    Add_group slow on mac
    48 Posts 7 Posters 22.3k Views 7 Watching
      hm... will have to have a look...
      as for status text: http://forums.sketchucation.com/viewtopic.php?f=180&p=305388#p305248
      • T
        th3lurker
        I've had the same problem. I wrote an import tool for a custom format, and add_group (if i create a group for each volume) or add_face/add_point(if i create just one main group, and keep adding to that) greatly slows down the import. It gets exponentially slower (1.2 secs for 100 volumes, 120 seconds for 1400, 0.02 secods/add_group in the beginning, ~0.2 seconds/add_group near the end). I tested this with the GWD's code, and even without all my other code, it is just as slow. Any ideas/ workarounds? I work on windows vista (not my fault πŸ˜„ ).
          @dan rathbun said:
          >       if PC
          >         Sketchup.send_action(57603)
          >       else # Mac
          >         # may be convoluted on Mac
          >       end
          Why not use Model.save ?
          http://code.google.com/apis/sketchup/docs/ourdoc/model.html#save
          And I don't see how saving would free up the undo stack. ❓ Seems to operate the same after a save...
          I don't think saving has any effect - it's SketchUp that process existing geometry whenever new is added in order for auto-merge to work.
          • Dan RathbunD
            Dan Rathbun
            I was under the impression that the API would not let use use that method to overwrite the current file. But I just tested it and yes, it does work.
            And, your're correct again. (Maybe I made an assumption.) On PC we can clear the undo stack by saving, then asking for a new model, then reloading the old model. (The API does not have a method to close the active model, yet. So it may be a no go on Mac.)
            Here's an updated example:
            model = Sketchup.active_model
            entities = model.entities
            disable_ui = true
            save = true
            if save
              path = UI.savepanel("Save Model to","*.skp")
              if path.nil?
                save = false
              else
                path = File.expand_path(path)
            for n in 1..1000 do
              begin
                model.start_operation("Group#{n}",disable_ui)
                g = entities.add_group
                g.name = n.to_s
                point1 = Geom;;Point3d.new(n*10,0,0)
                c = g.entities.add_cpoint point1
                g.explode
              rescue => e
                model.abort_operation
                puts("Error #<#{e.class.name}; #{e.message}>")
                puts(e.backtrace)
              else
                model.commit_operation
                # opt save model here
                if save
                  Sketchup.active_model.save(path)
                  Sketchup.file_new
                  Sketchup.open_file(path)
            I'm not here much anymore.
            • Dan RathbunD
              Dan Rathbun
              Is it explode that is slow ? Or adding group definitions ?
              If making groups (and explode) is avoided, is it still as slow ?
              Does turning off shadows and textures speed things up ?
                There are issues with model.save.
                It only saves by name, but not path obtained using File from model.path etc.
                It does NOT save by the name of the current SKP, although it returns 'true'...
                To test this make a simple SKP and save it as 'aaa.skp'.
                model=Sketchup.active_model Dir.pwd
                if not where aaa.skp is located use
                Dir.chdir(File.dirname(model.path))
                now use
                model.save("xxx.skp")### it saves a copy as xxx.skp
                you are still inside aaa.rb
                model.save(File.basename(model.path))### saves as itself - aaa.skp [supposedly, as it returns 'true' !]
                Now edit the SKP with a noticeable change, and repeat
                model.save("xxx.skp") model.save(File.basename(model.path))
                Exit without saving further...
                xxx.skp WILL show the changes
                aaa.skp will NOT show the changes, that it said were saved, BUT were not!
                  Both. Adding geometry gets slower and slower in SU. When you explode you take the entities from one context and add it to another - so it suffers from the same slowdown of adding them.
                  It seems to be that SU processes all existing geometry when anything is added to a context.
                  • Dan RathbunD
                    Dan Rathbun
                    Thanks TIG... I knew you had expounded on this subject before.. and tried to get the Google team to fix this save BS.
                    Well, the example above at least DOES clear the undostack on PC...
                    which is why (ThomThom) I originally used the send_action for the PC menu's "Save" option. (Which does work.)
                      ...under Windows only...
                      πŸ˜’ sigh the Ruby API makes my head ache all too often...
