    [Plugin] Selection Memory
    39 Posts 17 Posters 24.6k Views 17 Watching
      Overview
      Response to this thread: http://forums.sketchucation.com/viewtopic.php?f=15%26amp;t=42390
      Will let the user cycle through the five last selection sets. Useful when you for instance accidentally deselects a carefully crafted selection.
      Important!
      This plugin has not been tested under OSX! It is not known how it will behave under SketchUp OSX where one process can have multiple models open. Unpredictable behaviour will most likely occur - possibly bugsplats.
      Modification
      To modify the number of saved sets, modify this constant:
      SELECTION_STACK_SIZE = 5
      I recommend you do not change this to a too large number.
      Access
      Edit > Cycle Previous Selections
      Features
      • Cycle Previous Selections
        Cycles through the last 5 selection sets.
      Requirements
      • SketchUp 8 or newer - ( Other versions untested )
      • Might work with older version. Just test for yourself. Either it works or it doesn't.
      SketchUp Plugins | PluginStore | SketchUcation
      SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
      (sketchucation.com)
      Footprint
      http://forums.sketchucation.com/download/file.php?id=53762
      <Sketchup>/Plugins/
      http://forums.sketchucation.com/download/file.php?id=53763
      tt_selection_memory.rb
      http://forums.sketchucation.com/download/file.php?id=53761
      • Rich O BrienR Online
        Nice tool πŸ‘
        Works like a charm
        • mitcorbM Offline
          mitcorb
          Thanks, thomthom:
          Tested in Sketchup 7, also. Worked on first try.
            πŸ‘ πŸ‘
              When you double click - two selections sets are made. One for the first click on the face - and one on the second click when edges are selected.
              If you deselect after a doubleclick you need to cycle two times to restore the selection with both borders. It is a bit counter-intuitive some times like that.
              Basically how it works:
              Every times you change the selection - the selection set is stored in the selection stack.
              Cycle selection advances the internal index and fetches the selection set associated with that index.
              The plugin is a bit rough around the edges like that.
              • massimoM Offline
                massimo Moderator
                Thanks! πŸ‘
                It seems not working with edges with the last selection. I mean select a rectangle with a double click-->deselect-->"cycle previous selection" and only the face is selected. But if you've made another selection and go back to the initial selection then it works.
                SU pro 7.1
                • massimoM Offline
                  massimo Moderator
                  Oh, I see. Thanks again. πŸ˜„
                  • massimoM Offline
                    massimo Moderator
                    Another thing: it seems not working with selection window from left to right. Is that normal?
                    Also not working with artisan's select brush.
                      Seems to work here. SU8?
                      As far as I've seen - it work with any selection.
                      Not sure how Artisan's selection brush works. If it continuously updates the selection then it might cause unexpected behaviour - as the stack will the flushed very quickly. It works by using SketchUp's selection observer...
                      • N Offline
                        numerobis
                        WOW! This sounds great! I have to test it...
                        thanks!!! 😎
                        • massimoM Offline
                          massimo Moderator
                          I have SU 7.1 and can confirm that here not works with left-->right selection while it works with right-->left selection.
                            Just tried it myself - I see no problems with Left to Right as oppose to Right to Left...
                            Are you able to make a short video of what you see?
                              Ah - it's something to do with how it retrieves back the previous selections. What you are experiencing is probably that it retrieves an earlier selection set. Might be empty.
                              There is five slots of selection sets - always - even when you start a fresh model. Keep cycle through and it will come back. I'll have a look at it. But this plugin isn't on top of my priority list.
                              • massimoM Offline
                                massimo Moderator
                                Ehm...I'm afraid not. Anyway this is what i do:
                                • Draw a simple rectangle for example;
                                • Select all (edges and face) with a left-->right window.
                                • click anywhere to deselect;
                                • run "cycle previous selection" and nothing happens.
                                  EDIT it's not working with right-->left selection either.
                                • massimoM Offline
                                  massimo Moderator
                                  Ah! That's maybe the reason. Thought that with a fresh model the "memory" would have been deleted.
                                    Well, it does - but there's a pre-reserved set of slots regardless. Which then are "filled" as you use it.
                                    The plugin was written very quickly so unfortunately it has this behaviour which is illogical from a user point of view. πŸ˜•
                                    • massimoM Offline
                                      massimo Moderator
                                      Ok, no problem. πŸ˜„
                                      • andybotA Offline
                                        andybot
                                        Thanks Thomthom πŸ‘ πŸ‘
                                        works as expected for me!
                                          Version 1.0.1
                                          Did a quick tweak to it. I believe it should retrieve the previous selection more predictably now.
                                          • massimoM Offline
                                            massimo Moderator
                                            Now it seems to work just fine. πŸ‘ πŸ‘
