    [REQ]plugin which ONLY reverses purple faces
    10 Posts 6 Posters 951 Views 6 Watching
    • john2J Offline
      john2
      i used reversing plugins found here, but the problem is that my selection comprises of both white and purple faces. i only want 2 reverse purple faces, the plugin reverses white faces too. is there any nice plugin/trick that i haven't found yet. i have used vbfr and TIG s face reverser. there's also one plugin with a gray toolbar button and a red streak. this makes me click on the backfaces and it reverses them one by one.
      Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
      • numbthumbN Offline
        numbthumb
        There is an option to "Orient faces": select a rightly-oriented face and right-context-click [Orient faces].
        Comfortably numb...
        • john2J Offline
          john2
          that doesnt always solve the problem
            Aerilius
            the problem is all faces are purple (have a backface) and white (have a frontface) at the same time. There might be one of the many face reverse scripts that is view-dependent. I think you should try this one:
            http://forums.sketchucation.com/viewtopic.php?f=323&t=32088&p=283327#p283327
            • john2J Offline
              john2
              well this plugin reverses my materials too 😢 i have to reapply materials [too much time wasted] on the white face that faces me now.
                My FixReversedFacesMaterials tool flips faces where you have applied a material to the back and it's wrongly oriented.
                It flips the face and reapplied the material, keeping UV-mapping etc.
                The native tool Orient will ensure ALL faces look the same way, BUT it fails if an edge has three faces - so tidy modeling means tidy faces.
                Model in Monochrome mode with a distinct back face color, if you make a reverse face select it and use Reverse on it.
                It's almost essential to have a shortcut set to Reverse.
                I have one set, and also Orient with it+Shift.
                It's easy to model right BUT hard to fix later...
                • simon le bonS Offline
                  simon le bon
                  @john2 said:
                  i used reversing plugins found here, but the problem is that my selection comprises of both white and purple faces. i only want 2 reverse purple faces.
                  Hi John,
                  I think [Plugin] Front Face - 1.2from Tomasz (SU2TH & SU2KT Developer) is the solution you are searching. 😉
                  -once the tool is activated you just have to "fly" with the mouse over the purple faces you want to reverse. White faces aren't touched 👍
                  -A simple icon is available to launch it
                  simon
                    simon le bon
                    well this plugin reverses my materials too i have to reapply materials [too much time wasted] on the white face that faces me now.
                    Hum! I just come back to test this plugin with textures applied: and effectively with this one too, textures are washed 😞 .
                    simon
                      simon le bon
                      Hum!2 I'm too much in the hurry to post: excuse me..
                      Dear TIG I just have made a first quick test of your [Plugin] Fix Reversed Face Materials
                      very powerful tools to help to export a model in a rendering application 👍 😉
                      -Fix Reversed Face Materials
                      -Fix Reversed Face Materials [Forced]
                      -Reverse Faces and Materials
                      -Delete Back-Materials
                      it seems to me that the main purpose is basically to bring materials to front, changing if necessary back textured faces by front textured faces.
                      A common question: ❓ When both front and back faces are textured, How can we know what face is front, what face is back.The Entity Info box don't reply
                      Yes shortcuts are a good idea. But that want to say that each face have to be treated one by one 😕
                      simon
                        Fix the face orientation before you apply materials, not after. If you did that you wouldn't be wasting time. Keep up with the face orientation from the beginning so you don't have to fix things later. Don't be a sloppy modeler and you won't have a lot of the problems you seem to be having according to your questions.
