    Inner bevel
    20 Posts 6 Posters 3.6k Views 6 Watching
    • GaieusG
      On a slightly different note...
      The profile does not have to be on the path you are extruding it along. SU sometimes "complains" that it's not on the path (sometimes does not): simply disregard. Here is an example where you can make a simple inner bevel with a profile completely disconnected from the main shape.
      InnerBevel.skp
      • charly2008C
        charly2008
        Also, I had again a Duh moment yesterday in this thread
        The method Convert arcs.... to cylinders is very suitable for engraving maybe also for carvings.
        404 Not Found
        (forums.sketchucation.com)
        Charly
        • H
          harnstein
          Exactly.
          It has a great potential!
          I'm like a bull facing a mountain (german saying for "standing there understanding nothing, too stupid")
          I never used "outer shell" before, i don't know why, it's great.
          But it doesn't work correctly for me, somehow:
          if i select a bunch of groups (created e.g. with convert to arc.. ("precision 4", "each tube is a group")
          SU sometimes deletes some groups when using "outer shell" on them.
          Second, when i want to substract this solid (created with "outer shell") from e.g. a box it's saying "selection is not a solid"..
          I tried it a couple of times but just couldn't get it to work..
          Any ideas what i may be doing wrong?
          Happy new year 2012 to all of you!
          still sketchin'
          • gillesG
            gilles
            Could you post a .skp ?
            • H
              harnstein
              Hey,
              here's the skp-file. I could't reproduce the problem i mentioned above when SU has a problem with substracting a solid
              made by "outer shell" from another solid saying it's not a solid.. (and, not showing a volume in entity info as well)
              But here's the problem attached concerning disappearing groups when using outer shell on tubes created with "cylinder along line" plug.
              Problem is explained inside of the file.
              Thanks 😉
              Outer shell makes no solid problem.skp
              still sketchin'
              • sdmitchS
                sdmitch
                For anyone interested in this problem, I invite you to visit my plugins blog and check out Bevel Maker.
                http://sdmitch.blogspot.com/
                • charly2008C
                  charly2008
                  Hi Sam,
                  Your "Bevel Maker" works well. But for many geometries I get a "BugSplat".
                  Charly
                  Works well
                  Bugsplat
                  Bugsplat
                  • sdmitchS
                    sdmitch
                    Yes I have had the same problems with circles and arcs not sure why. Sometimes it works better choosing 1 face at a time in these cases.
                      I'm just talking out of my hat because I don't know but... Does the plugin actually do a "move" operation and do the Auto fold thing? Is it failing on arcs and circles due to small faces?
                      • sdmitchS
                        sdmitch
                        Yes it moves the face created by the offset using a transform with results in an autofold creating the bevel.
