    Did a God or Gods create the universe? EDITED
    898 Posts 56 Posters 229.3k Views 56 Watching
    • IdahoJI
      IdahoJ
      Maybe you're adding an extra element in here that wasn't expressed well originally. Are you trying to say the two (hypothetical) options are a) eternal separation from God or b) temporary but painful separation from God? I don't quite see how a physical sort of hell with fire necessarily implies the possibility for repentance or escape. That's kind of the problem most people have with it as far as I can tell.
      I believe the "hell" that most people conceive of is the "first death". This place is temporary. It isn't until Rev 20:14, "Then death and Hades were thrown into the lake of fire. The lake of fire is the second death." that Satan, his followers and those of whom Matthew speaks of in verses 12:31-32 "Therefore I say to you, any sin and blasphemy shall be forgiven men, but blasphemy against the Spirit shall not be forgiven. "And whoever shall speak a word against the Son of Man, it shall be forgiven him; but whoever shall speak against the Holy Spirit, it shall not be forgiven him, either in this age, or in the {age} to come." shall be sent for eternity.
      Now, some consider the first "hell" as a place where people can still repent and find God's grace and redemption. It's their last chance. If they don't repent, then they remain in "hell" and are cast into the lake of fire along with Satan and his defeated followers for the "second death". Is the first hell "fire and brimstone", it seems unlikely.
      Here's where some differ about the "second death". That it's not a "fire and brimstone" kind of place, but instead, it is the "outer darkness", where they are cut off for all eternity from God. The prospect of "physical pain and suffering" is not the punishment, but knowing there is no hope of salvation, ever, is the real punishment. One that they brought on themselves and now have to live with it for eternity.
      The arguments for hell NOT to be a "fire and brimstone" kind of place, was due in part, to this rationale: If the "presence" of a person after death is spiritual, then how does the prospect of being in eternal "pain" work? Pain is a physical sensation as far as we know, and it seems unlikely that a spiritual being would be effected.
      Either way, whether one considers a complete separation from God, or a complete separation from God with eternal torment added in, I wouldn't care to find myself there in either case.
      Cheers.
      "For a moment, nothing happened. Then, after a second or so, nothing continued to happen."
        Starling75
        [flash=600,400:18cdke89]http://www.youtube.com/v/icTrzUuWlHI?version=3&amp[/flash:18cdke89]
        [flash=600,400:18cdke89]http://www.youtube.com/v/_teA-EG7Ac0?version=3&amp[/flash:18cdke89]
        http://www.starlingarch.cz
          @tig said:
          Hell is other people...
            Starling75
            http://judaism.about.com/od/judaismbasics/a/jewishbeliefsatan.htm
              "Hell is other people."
              Jean-Paul Sartre
              ["L'enfer, c'est les autres."]
              • C
                cornel
                @solo said:
                I'd like to add the greek word "tartaroos" or tartarus from which Hell is translated in 2 Peter 2:4 which describes the deeps parts of the dark pit where the fallen angels are reserved for punishment. This is the same place the demons in the swine did not want Jesus to sent them; that is, the Abyss. Also, consider a careful study in the same context of 2 Peter and that is 2 Peter 2:9 which places the deceased wicked in the same place as the fallen angels.
                @ ‘Solo’.
                Rebellious angels, incarcerated in Tartarus, have nothing in common with Satan’s angels, who are in ‘freedom’... It is obvious that you have not studied the subject...!
                • C
                  cornel
                  Where 'go' the souls of men to death?
                  Old Testament speaks about Sheol/Hades, and tells us that the souls of the dead go there.
                  "Sheol" should not be confused with the term "grave" (or 'hole'), for which Jews have separate/dedicated term, and only use it when referring to human BODY, such as in these verses: Genesis 5:20, 50:5; Deuteronomy 34:6; Isaia 53:9, etc.
                  The term “Sheol” is distorted in ignorance or deliberately, by some religious groups, as "grave".
                  Read some texts about Sheol, such as those from Job 7:9, Psalm 6:5, 16:8-10, 86:13..., to begin to edify ...!
                  It is easy to notice that like difference between body and soul, so is a distinction between "grave and "Sheol".
                  Even in same verse, for example in Psalm 16:10, respectively : “For You will not leave my soul in Sheol, nor will You allow Your Holy One to see corruption/dissolution” (prophecy, targeting the Messiah), is the distinction between SOUL, which arrives in Sheol, and the body subjected to decay, which reached the grave.
                  Refer to this, both, apostle Peter, in his sermon at Pentecost (Acts 2:27), and apostle Paul, in his sermon (Acts 13:27), held in the synagogue of Antioch of Pisidia.
                  The term "Sheol" comes from Sha'ul/Sha’al which means ‘place of tension’, ‘place of questions’, ‘place of turmoil/of struggles’ ... It originally consisted of two 'compartments':
                  a) Department of the UNSAVED SOULS (unchanged department), which is characterized by terror and suffering, awaiting ‘the Last Judgement’;
                  b) Paradise (moved to Heaven, once the resurrection of Jesus Christ), for the SOULS OF THE FAITFUL, which were "comforted" and waiting to be solved by the redemption plan prepared by God (work already accomplished by Messiah/Jesus Christ).
                  Both, the unsaved souls, and saved souls, do not experience annihilation...!
                  • Alan FraserA
                    Alan Fraser
                    I might be a Norse mythology nerd; (actually it was a unit on my degree course...quite useful for one contemplating historical illustration; I can read runic script too) However, I'm not in the same league with Norse mythology as many people seem to be with Jewish mythology....and there is no difference....they are both mythologies...a colourful illustration of the mindset extant at the time.