                      • Dan RathbunD
                        Dan Rathbun
                        YUP. On PC, Sketchup.send_action("save:") returns false. I wonder what the standard action is for Mac ?
                        Dittos.. on the API.
                          I wish that PolygonMesh had more features in the Ruby API. In the C++ SDK you can define more info when you create the mesh. Under the Ruby API you are more limited.
                          One example, you can retrieve the mesh of any geometry - from that you can get info on hidden/soft edges and UV mapping. But you cannot create a mesh with UV mapping or control hidden/smooth. That severely limits the usability of PolygonMesh as a method of creating geometry.
                          So either complex and very slow geometry creation, or simple and less slow creation.
                          Or use the C++ API - ...which require C++ knowledge... 😞 Slower development...
                          • Dan RathbunD
                            Dan Rathbun
                            Ok.. it's Sketchup.send_action("saveDocument:") (at least it works on PC, and is listed on the Apple site as an action for the NSDocument class.)
                            • Dan RathbunD
                              Dan Rathbun
                              You might try saving the model to a temp file, after each group. That should clear the undo stack.
                              The file must have a name other than "Untitled" or the save dialog will popup.
                              Also use the disable_ui flag in an operation:
                              disable_ui = true
                              PC =( RUBY_PLATFORM =~ /(mswin|mingw)/ ? true ; false )
                              save = true
                              for n in 1..1000 do
                                begin
                                  g.name = n.to_s
                                  g.explode
                                rescue
                                else
                                  if save
                                    if PC
                                    else # Mac
                                      Sketchup.send_action("saveDocument;")
                              • G
                                GWD
                                the Sketchup.send_action("saveDocument:") works on mac!
                                  BUT saveDocument simply saves the current SKP and leaves the undo stack alone.
                                  IF we use
                                  pwd=Dir.pwd Dir.chdir(File.dirname(model.path))
                                  so we don't need to worry about full paths etc...
                                  Then use
                                  ` skp=File.basename(model.path)
                                  tmp=rand.to_s+File.basename(model.path)
                                  model.save(tmp)
                                  Sketchup.open_file(tmp)
                                  Sketchup.open_file(skp)`
                                  on completion tidy up
                                  File.delete(tmp) if File.exist?(tmp) Dir.chdir(pwd)
                                  it will cause the "undo stack" to empty ! 😲
                                  BUT at the expense of the time delay of saving/opening/etc etc...
                                  There seems no easy way to clear the "undo stack" otherwise... πŸ˜•
                                    And we have no signs of "clearing the undo stack" will actually improve the performance of adding geometry, do we?
                                      driven
                                      Was this a query? if so, the answer is yes, normally, but the way Dan has used it in the earlier snippets, the Dialog appears, but fails to change the windows name and the script then really does strange things in 'no mans land'
                                      i.e. it's not 'Untitled Window', or your given name, just 'Sketchup'. The cursor pulses, the view disintegrates[holes appeared] then the whole computer freezes... repeatable, yes but I'll pass.
                                      In my curiosity to learn some ruby, I cobbled together some additional test scripts and ran them on my mac.
                                      Script 1: 1.52668809890747 and generates 2000 undo steps #### this is the original from this thread
                                      Script 2: 0.175029039382935 and generates 1001 undo steps
                                      Script:3: 0.419209957122803 and generates 2 undo steps
                                      Script 4: 0.0664420127868652 and generates 2 undo steps #### this uses disable_ui and draws after the timer stops, so add 0.04 maybe...
                                      My scripts a probably really badly constructed, but they reliably return this similar timings... john
                                      # timer snippet from http://stackoverflow.com/questions/2289381/how-to-time-an-operation-in-milliseconds-in-ruby
                                      def time
                                        now = Time.now.to_f
                                        yield
                                        endd = Time.now.to_f
                                        endd - now
                                      time{
                                      # This code draws a line of points in 1.52668809890747
                                      # and generates 2000 undo steps
                                      for n in 1..1000 do
                                       g.name = n.to_s
                                       point1 = Geom;;Point3d.new(n*1,0,0)
                                       g.explode
                                      def time
                                        now = Time.now.to_f
                                        yield
                                        endd - now
                                      time{
                                      # This code draws a line of points in 0.175029039382935
                                      # and generates 1001 undo steps
                                       entities = model.active_entities
                                       centerpoint = Geom;;Point3d.new
                                       full_group = entities.add_group()
                                       (0..1000).each do |i|
                                       # Create a line of points
                                       centerpoint = [i*1,10,0]
                                       full_group.entities.add_cpoint centerpoint
                                      full_group.explode
                                      def time
                                        now = Time.now.to_f
                                        yield
                                        endd - now
                                      time{
                                      # This code draws a line of points in  0.389806985855103 on mac
                                      # and generates 2 undo steps
                                      require 'sketchup.rb'
                                      require 'LangHandler.rb'
