    Inner bevel
    20 Posts 6 Posters 3.6k Views 6 Watching
    • gillesG
      gilles
      Gilles method is a good one too. Didn't work for me right now saying the group created by "convert lines to tubes" plugin is not a solid, whyever.
      It does for me, be sure to check in input box "create a group"=no, "each tube is a group"=yes
      #1- make your shape a group before drawing lines to bevel
      #2- draw the lines a little longer than the edges of the shape (according to the radius)
      #3-Tool/convert lines to tube:"create a group"=no, "each tube is a group"=yes "precision"= 4
      #4-Solid tools "outer shell" with all the tubes, gives one solid
      #5-Solid tools "subtract" N°1 tubes, N°2 shape
      #6- its done
      PS: this plugins always wants to apply home material?
      • GaieusG
        On a slightly different note...
        The profile does not have to be on the path you are extruding it along. SU sometimes "complains" that it's not on the path (sometimes does not): simply disregard. Here is an example where you can make a simple inner bevel with a profile completely disconnected from the main shape.
        InnerBevel.skp
        • charly2008C
          charly2008
          Also, I had again a Duh moment yesterday in this thread
          The method Convert arcs.... to cylinders is very suitable for engraving maybe also for carvings.
          404 Not Found
          (forums.sketchucation.com)
          Charly
          • H
            harnstein
            Exactly.
            It has a great potential!
            I'm like a bull facing a mountain (german saying for "standing there understanding nothing, too stupid")
            I never used "outer shell" before, i don't know why, it's great.
            But it doesn't work correctly for me, somehow:
            if i select a bunch of groups (created e.g. with convert to arc.. ("precision 4", "each tube is a group")
            SU sometimes deletes some groups when using "outer shell" on them.
            Second, when i want to substract this solid (created with "outer shell") from e.g. a box it's saying "selection is not a solid"..
            I tried it a couple of times but just couldn't get it to work..
            Any ideas what i may be doing wrong?
            Happy new year 2012 to all of you!
            still sketchin'
            • gillesG
              gilles
              Could you post a .skp ?
              • H
                harnstein
                Hey,
                here's the skp-file. I could't reproduce the problem i mentioned above when SU has a problem with substracting a solid
                made by "outer shell" from another solid saying it's not a solid.. (and, not showing a volume in entity info as well)
                But here's the problem attached concerning disappearing groups when using outer shell on tubes created with "cylinder along line" plug.
                Problem is explained inside of the file.
                Thanks 😉
                Outer shell makes no solid problem.skp
                still sketchin'
                • sdmitchS
                  sdmitch
                  For anyone interested in this problem, I invite you to visit my plugins blog and check out Bevel Maker.
                  http://sdmitch.blogspot.com/
                  • charly2008C
                    charly2008
                    Hi Sam,
                    Your "Bevel Maker" works well. But for many geometries I get a "BugSplat".
                    Charly
                    Works well
                    Bugsplat
                    Bugsplat
                    • sdmitchS
                      sdmitch
                      Yes I have had the same problems with circles and arcs not sure why. Sometimes it works better choosing 1 face at a time in these cases.
                        I'm just talking out of my hat because I don't know but... Does the plugin actually do a "move" operation and do the Auto fold thing? Is it failing on arcs and circles due to small faces?
                        • sdmitchS
                          sdmitch
                          Yes it moves the face created by the offset using a transform with results in an autofold creating the bevel.
