    [Plugin]$ Keyframe Animation
    150 Posts 39 Posters 148.7k Views 39 Watching
    • iichiversiiI
      iichiversii
      @regular polygon said:
      iichiversii, technically you could do this yourself in version 1.5. But to imply that it is simple to do, and no plugin is necessary to automate the process, is just plain false.
      When the tweens are created for an animation, there are usually 500+ tweens, often over a 1000. Are you really going to go through 1000 scenes and manually adjust the visibility of the layers for each one? Even if you could update one scene every 10 seconds that would still take nearly three hours. You must have a lot more time on your hands than I do. I think most people would consider a script that automates this process to be a new feature. And that is probably why I received so many emails requesting it.
      Im sorry if i offend, i didnt understand the feature fully, normally i do short clips with 30-50 tweens, i adjust my tweens then with layers, doesnt take to much time to do with so little tweens, im a great fan of keyframe_animation, with out it i wouldnt be able to create the animations im doing now, looking forward to the new updates, thank you
      Bring on the Rain...
        Regular Polygon
        Hey iichiversii, thanks for putting things into perspective. I am sorry if I overreacted, which I probably did. I shouldn't write posts at 3 am, I guess. πŸ˜’
        My SketchUp Plugins
        • iichiversiiI
          iichiversii
          lol, no worries,really am a fan of this plugin tho, its fantastic and im constantly mentioning it in my posts, heres a short clip i did using it, im looking forward to the next updates, im having 1 problem tho, my animations bugsplat everytime i animate a componant within a group, may i ask for a tutorial so i can see if im doing something i shouldnt be doing or does this happen alot??? πŸ˜† , please dont over react, πŸ˜†
          [flash=640,480:1amf8kr5]http://www.youtube.com/v/QP1ILu_IWII?version=3&hl=en_US[/flash:1amf8kr5][/quote]
            Regular Polygon
            You should be able to do that. I will PM you with the email address to send me your model so I can look into it.
            My SketchUp Plugins
              Regular Polygon
              @andybot said:
              By the way RP, nice to see added features πŸ‘ Any progress on changing objects' scale? πŸŽ‰
              Now that animating object visibility is out of the way, animating the scale of objects is the new most requested feature. It has moved up to third place on my list of Planned Updates. I hope to knock off the first two items in version 1.7, and release it in January. They are more essential to the basic workflow, so I need to do them first. After that, I will get serious about trying to animate the scale of objects.
              My SketchUp Plugins
              • N
                nickdk
                I'm testing the plugin and it seems very nice! But when i try to create the 'tweens' no scenes are added, what could be wrong? V. 1.6
                the file i'm working on has a ton of sub components and heavy geometry but I read that it shouldn't be a problem anymore?
                I have tried to explode some of the components but it didn't help.
                I tried to create tweens for a simple model and it worked.
                .. OK I tried to explode everything and with 10FPS and 3 sec transitions it worked, but with 25fps and 30sec transitions it failed as before... this is very frustrating
                • iichiversiiI
                  iichiversii
                  On a good note, after PM with Regular Polygon i was directed in the right way on issues i had with keyframe_Animation and sub componants can be animated in a parent group/componant with simply highlighting the subcomponant within the parent group/componant and recording the subcomponant, and then recording the parent componant in the same scene, thank you Regular Polygon for your instructions, remember i never doubted you Doug πŸ˜„
                    Regular Polygon
                    Thanks for clearing that up iichiversii. πŸ‘
                    I changed the workflow for subcomponents in version 1.5. Now, you have to open the parent component/group for editing by double-clicking on it. Then click the record button while the parent component is open. That records the position data for all the subcomponents.
                    It is not really any extra work, because you have to open the parent component in the first place to position the subcomponent. So, just click the record button at that time.
                    My SketchUp Plugins
                      Regular Polygon
                      The best way to reach me for support is at the email listed here on the Contact page. I don't check this forum every day, but I do check my email quite often. If your model is less than 25 MB, you can send it to that email address and I will check it out for any bugs.
                      My SketchUp Plugins
                      • fouronethirtyF
                        fouronethirty
                        can't export section animation
                          Regular Polygon
                          That is true. But I never claimed you could. The only scene properties that can be exported are camera location and visible layers. The other ones may be supported in the future. Section planes are currently fourth on the list of planned updates.
                          My SketchUp Plugins
                          • emerald15E
                            emerald15
                            I've posted this problem separately, but though it might find more attention here.
                            http://forums.sketchucation.com/viewtopic.php?f=79&t=42931
                            Love using keyframe Animation, but can't figure this problem out.
                            • utilerU
                              utiler
                              Just bought this plugin, Regular_Polygon; I have been meaning too for a while..... πŸ‘
                              I use your other plugins quite a lot so I feel I should contribute!!
                              Just Curious...
                                Regular Polygon
                                Thank you! πŸ‘ πŸ˜„
                                My SketchUp Plugins
                                  Regular Polygon
                                  Hi emerald15,
                                  Trying to animate two folding doors is an interesting problem. The door on the right just rotates about its right edge, so that is easy to animate. But the other door, to the left, moves in a way that is neither a simple rotation, or translation. However, it is possible to represent this motion using animated subcomponents. When you animate a subcomponent (subgroup), it moves relative to the parent. So, the combined motion can be something more complex than a translation or rotation.
                                  First, clear/delete any position data you have recorded for the doors. Then make a group out of the two doors, so each door is a subgroup. The basic idea is, you rotate the left door about the hing through some angle less than 180 degrees. At the same time, you rotate the entire two door group about the right edge through an angle of 90 degrees. The combined motion causes the doors to fold together exactly like they do in real life.
                                  I am sure that a video would explain this much better than words. I hope to make some tutorials in the near future. If it isn't clear, you can just email me your model, and I can quickly set up the animation, and send it back to you.
                                  My SketchUp Plugins
                                  • emerald15E
                                    emerald15
                                    Thanks Regular Polygon.
                                    As per e-mail, I followed instructions but failed. Here is the skp file if you would kindly help. Thank again.
                                    folding doors 2.skp
                                      Regular Polygon
                                      No problem, I think I have those folding doors moving correctly. I made the doors subcomponents of a group. To create the folding motion, both the doors, and the parent group, rotate at the same time. Here is your model with the animation set up. πŸ€“
                                      Animated Folding Doors
                                      And, for anyone wondering what it looks like, I exported the animation.
                                      [flash=480,274:3xeqywwp]http://www.youtube.com/v/D2wmqRcHoyA?version=3&hl=en_US&rel=0[/flash:3xeqywwp]
                                      Thanks for sharing your model, Emerald15. πŸ‘
                                      I think this is a good example of how animated sub-components can be used to create more complex types of motion.
                                      My SketchUp Plugins
                                      • emerald15E
                                        emerald15
                                        Thanks so much for this - exactly what I've been trying to do. I'm still working it all out, but now I know it is possible!
                                        • emerald15E
                                          emerald15
                                          Sorry, I must be still missing something.
                                          I have grouped the components/groups into a parent group. I can rotate the far left door and each of the right side doors individually within the group (through selecting them in Outliner). However, when I move the parent group the sequence goes wrong. I've tried various combinations of moving the subgroups & parent group and moving all the subgroups inside the parent group, but I'm not getting the right result.
                                          • andybotA
                                            andybot
                                            does it matter if it's a group or component? Just a thought.
                                            • 6 / 8
