    The PREVIOUS command like AutoCAD ??
    26 Posts 8 Posters 13.0k Views 8 Watching
      Ok - got something of a prototype working. Cycles through the last five selection sets. Though, it will probably have to be modified to work with OSX - as OSX can have multiple open models, selections might run into crossover issues. I'm working on a deadline this weekend so I don't have much more time until next week to look at that.
      • Jean LemireJ Offline
        Jean Lemire
        I folks.
        If you plan on doing a very complex selection and are afraid that you may loose it after an accidental click on empty space or whatever, like letting go of the SHIFT key, etc, I have the following trick: create a temporary group with some object or objects that are easy to rapidly select. Then, continue to select objects, cut them, open the temporary group and Paste it place. Get out of the group context and repeat the procedure.
        When the group contains all the objects you want, enter its context and do what you need to do. The fun part is that if anything goes wrong, you can undo and you still have the group that still contains all your carefully selected objects.
        When completely done with this selection (group), explode it.
        This may seems like a lot of work but, believe me, the little time wasted using this trick will be much less than the time lost trying to reselect and rerereselect and ... etc.
        A model that is well stuctured with components and named groups can also be easily managed with the Outliner.
        Just ideas.
        • arail1A Offline
          arail1
          This is one area where I geatly prefer AutoCAD's method. In AutoCAD you can keep selecting without de-selecting objects by accident. To de-select you hold down the Shift key. Much better than SketchUp.
            weeeell... "better" is very subjective on this matter. I could easily take your statement and flip SketchUp and AutoCAD. I don't like the way of selecting in AC. But I do like that it let you restore previous selection.
            • mitcorbM Offline
              mitcorb
              So far as I know, it (Autocad) won't let you COPY previous. And don't try to do large selections for move or stretch and then zoom in for precision box selection, because in this case all that is selected has to be fully within display.
              • Bob JamesB Offline
                Bob James
                @thomthom said:
                Ok - got something of a prototype working. I'm working on a deadline this weekend so I don't have much more time until next week to look at that.
                thomthom:
                Sit down
                Relax and take a deep breath
                Now let it out slowly
                Block out all sounds
                Clear your mind of random thoughts
                Look deeply into my eyes
                Think only of one thing
                GIZMO
                πŸ˜„
                • andybotA Offline
                  andybot
                  Um, quick ACAD tutorial.. make a selection. hit Esc twice. invoke copy command. type "p" (for "previous"). Enter. (now you have your previous selection.) (you can do this in any command, including "ch")
                  Now as for Thomthom - you can really make a gizmo to choose between earlier selections!?! 😲
                    I have a version working already. When you activate the command it cycles through the last five selections.
                    • john2J Offline
                      john2
                      http://bookbuilder.cast.org/bookresources/16/16951/glossary_9182.jpg
                      when are u gonna release this??
                      Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                        I need to check how it acts under OSX. There could be an issue there - where you have multiple models open in the same process. Under Windows it is not an issue as there is just one model per process.
                        • john2J Offline
                          john2
                          http://vitalogics.net/wp-content/uploads/2011/02/pic_excited_man.jpg
                          i have windows..yippee... so upload the windows version dude..for the windows people πŸ˜„
                            Allrightallright - for the Windows people: http://forums.sketchucation.com/viewtopic.php?f=323&t=42469
                            • 2 / 2
