    Huh? Units? WTH?
    4 Posts 3 Posters 339 Views 3 Watching
    • I
      installtechireland
      So, I have this code:
      def create_entities(data, container)
      a = data["a"].to_l
      w = data["w"].to_l
      h = data["h"].to_l
      pts = [[0,0,0], [a,0,0], [a,w,0], [0,w,0], [0,0,0]]
      base = container.add_face pts
      Obviously, that's not the whole thing. It makes a box eventually, based on the points defined above.
      Now, I want to alter the box to mae one side shorter than the other.
      The default Length "a" is 1000mm. When I replace point [a,0,0] with [a-20,0,0] I get a weird result. I expect a-20 to be 980mm, but I end up with a side that is 492mm, which implies Sketchup is taking off 20 inches, not mm. How do I tell it to read all units as mm? I am using the Engineering (mm) template if that makes any difference.
      Any help appreciated.
      Regards,
      Cathal
        If ' a' is in mm and you use a-20 you are taking of 20" !
        Use a-20.mm πŸ˜’
        Raw numbers are assumed to be in inches ALWAYS!
          Make use of the Length class, and the extended method of String and Numberic to let SU handle the units. Remember that SU uses inches internally at all time. Units are presented to the user in the correct format using the assisting methods.
          Length class: http://code.google.com/apis/sketchup/docs/ourdoc/length.html
          Numeric class: http://code.google.com/apis/sketchup/docs/ourdoc/numeric.html
          String class: http://code.google.com/apis/sketchup/docs/ourdoc/string.html
          Keep track of whether your object is a Float or Length - as that matters when the number is outputted as string to the user.
          • I
            installtechireland
            ah yes. I was using "a-20mm", not "a-20.mm", wondering why it didn't work...
            thanks πŸ˜„
