    The PREVIOUS command like AutoCAD ??
    26 Posts 8 Posters 13.0k Views 8 Watching
      @john2 said:
      uh what i wanted pilou that after selection has been done if i press at a blank space..my objects get deselected. in autocad if i type the word previous, the objects that were selected previously get selected. in a nutshell autocad remembers what i last selected and selects them. it saves my selection in memory.
      You know what - I want such a function myself... If the Selection Observer behave reliably it might not be that hard... will have to see. Before SU8 it was FUBAR - but I think it should be acting better now.
        You are not in in Autocad but result will be the same!
        Multiple selection in SU is made with SHIFT Pressed (if one object is yet selected it will be deselect)
        I don't see any difficulty πŸ˜„
        And even you click on a blank space just reselect all with a box selection then deselect the objects not wanted!
        And that is not obliged the last one πŸ˜‰
        And try also one click, double click, triple click !
        Ps But if Thomthom want to make the trick you are in good hands β˜€
          Pilu, he's not asking about how to add to a selection, but how to restore a selection. For instance, if you have a selection and click on empty model space everything is deselected - sometimes that is not what you wanted and would like to restore the selection.
          • andybotA Offline
            andybot
            In the interim, while thomthom creates some more amazing plugins (and I don't mean that sarcastically, his work is outstanding) have you tried the selection toys plugin? It makes selecting and deselecting specific geometry types a breeze.
              Yes I had full understood he wants a sort of history selection for solve the click on a empty space πŸ˜‰
              There is so numerous possibility of speedy selections, and your tools selection πŸ˜‰
              so the click on a free space is not a such drama πŸ˜„
                Some times is it - when you've carefully crafted a complex selection where automated tools cannot be used.
                  In this case you must be never with numerous objects for avoid that! πŸ˜‰
                  If a complex selection is needing that want to say that organisation of objects is not optimum from the beginning!
                    That might be - but it is what I have some times when I take over models made by others. Or import geoemtry from AutoCAD or Revit. In which case I often need to carefully select and separate specific elements so I can regroup it.
                      Ok - got something of a prototype working. Cycles through the last five selection sets. Though, it will probably have to be modified to work with OSX - as OSX can have multiple open models, selections might run into crossover issues. I'm working on a deadline this weekend so I don't have much more time until next week to look at that.
                      • Jean LemireJ Offline
                        Jean Lemire
                        I folks.
                        If you plan on doing a very complex selection and are afraid that you may loose it after an accidental click on empty space or whatever, like letting go of the SHIFT key, etc, I have the following trick: create a temporary group with some object or objects that are easy to rapidly select. Then, continue to select objects, cut them, open the temporary group and Paste it place. Get out of the group context and repeat the procedure.
                        When the group contains all the objects you want, enter its context and do what you need to do. The fun part is that if anything goes wrong, you can undo and you still have the group that still contains all your carefully selected objects.
                        When completely done with this selection (group), explode it.
                        This may seems like a lot of work but, believe me, the little time wasted using this trick will be much less than the time lost trying to reselect and rerereselect and ... etc.
                        A model that is well stuctured with components and named groups can also be easily managed with the Outliner.
                        Just ideas.
                        • arail1A Offline
                          arail1
                          This is one area where I geatly prefer AutoCAD's method. In AutoCAD you can keep selecting without de-selecting objects by accident. To de-select you hold down the Shift key. Much better than SketchUp.
                            weeeell... "better" is very subjective on this matter. I could easily take your statement and flip SketchUp and AutoCAD. I don't like the way of selecting in AC. But I do like that it let you restore previous selection.
                            • mitcorbM Offline
                              mitcorb
                              So far as I know, it (Autocad) won't let you COPY previous. And don't try to do large selections for move or stretch and then zoom in for precision box selection, because in this case all that is selected has to be fully within display.
                              • Bob JamesB Offline
                                Bob James
                                @thomthom said:
                                Ok - got something of a prototype working. I'm working on a deadline this weekend so I don't have much more time until next week to look at that.
                                thomthom:
                                Sit down
                                Relax and take a deep breath
                                Now let it out slowly
                                Block out all sounds
                                Clear your mind of random thoughts
                                Look deeply into my eyes
                                Think only of one thing
                                GIZMO
                                πŸ˜„
                                • andybotA Offline
                                  andybot
                                  Um, quick ACAD tutorial.. make a selection. hit Esc twice. invoke copy command. type "p" (for "previous"). Enter. (now you have your previous selection.) (you can do this in any command, including "ch")
                                  Now as for Thomthom - you can really make a gizmo to choose between earlier selections!?! 😲
                                    I have a version working already. When you activate the command it cycles through the last five selections.
                                    • john2J Offline
                                      john2
                                      http://bookbuilder.cast.org/bookresources/16/16951/glossary_9182.jpg
                                      when are u gonna release this??
                                      Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                                        I need to check how it acts under OSX. There could be an issue there - where you have multiple models open in the same process. Under Windows it is not an issue as there is just one model per process.
                                        • john2J Offline
                                          john2
                                          http://vitalogics.net/wp-content/uploads/2011/02/pic_excited_man.jpg
                                          i have windows..yippee... so upload the windows version dude..for the windows people πŸ˜„
                                            Allrightallright - for the Windows people: http://forums.sketchucation.com/viewtopic.php?f=323&t=42469
