    Add_group slow on mac
    48 Posts 7 Posters 19.5k Views 7 Watching
      GWD
      I've a script that runs good on my PC. But when my friend uses it on his mac with the same model it's much slower (more than 10x). After a lot of testing to narrowed down the problem, adding a group with add_group on a big model is much slower on mac than on pc. How can we avoid this problem?
        Are you sure it's add_group being slow?
        Are you by any chance also using Sketchup.status_text as well? Updating the progress of your script?
        Do you have a sample script you're testing with?
          GWD
          We use indeed the Sketchup.status_text in our script for updating the progress. But this isn't to problem because the problem also occurs with te following simple script.
          Create a model with 1000 solids and run the following script:
          model = Sketchup.active_model
          entities = model.entities
          for n in 1..1000 do
          g = entities.add_group
          g.name = n.to_s
          point1 = Geom::Point3d.new(n*10,0,0)
          c = g.entities.add_cpoint point1
          g.explode
          On PC this goes fast, on mac this takes a very long time.
            hm... will have to have a look...
            as for status text: http://forums.sketchucation.com/viewtopic.php?f=180&p=305388#p305248
              th3lurker
              I've had the same problem. I wrote an import tool for a custom format, and add_group (if i create a group for each volume) or add_face/add_point(if i create just one main group, and keep adding to that) greatly slows down the import. It gets exponentially slower (1.2 secs for 100 volumes, 120 seconds for 1400, 0.02 secods/add_group in the beginning, ~0.2 seconds/add_group near the end). I tested this with the GWD's code, and even without all my other code, it is just as slow. Any ideas/ workarounds? I work on windows vista (not my fault πŸ˜„ ).
                @dan rathbun said:
                >       if PC
                >         Sketchup.send_action(57603)
                >       else # Mac
                >         # may be convoluted on Mac
                >       end
                Why not use Model.save ?
                http://code.google.com/apis/sketchup/docs/ourdoc/model.html#save
                And I don't see how saving would free up the undo stack. ❓ Seems to operate the same after a save...
                I don't think saving has any effect - it's SketchUp that process existing geometry whenever new is added in order for auto-merge to work.
                • Dan RathbunD Offline
                  Dan Rathbun
                  I was under the impression that the API would not let use use that method to overwrite the current file. But I just tested it and yes, it does work.
                  And, your're correct again. (Maybe I made an assumption.) On PC we can clear the undo stack by saving, then asking for a new model, then reloading the old model. (The API does not have a method to close the active model, yet. So it may be a no go on Mac.)
                  Here's an updated example:
                  disable_ui = true
                  save = true
                  if save
                    path = UI.savepanel("Save Model to","*.skp")
                    if path.nil?
                      save = false
                    else
                      path = File.expand_path(path)
                  for n in 1..1000 do
                    begin
                      model.start_operation("Group#{n}",disable_ui)
                      g.name = n.to_s
                      point1 = Geom;;Point3d.new(n*10,0,0)
                      g.explode
                    rescue => e
                      model.abort_operation
                      puts("Error #<#{e.class.name}; #{e.message}>")
                      puts(e.backtrace)
                    else
                      model.commit_operation
                      # opt save model here
                      if save
                        Sketchup.active_model.save(path)
                        Sketchup.file_new
                        Sketchup.open_file(path)
                  I'm not here much anymore.
                    Dan Rathbun
                    Is it explode that is slow ? Or adding group definitions ?
                    If making groups (and explode) is avoided, is it still as slow ?
                    Does turning off shadows and textures speed things up ?
                    • TIGT Online
                      There are issues with model.save.
                      It only saves by name, but not path obtained using File from model.path etc.
                      It does NOT save by the name of the current SKP, although it returns 'true'...
