    [Plugin]$ Keyframe Animation
    150 Posts 39 Posters 132.9k Views 39 Watching
    • iichiversiiI Offline
      iichiversii
      Correct me if im wrong but couldnt we do this with version 1.5 , once tweens are created you could turn off/on the layers in each tween and update each tween/scene, i dont understand how version 1.6 is different, is there any new features in 1.6 you can share with us, thank you
      Bring on the Rain...
        Regular Polygon
        iichiversii, technically you could do this yourself in version 1.5. But to imply that it is simple to do, and no plugin is necessary to automate the process, is just plain false.
        When the tweens are created for an animation, there are usually 500+ tweens, often over a 1000. Are you really going to go through 1000 scenes and manually adjust the visibility of the layers for each one? Even if you could update one scene every 10 seconds that would still take nearly three hours. You must have a lot more time on your hands than I do. I think most people would consider a script that automates this process to be a new feature. And that is probably why I received so many emails requesting it.
        My SketchUp Plugins
        • andybotA Offline
          andybot
          @nickdk said:
          What is the status with VRay support? I couldn't locate the ticket at Chaosgroup.
          Regards
          Nick
          Are you asking if vray will render the animations from Keyframe animation? The answer is no because vray loads the model and the views from the initial scene and then renders only that state. No layer or geometry changes will be generated.
          • andybotA Offline
            andybot
            By the way RP, nice to see added features πŸ‘ Any progress on changing objects' scale? πŸŽ‰
              iichiversii
              Im sorry if i offend, i didnt understand the feature fully, normally i do short clips with 30-50 tweens, i adjust my tweens then with layers, doesnt take to much time to do with so little tweens, im a great fan of keyframe_animation, with out it i wouldnt be able to create the animations im doing now, looking forward to the new updates, thank you
                Regular Polygon
                Hey iichiversii, thanks for putting things into perspective. I am sorry if I overreacted, which I probably did. I shouldn't write posts at 3 am, I guess. πŸ˜’
                My SketchUp Plugins
                  iichiversii
                  lol, no worries,really am a fan of this plugin tho, its fantastic and im constantly mentioning it in my posts, heres a short clip i did using it, im looking forward to the next updates, im having 1 problem tho, my animations bugsplat everytime i animate a componant within a group, may i ask for a tutorial so i can see if im doing something i shouldnt be doing or does this happen alot??? πŸ˜† , please dont over react, πŸ˜†
                  [flash=640,480:1amf8kr5]http://www.youtube.com/v/QP1ILu_IWII?version=3&hl=en_US[/flash:1amf8kr5][/quote]
                    Regular Polygon
                    You should be able to do that. I will PM you with the email address to send me your model so I can look into it.
                    My SketchUp Plugins
                      Regular Polygon
                      Now that animating object visibility is out of the way, animating the scale of objects is the new most requested feature. It has moved up to third place on my list of Planned Updates. I hope to knock off the first two items in version 1.7, and release it in January. They are more essential to the basic workflow, so I need to do them first. After that, I will get serious about trying to animate the scale of objects.
                      My SketchUp Plugins
                      • N Offline
                        nickdk
                        I'm testing the plugin and it seems very nice! But when i try to create the 'tweens' no scenes are added, what could be wrong? V. 1.6
                        the file i'm working on has a ton of sub components and heavy geometry but I read that it shouldn't be a problem anymore?
                        I have tried to explode some of the components but it didn't help.
                        I tried to create tweens for a simple model and it worked.
                        .. OK I tried to explode everything and with 10FPS and 3 sec transitions it worked, but with 25fps and 30sec transitions it failed as before... this is very frustrating
                          iichiversii
                          On a good note, after PM with Regular Polygon i was directed in the right way on issues i had with keyframe_Animation and sub componants can be animated in a parent group/componant with simply highlighting the subcomponant within the parent group/componant and recording the subcomponant, and then recording the parent componant in the same scene, thank you Regular Polygon for your instructions, remember i never doubted you Doug πŸ˜„
                            Regular Polygon
                            Thanks for clearing that up iichiversii. πŸ‘
                            I changed the workflow for subcomponents in version 1.5. Now, you have to open the parent component/group for editing by double-clicking on it. Then click the record button while the parent component is open. That records the position data for all the subcomponents.
                            It is not really any extra work, because you have to open the parent component in the first place to position the subcomponent. So, just click the record button at that time.
                            My SketchUp Plugins
                              Regular Polygon
                              The best way to reach me for support is at the email listed here on the Contact page. I don't check this forum every day, but I do check my email quite often. If your model is less than 25 MB, you can send it to that email address and I will check it out for any bugs.
                              My SketchUp Plugins
                              • fouronethirtyF Offline
                                fouronethirty
                                can't export section animation
                                  Regular Polygon
                                  That is true. But I never claimed you could. The only scene properties that can be exported are camera location and visible layers. The other ones may be supported in the future. Section planes are currently fourth on the list of planned updates.
                                  My SketchUp Plugins
                                  • emerald15E Offline
                                    emerald15
                                    I've posted this problem separately, but though it might find more attention here.
                                    http://forums.sketchucation.com/viewtopic.php?f=79&t=42931
                                    Love using keyframe Animation, but can't figure this problem out.
                                    • utilerU Offline
                                      utiler
                                      Just bought this plugin, Regular_Polygon; I have been meaning too for a while..... πŸ‘
                                      I use your other plugins quite a lot so I feel I should contribute!!
                                      Just Curious...
                                        Regular Polygon
                                        Thank you! πŸ‘ πŸ˜„
                                        My SketchUp Plugins
                                          Regular Polygon
                                          Hi emerald15,
                                          Trying to animate two folding doors is an interesting problem. The door on the right just rotates about its right edge, so that is easy to animate. But the other door, to the left, moves in a way that is neither a simple rotation, or translation. However, it is possible to represent this motion using animated subcomponents. When you animate a subcomponent (subgroup), it moves relative to the parent. So, the combined motion can be something more complex than a translation or rotation.
                                          First, clear/delete any position data you have recorded for the doors. Then make a group out of the two doors, so each door is a subgroup. The basic idea is, you rotate the left door about the hing through some angle less than 180 degrees. At the same time, you rotate the entire two door group about the right edge through an angle of 90 degrees. The combined motion causes the doors to fold together exactly like they do in real life.
                                          I am sure that a video would explain this much better than words. I hope to make some tutorials in the near future. If it isn't clear, you can just email me your model, and I can quickly set up the animation, and send it back to you.
                                          My SketchUp Plugins
                                            emerald15
                                            Thanks Regular Polygon.
                                            As per e-mail, I followed instructions but failed. Here is the skp file if you would kindly help. Thank again.
                                            folding doors 2.skp
                                            • 6 / 8