                    The single difference is that I recognise the fact that they are both just mythologies, whilst others mistake one for reality. It matters not a jot if that particular mythology 'works' for you. Other mythologies work equally well for millions of others; if they didn't, they wouldn't have lasted. The only reason that the christian mythology replaced the Nordic one is that it is far better suited to civilized living, promising as it does, heaven for the righteous rather than those who die in battle (not a very sensible long-term strategy).
                    Hinduism, on the other hand, has far older roots than christianity. The texts of the Vedas are equally claimed to have been 'revealed'. On that basis, Ganesh the elephant god or Hanuman the monkey god have every bit as much validity as the christian concept of heaven and hell.
                    Theology is fiction. You can't get away from the fact. It doesn't matter how much you have studied ancient texts and wrestled with the precise meaning of words. It doesn't matter how well-reasoned or rational your arguments may seem...be they by historical figures like Thomas Aquinas or modern apologists like William Lane craig...they are all based upon an irrational and utterly unproveable premise...that there is a deity...and what is more, that it's your deity and not the other guy's. It's the ultimate house built on sand.
                    Theology does have its uses. It's an interesting intellectual exercise; and it is a very useful vehicle for the contemplation of moral and ethical questions...as are many other areas of philosophy. But the only 'truth' it reveals is how we can more effectively live as human beings in the company of other human beings. These are the only universal truths it can offer...those concerning the workings of the human mind. It has nothing to do with physical reality.
                    If it turns out that there is a god, then one thing is for sure...he will have very little in common with any of those concocted by the limited imagination of man.
                    3D Figures
                    • andybotA
                      andybot
                      Thanks Alan! I totally agree with this bottom line. Well put. God is a human construct, no matter which way and by which society it gets constructed.
                      • C
                        cornel
                        You are wrong, 'andybot', that is an IDOL...!
                        • brodieB
                          brodie
                          It sounds like you're basically taking this as a given - a sort of a priori truth. If that's indeed your starting point, then that will certainly affect the lens through which you view everything.
                          You seem to be admitting here that no argument, no matter how reasonable and rational could ever sway you. Again, if you're 1st principle is that all theology is fiction, this may make sense. However, I'm not sure I've ever met someone who understands the exact nature of their bias so well and yet persists in it. Am I perhaps misunderstanding what you're saying?
                          If you understand things from my perspective, I believe there's good historical evidence that Jesus was resurrected and go from there. There are side issues which further convince me but this is my central foundation and I don't believe it's sandy at all. It hasn't been the point of this thread so far, but I've yet to hear an alternative that fits the historical facts better than the resurrection.
                          Herm...perhaps I did misunderstand your a priori position?
                          Well, if we're hypothesizing here, wouldn't it be just as valid to suggest that if there's a God, he'd be fully capable of communicating with us? Maybe we couldn't fully understand him but that doesn't mean we couldn't understand him at all.
                          -Brodie
                            😒 EVERY human 'construct' of God is equivalent == an IDOL, [if you will].
                            Cornel,
                            What proof do you have that YOUR VERY OWN SPECIAL VERSION of God is the EXACTLY CORRECT one... and that anybody else's is therefore COMPLETELY WRONG, and invalid? 😒
                            Your only proof is that your scriptures tell you so !
                            It's a circular argument removed from critical investigation.
                            That ISN'T proof - it's assumption !
                            For Christ sake... please, please, get real!!!!!!!!
                            What planet do you live on 😕
                            You are as big an apostate of common-sense, as the atheists are of 'belief' !
                            • IdahoJI
                              IdahoJ
                              http://www.northrim.net/jhouck/images/chill-pill.jpg
                              • Alan FraserA
                                Alan Fraser
                                Theology being fiction is an a priori truth...because that is the default position. Once again, it's not up to rationalists to disprove the existence of god. I can't to do that anymore than I can disprove the existence of any other invisible, magical being. It's the proponent that has to provide the proof, not the other way around.
                                Are you suggesting that Thor and Odin are not fiction?...or Vishnu or Kali, or Zeus, or Xipe Totec the flayed one...or any of the thousands of other deities out there?
                                It's up to theists to prove that theology isn't a fiction by proving the existence of god...their god, specific to their particular theology. If they can't prove it, then everything that follows, however cogent the arguments, is mere speculation and mental exercise. You might as well be discussing the finer points of other mythical constructs, like Star Trek or Tolkien.
                                3D Figures
                                • MarianM
                                  Marian
                                  I'd rather prefer that, it would be much more fun. 😄
                                  • IdahoJI
                                    IdahoJ
                                    I agree with Marian, this thread is about worn out. A Tolkien discussion would be cool ... 😎
                                    Cheers.
                                    • C
                                      cornel
                                      @tig said:
                                      Cornel,
                                      God tells you so: "[Test Me, says the LORD Almighty, and you will see!]"
                                      • pbacotP
                                        Cheers.
                                        Mike just throws these stones in our path to increase the activity in his bar. 💚
                                        • gillesG
                                          gilles
                                          Cornel
                                          What kind of test?
                                          • Mike LuceyM
                                            Mike Lucey
                                            @pbacot said:
                                            Cheers.
                                            Shoooooossshhh! 😉
                                            • 37
                                            • 38
                                            • 39
                                            • 40
                                            • 41
                                            • 44
                                            • 45
                                            • 39 / 45