                      To test this make a simple SKP and save it as 'aaa.skp'.
                      model=Sketchup.active_model Dir.pwd
                      if not where aaa.skp is located use
                      Dir.chdir(File.dirname(model.path))
                      now use
                      model.save("xxx.skp")### it saves a copy as xxx.skp
                      you are still inside aaa.rb
                      model.save(File.basename(model.path))### saves as itself - aaa.skp [supposedly, as it returns 'true' !]
                      Now edit the SKP with a noticeable change, and repeat
                      model.save("xxx.skp") model.save(File.basename(model.path))
                      Exit without saving further...
                      xxx.skp WILL show the changes
                      aaa.skp will NOT show the changes, that it said were saved, BUT were not!
                        Both. Adding geometry gets slower and slower in SU. When you explode you take the entities from one context and add it to another - so it suffers from the same slowdown of adding them.
                        It seems to be that SU processes all existing geometry when anything is added to a context.
                          Dan Rathbun
                          Thanks TIG... I knew you had expounded on this subject before.. and tried to get the Google team to fix this save BS.
                          Well, the example above at least DOES clear the undostack on PC...
                          which is why (ThomThom) I originally used the send_action for the PC menu's "Save" option. (Which does work.)
                            ...under Windows only...
                            πŸ˜’ sigh the Ruby API makes my head ache all too often...
                              Dan Rathbun
                              YUP. On PC, Sketchup.send_action("save:") returns false. I wonder what the standard action is for Mac ?
                              Dittos.. on the API.
                                I wish that PolygonMesh had more features in the Ruby API. In the C++ SDK you can define more info when you create the mesh. Under the Ruby API you are more limited.
                                One example, you can retrieve the mesh of any geometry - from that you can get info on hidden/soft edges and UV mapping. But you cannot create a mesh with UV mapping or control hidden/smooth. That severely limits the usability of PolygonMesh as a method of creating geometry.
                                So either complex and very slow geometry creation, or simple and less slow creation.
                                Or use the C++ API - ...which require C++ knowledge... 😞 Slower development...
                                  Dan Rathbun
                                  Ok.. it's Sketchup.send_action("saveDocument:") (at least it works on PC, and is listed on the Apple site as an action for the NSDocument class.)
                                    Dan Rathbun
                                    You might try saving the model to a temp file, after each group. That should clear the undo stack.
                                    The file must have a name other than "Untitled" or the save dialog will popup.
                                    Also use the disable_ui flag in an operation:
                                    disable_ui = true
                                    PC =( RUBY_PLATFORM =~ /(mswin|mingw)/ ? true ; false )
                                    save = true
                                    for n in 1..1000 do
                                      begin
                                        g.name = n.to_s
                                        g.explode
                                      rescue
                                      else
                                        if save
                                          if PC
                                          else # Mac
                                            Sketchup.send_action("saveDocument;")
                                      GWD
                                      the Sketchup.send_action("saveDocument:") works on mac!
                                      • TIGT Online
                                        BUT saveDocument simply saves the current SKP and leaves the undo stack alone.
                                        IF we use
                                        pwd=Dir.pwd Dir.chdir(File.dirname(model.path))
                                        so we don't need to worry about full paths etc...
                                        Then use
                                        ` skp=File.basename(model.path)
                                        tmp=rand.to_s+File.basename(model.path)
                                        model.save(tmp)
                                        Sketchup.open_file(tmp)
                                        Sketchup.open_file(skp)`
                                        on completion tidy up
                                        File.delete(tmp) if File.exist?(tmp) Dir.chdir(pwd)
                                        it will cause the "undo stack" to empty ! 😲
                                        BUT at the expense of the time delay of saving/opening/etc etc...
                                        There seems no easy way to clear the "undo stack" otherwise... πŸ˜•
                                          And we have no signs of "clearing the undo stack" will actually improve the performance of adding geometry, do we?
