    Constructive Rendering Criticism
    renderpluginsextensions
    23 Posts 7 Posters 2.5k Views 7 Watching
      JM2
      Thought I would post an updated rendering of the original image I posted. Still adding the finishing touches in PS, but overall I'm really happy with the results. Thanks to everyone for their advice πŸ˜„
      • V Offline
        valerostudio
        nice work!
        • andybotA Offline
          andybot
          much better πŸ‘
          Are you adding trees back in post-pro?
            JM2
            @andybot said:
            much better πŸ‘
            Here are the two final renderings I did for the architect. We are actually going to show the client the black and white one but I thought the color looked good as well. I'm working on a second daytime rendering as well as a night rendering. I will post those within the next week. Thanks again for the tips!
            • BoxB Offline
              Looks nice, but I must say I'm a little confused by the Reflection or Image, it doesn't seem to reflect the correct subject if it is a reflection and it has colour in the black and white.
                JM2
                I was farther along than I thought I was, so here's the night rendering. I'm not as happy with this one, but for being my first one, I was still pleased.
                  JM2
                  I haven't done any post-pro work on it yet, but here's the other view of the project.
                    JM2
                    I know it is a little confusing...the window will serve both for viewing and light, as well as a projection screen for art.
                      Roger
                      @jm2 said:
                      @andybot said:
                      much better πŸ‘
                      JM2, there is still a problem, but you are getting much closer to a good result. Let me see if I can explain properly. The area of the projection screen shaded by the window frame projection should have saturated or at least more saturated color.
                      http://www.azcreative.com
                        JM2
                        @roger said:
                        @jm2 said:
                        @andybot said:
                        much better πŸ‘
                        Ahh...I understand now. The image would be saturated in that area due to the image being shaded by the window frame projection. I would assume it would be a combination of more saturation and a darker tone?
                        Thanks.
                          Roger
                          Not necessarily darker as the projection light source is independent of the exterior sunlight.
                          When in doubt, I will google for an example and if that produces nothing I will do a small quick-and-dirty mockup to study the effect I am trying to reproduce.
                          Of course, you can also build the projection effect right into your model and not have to do anything in post. However if you understand what the result will be it can be quicker to fake it.
                          • 2 / 2
