
          lecra
          Gaieus,
          Damn! I expected there was a plugin in the game! 😮 But I had to sweat some liter, what?
          In order to draw the 4 edges you have drawn, do I need another plugin?
          Many thanks for the hints until now Gaieus!
          KR; Lecra
          • L
            lecra
            Gaieus,
            [attachment=0:1e0zy92x]<!-- ia0 -->1.png<!-- ia0 -->[/attachment:1e0zy92x]
            Ups. I think I got it. Select the edge and choose the move tool, hit ctrl copy and move the edge. Right?
            KR; Lecra
            • L
              lecra
              Gilles,
              @gilles said:
              Have a look at this if it can help.
              step by step.
              Merci beaucoup! It's also a way but I have issue with the other side. The right side is not parallel to the left one. Maybe due to the texture.
              KR; Lecra
              • GaieusG
                Exactly.
                @lecra said:
                Damn! I expected there was a plugin in the game! But I had to sweat some liter, what?
                Well, one really has to learn the basic tools first. In 90% of the cases, the simplest SU tools are enough - and even faster than tinkering with plugins.
                You could have started with this plugin (to simply map your tyre cylindrically):
                http://forums.sketchucation.com/viewtopic.php?t=10404
                or unwrap and texture nicely with this one:
                http://forums.sketchucation.com/viewtopic.php?t=39442
                or here is a very complex one that can do so many other things, too:
                http://forums.sketchucation.com/viewtopic.php?t=36051
                (there is a free version...)
                • L
                  lecra
                  @Gaieus,
                  Many thanks for your support and tutorial. It works like a charme....
                  Below you can see the results. I'm no looking for tire treads images for agricultural (farm) vehicles.
                  Thanks again. Great help.
                  KR; Lecra
                    driven
                    Looks good, how big/small is your skp now?
                    • L
                      lecra
                      Hi driven,
                      Exactly 504 Kb small/big 😄
                      KR; Lecra
                      • GaieusG
                        Good. What are you rendering it with? It looks like Kerkythea. IMO a little (bit more enhanced?) bumpiness would add to it. Of course, eventually there needs to be some environment or a render to look good (even for the reflections as there needs to be something reflected of course)
                        • GaieusG
                          Good. What are you rendering it with? It looks like Kerkythea. IMO a little (bit more enhanced?) bumpiness would add to it. Of course, eventually there needs to be some environment for a render to look good (even for the reflections as there needs to be something reflected...)
                          • simon le bonS
                            simon le bon
                            Definitely a useful thread with great tips and tricks 👍 😉
                            my quote:
                            This tutorial Making Bump Maps in SKP from CanonFodder000 on Deviant Art
                            http://fc08.deviantart.net/fs71/f/2010/248/e/9/making_bump_maps_in_skp_by_canonfodder000-d2y3poi.png
                            simon
                            • L
                              lecra
                              Gaieus,
                              Nope, Twilight. I have to admit, I was just rendering this image with the default settings. I have absolute no experience with rendering. I try to follow your suggestion learning first dominating SU and then to enter in the big world of rendering. I have to admit, that waiting would make me nervous but in my old age I have to be patient as I cannot learn so fast anymore! 🤣
                              KR; Lecra
                              • L
                                lecra
                                Gaieus,
                                Unfortunately I encountered another challenge with my tires! This kind of tires is slightly curved on his tread as well as the sidewall. This means a lot more of hidden geometry 😳
                                In order to understand how I did this tire: I draw the profile with the arc tool and lines, then revolved with the follow-me tool.
                                I really don't know how to apply the tread texture as well as the sidewall texture to the tire. I suppose that you will again 'do party pieces' taking out one of those wonderful plug-ins 😆
                                Attached my SU file:
                                FlotationTire.skp
                                Any suggestions how to overcome my problem?
                                Many thanks in advance for your great support.
                                KR; Lecra
                                • Alan FraserA
                                  Alan Fraser
                                  Unfortunately, you can't use the method I described for mapping onto a rounded face like that. It will only work on a flat cylindrical face. Even in my example, the shoulders of the tread are not correctly mapped, because they are sloping. Fortunately, they are fairly thin, so you don't really notice. If you round the whole face of the tread, the whole system goes out the window.
                                  You'd need to use some other more sophisticated mapping software, like Ultimate Unwrap 3D, or perhaps try Thomthom's Quadface Tools plugin.
                                  3D Figures
                                  • soloS
                                    I did it in sections, used rotate copy.
                                    FlotationTire.skp
                                    • L
                                      lecra
                                      @solo,
                                      Great!!! Could you explain me step by step what you did? Have you used UV Toolkit2 for that?
                                      Please, please solo, tell me what you did! 😄
                                      KR; Lecra
                                      • L
                                        lecra
                                        Alan,
                                        Thank you for your answer. I had a look to Quadface Tools but as a newbee it is not so easy to apply these tools. I had a look to the movies from thomthom but it sounds for me very strong.
                                        KR; Lecra
                                        • soloS
                                          I create a section, then copy rotate, see images.
                                          • L
                                            lecra
                                            solo,
                                            Thank you for your answer. I got it, but I imagine that you have textured the section in the same way as Alan proposed in this thread, right?
                                            KR; Lecra
                                            • 2 / 4