                                            driven
                                            Was this a query? if so, the answer is yes, normally, but the way Dan has used it in the earlier snippets, the Dialog appears, but fails to change the windows name and the script then really does strange things in 'no mans land'
                                            i.e. it's not 'Untitled Window', or your given name, just 'Sketchup'. The cursor pulses, the view disintegrates[holes appeared] then the whole computer freezes... repeatable, yes but I'll pass.
                                            In my curiosity to learn some ruby, I cobbled together some additional test scripts and ran them on my mac.
                                            Script 1: 1.52668809890747 and generates 2000 undo steps #### this is the original from this thread
                                            Script 2: 0.175029039382935 and generates 1001 undo steps
                                            Script:3: 0.419209957122803 and generates 2 undo steps
                                            Script 4: 0.0664420127868652 and generates 2 undo steps #### this uses disable_ui and draws after the timer stops, so add 0.04 maybe...
                                            My scripts a probably really badly constructed, but they reliably return this similar timings... john
                                            # timer snippet from http://stackoverflow.com/questions/2289381/how-to-time-an-operation-in-milliseconds-in-ruby
                                            def time
                                              now = Time.now.to_f
                                              yield
                                              endd = Time.now.to_f
                                              endd - now
                                            time{
                                            # This code draws a line of points in 1.52668809890747
                                            # and generates 2000 undo steps
                                            for n in 1..1000 do
                                             g.name = n.to_s
                                             point1 = Geom;;Point3d.new(n*1,0,0)
                                             g.explode
                                            def time
                                              now = Time.now.to_f
                                              yield
                                              endd - now
                                            time{
                                            # This code draws a line of points in 0.175029039382935
                                            # and generates 1001 undo steps
                                             entities = model.active_entities
                                             centerpoint = Geom;;Point3d.new
                                             full_group = entities.add_group()
                                             (0..1000).each do |i|
                                             # Create a line of points
                                             centerpoint = [i*1,10,0]
                                             full_group.entities.add_cpoint centerpoint
                                            full_group.explode
                                            def time
                                              now = Time.now.to_f
                                              yield
                                              endd - now
                                            time{
                                            # This code draws a line of points in  0.389806985855103 on mac
                                            # and generates 2 undo steps
                                            require 'sketchup.rb'
                                            require 'LangHandler.rb'
                                            # Using language handler makes sure that the string "Create Line" gets translated.
                                            # This is important as this string is shown in undo menu.
                                            $make_cp_line_string = LanguageHandler.new("gettingstarted.strings");
                                            def cp_line()
                                                 selection = model.selection
                                              # Create a transaction so the box is one undo
                                              model.start_operation($make_cp_line_string.GetString("Create cp_Line"))
                                              points_group = entities.add_group()
                                              entities = points_group.entities
                                             centerpoint = [i*1,20,0].to_a
                                             c_pl = points_group.entities.add_cpoint centerpoint
                                             points_group.name = "Points Group"
                                             points_group.description = "Example Group"
                                             selection.add points_group
                                             end #create
                                            cp_line
                                            selection.length
                                            selection.each { |entity| (entity.explode) }
                                            def time
                                              now = Time.now.to_f
                                              yield
                                              endd - now
                                            time{
                                            # This code draws a line of points in 0.0667488574981689 with disable_ui on mac
                                            $make_dcp_line_string = LanguageHandler.new("gettingstarted.strings");
                                            def dcp_line()
                                                 disable_ui = true
                                              model.start_operation($make_dcp_line_string.GetString("Create cp_Line"),disable_ui)
                                              dis_pnts_group = entities.add_group()
                                              entities = dis_pnts_group.entities
                                             centerpoint = [i*1,30,0].to_a
                                             dc_pl = dis_pnts_group.entities.add_cpoint centerpoint
                                             dis_pnts_group.name = "Dis Points Group"
                                             dis_pnts_group.description = "Example 2 Group"
                                             selection.add dis_pnts_group
                                             end #create
                                            dcp_line
                                            selection.length
                                            disable_ui = false
                                            • 1 / 3