                                      # Using language handler makes sure that the string "Create Line" gets translated.
                                      # This is important as this string is shown in undo menu.
                                      $make_cp_line_string = LanguageHandler.new("gettingstarted.strings");
                                      def cp_line()
                                           selection = model.selection
                                        # Create a transaction so the box is one undo
                                        model.start_operation($make_cp_line_string.GetString("Create cp_Line"))
                                        points_group = entities.add_group()
                                        entities = points_group.entities
                                       centerpoint = [i*1,20,0].to_a
                                       c_pl = points_group.entities.add_cpoint centerpoint
                                       points_group.name = "Points Group"
                                       points_group.description = "Example Group"
                                       selection.add points_group
                                       end #create
                                      cp_line
                                      selection.length
                                      selection.each { |entity| (entity.explode) }
                                      def time
                                        now = Time.now.to_f
                                        yield
                                        endd - now
                                      time{
                                      # This code draws a line of points in 0.0667488574981689 with disable_ui on mac
                                      $make_dcp_line_string = LanguageHandler.new("gettingstarted.strings");
                                      def dcp_line()
                                           disable_ui = true
                                        model.start_operation($make_dcp_line_string.GetString("Create cp_Line"),disable_ui)
                                        dis_pnts_group = entities.add_group()
                                        entities = dis_pnts_group.entities
                                       centerpoint = [i*1,30,0].to_a
                                       dc_pl = dis_pnts_group.entities.add_cpoint centerpoint
                                       dis_pnts_group.name = "Dis Points Group"
                                       dis_pnts_group.description = "Example 2 Group"
                                       selection.add dis_pnts_group
                                       end #create
                                      dcp_line
                                      selection.length
                                      disable_ui = false
                                      • Dan RathbunD
                                        Dan Rathbun
                                        Well, John, you've proved that disable_ui is much faster that not.
                                        But the topic is about that add_group and explode group is slow. Which you've also proved, of course, by testing the same entity generation within only 1 group and then exploding it AFTER the loop.
                                        I only speculated that Sketchup's writing to the Undo stack (and Undo Log file,) might slow things down.
                                        There is a registry entry on PC for "MaxUndo" (under the "Preferences" key,) which is set to 100 by default. There is no UI control to change this "on-the-fly." (And likely Sketchup would not see any change to the attribute while running.) But I wonder if setting it to 0 before startup would it disable the undo feature all together ?? (I don't know what it's called in the Mac plist.)
                                        But, regardless, ThomThom believes that it's not the undo stack, but instead the way the app seems to resort the model database, during add groups and explodes.
                                        What if all the temp groups, were first added to a master group (to separate them from the rest of the model, and then after the loop, the master group was exploded ?)
                                        • Dan RathbunD
                                          Dan Rathbun
                                          I just tried this.. set "MaxUndo" to 0 before SU start.
                                          The undo operations do NOT appear on the Edit menu.
                                          Sketchup still writes to the undo log, but after each tool operation, it writes a "Commit(0)" line.
                                          Changing the attribute back to 100 while Sketchup is running has no effect (as I suspected.) And Sketchup will rewrite it's "live" "MaxUndo" value of 0, back to the registry attribute. So you must change it back to whatever limit you wish, while Sketchup is closed, in order to turn the Undo feature back on.
                                          • Dan RathbunD
                                            Dan Rathbun
                                            Also, note. When "MaxUndo" is 0, calling Sketchup.send_action("editUndo:") still returns true, but nothing happens. (At least it does not BugSplat, which I did fear.)
                                            • 1 / 3
