    Making tyres in SU
    65 Posts 11 Posters 5.8k Views 11 Watching
    • Alan FraserA Offline
      Alan Fraser
      There's another relevant thread here.
      3D Figures
        lecra
        Hi Alan,
        Thank you so much for your reply. That's exactly the way I would prefer in order to not blown up the size of the wheel as this is needed on a game environment and we all fight against high poly models.
        Unfortunately I cannot figure out how you have mapped the image on the model. I tried drawing a circle, push-pull out this to the width of the tire (tyre) and then making two other circles with the offset tool. Then I moved the outer circle with the move tool in order to have a small round edge. Mapping then the image as a material on the tire would work but after that I cannot position the picture anymore!!??
        Can you explain me a bit more how to do that? Would be much appreciated from my side as well as for a lot of people modeling for the game community.
        KR; Lecra
        I'm new to SU but so thirstily to learn all the stuff. Help me fighting against my thirst
          Alan Fraser
          Hi Lecra,
          Well, it was a while ago, so I can't guarantee this is the way i did it; but if I was doing it now, I'd do it like this:-
          Work out the circumference of the tyre then use that to determine the length of the image that you import...which will need to be an exact fraction of it. That way, you are not going to end up with a nasty mismatched seam somewhere on the tread. The image was imported as an image, not a texture...then exploded and grouped. It's a personal preference, as I find I can position stuff easier that way.
          Position the image as shown so that it is exactly the width of the tread and shoulder. Then sample it and paint it onto a face (You need to have hidden geometry showing). Because you have sampled the image itself, not used the material browser, it will paint on in Projected mode and will probably look quite distorted...especially if you paint it onto one of the top faces which are at pretty much rt. angles to the sampled image. No worry, just r-click the face and go to Texture > Position and uncheck the Projected entry. The painted face will correct itself. Now sample that face and paint all the others right around the tyre.
          You can use the same technique to put a label on a bottle. The sides of the tyre are just standard grey colour, but you could use a map for that as well, I suppose.
          3D Figures
            lecra
            Alan,
            This sentence is not quit clear for me. What do you mean with
            @alan fraser said:
            Hi Lecra,
            Could you explain me (noobs) what you mean with 'sample'? I don't understand this technique.
            Sorry to bother you Alan, but this kind of tires building is exactly that was I was searching for months!
            Many thanks in advance for your support!
            KR; Lecra
              Alan Fraser
              Use the Paint tool in conjunction with Alt on any painted surface. It acts like an eye-dropper and samples that texture or colour...ie. loads it ready to paint onto another surface.
              3D Figures
                lecra
                Alan,
                Finally I got it!! Thank you so much. Now I'm only fighting calculating how big the image should be in order to match!
                Many thanks for your great help!
                KR; Lecra
                  Look at the image and see how the pattern repeats. Count how many times it could be repeated all around and make the base circle of the same amount of segments. Crop the image accordingly and now you only need to position it on one segment to fully cover it and then you can go around and meet the other side perfectly.
                  Once you are done it, we can show easier ways, too but first you must learn it this way as I see in your signature: "I'm new to SU but so thirstily to learn all the stuff. Help me fighting against my thirst".
                    lecra
                    Gaieus,
                    I got the hint 😳
                    Thank you for your tips!
                    I'm still thirsty, yes! 😆
                    Hope really that you show me an easier way after i learned this stony way.
                    I'm there now. The problem that I see now is the rounded shoulder of the tire. Is there a way to make this edge after have textured them a bit rounder?
                    KR; Lecra
                    • KrisidiousK Offline
                      Krisidious
                      Lecra is this for rFactor2?
                      By: Kristoff Rand
                        lecra
                        Kris,
                        You mean what kind of game? Farming Simulator 2011.
                        KR; Lecra
                          Krisidious
                          I thought you might be modding this game, like I am...
                          By: Kristoff Rand
                            I can't really see where the problem exactly is. Can you attach the wheel (model) itself, too?
                              lecra
                              Gaieus,
                              Look at the edges of the tire. I don't know how to round the the edge so that the tire looks realistic and not in the shape of a square (at the end of the texture on the right and left side)!
                              Below the attached file:
                              LecraTyre_2.skp
                              Many thanks for your help Gaieus. Much appreciated.
                              KR; Lecra
                                Something like this?
                                LecraTyre_2.skp
                                • gillesG Offline
                                  gilles
                                  Have a look at this if it can help.
                                  step by step.
                                  LecraTyre.skp
                                    lecra
                                    Gaieus,
                                    Exactly that! Tell me!
                                    KR; Lecra
                                      Well, here are some steps (it could have been done differently, too - but this was the easiest from an already existing shape you made). The plugin I used can be downloaded here (note that some additional plugin is also needed and read the instructions carefully).
                                      This is the weakest part of SketchUp and if you want to nicely position some texture on a more complex, curved shape than a simple cylinder, you really need plugins.
                                        lecra
                                        Gaieus,
                                        Damn! I expected there was a plugin in the game! 😮 But I had to sweat some liter, what?
                                        In order to draw the 4 edges you have drawn, do I need another plugin?
                                        Many thanks for the hints until now Gaieus!
                                        KR; Lecra
                                          lecra
                                          Gaieus,
                                          [attachment=0:1e0zy92x]<!-- ia0 -->1.png<!-- ia0 -->[/attachment:1e0zy92x]
                                          Ups. I think I got it. Select the edge and choose the move tool, hit ctrl copy and move the edge. Right?
                                          KR; Lecra
                                            lecra
                                            Gilles,
                                            step by step.
                                            Merci beaucoup! It's also a way but I have issue with the other side. The right side is not parallel to the left one. Maybe due to the texture.
                                            KR; Lecra
                                            • 1 / 4
