    Making tyres in SU
    65 Posts 11 Posters 7.9k Views 11 Watching
    • L
      lecra
      Alan,
      This sentence is not quit clear for me. What do you mean with
      @alan fraser said:
      Hi Lecra,
      Then sample it and paint it onto a face (You need to have hidden geometry showing). Because you have sampled the image itself, not used the material browser, it will paint on in Projected mode and will probably look quite distorted...especially if you paint it onto one of the top faces which are at pretty much rt. angles to the sampled image. No worry, just r-click the face and go to Texture > Position and uncheck the Projected entry. The painted face will correct itself. Now sample that face and paint all the others right around the tyre.
      Could you explain me (noobs) what you mean with 'sample'? I don't understand this technique.
      Sorry to bother you Alan, but this kind of tires building is exactly that was I was searching for months!
      Many thanks in advance for your support!
      KR; Lecra
      I'm new to SU but so thirstily to learn all the stuff. Help me fighting against my thirst
      • Alan FraserA
        Alan Fraser
        Use the Paint tool in conjunction with Alt on any painted surface. It acts like an eye-dropper and samples that texture or colour...ie. loads it ready to paint onto another surface.
        3D Figures
        • L
          lecra
          Alan,
          Finally I got it!! Thank you so much. Now I'm only fighting calculating how big the image should be in order to match!
          Many thanks for your great help!
          KR; Lecra
          • GaieusG
            Look at the image and see how the pattern repeats. Count how many times it could be repeated all around and make the base circle of the same amount of segments. Crop the image accordingly and now you only need to position it on one segment to fully cover it and then you can go around and meet the other side perfectly.
            Once you are done it, we can show easier ways, too but first you must learn it this way as I see in your signature: "I'm new to SU but so thirstily to learn all the stuff. Help me fighting against my thirst".
            • L
              lecra
              Gaieus,
              I got the hint 😳
              Thank you for your tips!
              I'm still thirsty, yes! 😆
              Hope really that you show me an easier way after i learned this stony way.
              I'm there now. The problem that I see now is the rounded shoulder of the tire. Is there a way to make this edge after have textured them a bit rounder?
              KR; Lecra
              • KrisidiousK
                Krisidious
                Lecra is this for rFactor2?
                By: Kristoff Rand
                • L
                  lecra
                  Kris,
                  You mean what kind of game? Farming Simulator 2011.
                  KR; Lecra
                  • KrisidiousK
                    Krisidious
                    I thought you might be modding this game, like I am...
                    By: Kristoff Rand
                    • GaieusG
                      I can't really see where the problem exactly is. Can you attach the wheel (model) itself, too?
                      • L
                        lecra
                        Gaieus,
                        Look at the edges of the tire. I don't know how to round the the edge so that the tire looks realistic and not in the shape of a square (at the end of the texture on the right and left side)!
                        Below the attached file:
                        LecraTyre_2.skp
                        Many thanks for your help Gaieus. Much appreciated.
                        KR; Lecra
                        • GaieusG
                          Something like this?
                          LecraTyre_2.skp
                          • gillesG
                            gilles
                            Have a look at this if it can help.
                            step by step.
                            LecraTyre.skp
                            • L
                              lecra
                              Gaieus,
                              Exactly that! Tell me!
                              KR; Lecra
                              • GaieusG
                                Well, here are some steps (it could have been done differently, too - but this was the easiest from an already existing shape you made). The plugin I used can be downloaded here (note that some additional plugin is also needed and read the instructions carefully).
                                This is the weakest part of SketchUp and if you want to nicely position some texture on a more complex, curved shape than a simple cylinder, you really need plugins.
                                • L
                                  lecra
                                  Gaieus,
                                  Damn! I expected there was a plugin in the game! 😮 But I had to sweat some liter, what?
                                  In order to draw the 4 edges you have drawn, do I need another plugin?
                                  Many thanks for the hints until now Gaieus!
                                  KR; Lecra
                                  • L
                                    lecra
                                    Gaieus,
                                    [attachment=0:1e0zy92x]<!-- ia0 -->1.png<!-- ia0 -->[/attachment:1e0zy92x]
                                    Ups. I think I got it. Select the edge and choose the move tool, hit ctrl copy and move the edge. Right?
                                    KR; Lecra
                                    • L
                                      lecra
                                      Gilles,
                                      step by step.
                                      Merci beaucoup! It's also a way but I have issue with the other side. The right side is not parallel to the left one. Maybe due to the texture.
                                      KR; Lecra
                                      • GaieusG
                                        Exactly.
                                        @lecra said:
                                        Damn! I expected there was a plugin in the game! But I had to sweat some liter, what?
                                        Well, one really has to learn the basic tools first. In 90% of the cases, the simplest SU tools are enough - and even faster than tinkering with plugins.
                                        You could have started with this plugin (to simply map your tyre cylindrically):
                                        http://forums.sketchucation.com/viewtopic.php?t=10404
                                        or unwrap and texture nicely with this one:
                                        http://forums.sketchucation.com/viewtopic.php?t=39442
                                        or here is a very complex one that can do so many other things, too:
                                        http://forums.sketchucation.com/viewtopic.php?t=36051
                                        (there is a free version...)
                                        • L
                                          lecra
                                          @Gaieus,
                                          Many thanks for your support and tutorial. It works like a charme....
                                          Below you can see the results. I'm no looking for tire treads images for agricultural (farm) vehicles.
                                          Thanks again. Great help.
                                          KR; Lecra
                                            driven
                                            Looks good, how big/small is your skp now?
                                            • 1 / 4
