    Inner bevel
    20 Posts 6 Posters 3.6k Views 6 Watching
    • GaieusG
      I made a quarter a group here and bevelled the outer edge. If you have more of the same kind, making it a component would be better - then distribute them on the face. I used the Round Corner plugin here though - it can also bevel but has more functions, too.
      • GaieusG
        Another solution is to offset the two, inner edges on each face (this can only be done one face at a time)
        And then move it out to the desired distance (this can already be done with all four faces at the same time - just select all four first)
          No need for plugins. This was done with the native tools. Offset and Move/Autofold. Doesn't take long.
          Edit: I see Csaba beat me to it. 😄
          Rereading your original post, I'm not sure I got what you are looking for. I moved the faces out leaving the original lines as the bottoms of the valleys.
          Bevels.skp
          • H
            harnstein
            Great to see these different approaches!
            The problems with offsetting are:
            • if only one continuous line is selected the offset is shorter or longer than the original line, related to the angle (image 1)2.png
            • if all surrounding lines (or easier only the face) is offsetted, the edge-line of the solid gets a offset, too (image 3)3.png
            • if there are many faces this method won't work because you'd have to select each face individually
            • if there are sharp angles the offset will not be correct
            If there are just a few faces (lets say which you could count) you would doubleclick the face and deselect the outer lines.
            This is alright if you have a straight edge line, but it's not practical if the edge lines consist of many lines. (image 2)1.png
            @Dave, you got exactly what i am looking for. I doesn't matter if you pull out the faces or push in the lines.
            I just want to know how to achieve that basically. Could be used for importing any spline (e.g. an ornament) and pushing it into a face 3dimensionally.
            Or e.g. if you want to model tiles, just draw a face, place a grid on it and bevel..
            still sketchin'
              I did exactly what I said and what you say doesn't work. I used Offset (remember, after the first Offset operation, you can double click for the others. This is similar to the Push/Pull tool.) on edges I selected by double clicking on a face and then removing the exterior edges and the face from the selection holding Shift with Select. Yes, I did have to extend some edges and delete bits that ran over but that is pretty basic stuff. Then I selected all of the faces I wanted to move and used the Move tool while holding Alt to invoke Autofold. They were all moved in a single operation. It didn't take very long to do although I'll concede it could be time consuming over a very large area. I think Gilles' suggestion is a great alternative for something like that. and Subtract from the Solid tools would make quick work of it.
              For floor tiles I wouldn't use either method. It would create too much unneeded geometry. I would make a tile component and lay out copies of it to cover the area.
              • H
                harnstein
                Exactly-
                that's the point. Sure i could follow your explanations (thanks for that "doubleclick repeats action" hint, that's great! Didn't know that..!) and it works for this example.
                I don't want to be seen as just too lazy here 😉 it will just be problematic with complex structures, as mentioned.
                Concerning tiles: yes, your right that it's way better to use components to tile a floor,
                but if the tiles are not regular (some different sizes of rectangles or a slate floor) it's a different story.
                Gilles method is a good one too. Didn't work for me right now saying the group created by "convert lines to tubes" plugin is not a solid, whyever.
                I don't know if it would be possible to change the bevel plugin's code to achieve sth. like an "inner bevel".
                Thanks for all your answers!
                still sketchin'
                • gillesG
                  gilles
                  It does for me, be sure to check in input box "create a group"=no, "each tube is a group"=yes
                  #1- make your shape a group before drawing lines to bevel
                  #2- draw the lines a little longer than the edges of the shape (according to the radius)
                  #3-Tool/convert lines to tube:"create a group"=no, "each tube is a group"=yes "precision"= 4
                  #4-Solid tools "outer shell" with all the tubes, gives one solid
                  #5-Solid tools "subtract" N°1 tubes, N°2 shape
                  #6- its done
                  PS: this plugins always wants to apply home material?
                  • GaieusG
                    On a slightly different note...
                    The profile does not have to be on the path you are extruding it along. SU sometimes "complains" that it's not on the path (sometimes does not): simply disregard. Here is an example where you can make a simple inner bevel with a profile completely disconnected from the main shape.
                    InnerBevel.skp
                    • charly2008C
                      charly2008
                      Also, I had again a Duh moment yesterday in this thread
                      The method Convert arcs.... to cylinders is very suitable for engraving maybe also for carvings.
                      http://forums.sketchucation.com/viewtopic.php?f=15&t=17315&start=315
                      Charly
                      • H
                        harnstein
                        Exactly.
                        It has a great potential!
                        I'm like a bull facing a mountain (german saying for "standing there understanding nothing, too stupid")
                        I never used "outer shell" before, i don't know why, it's great.
                        But it doesn't work correctly for me, somehow:
                        if i select a bunch of groups (created e.g. with convert to arc.. ("precision 4", "each tube is a group")
                        SU sometimes deletes some groups when using "outer shell" on them.
                        Second, when i want to substract this solid (created with "outer shell") from e.g. a box it's saying "selection is not a solid"..
                        I tried it a couple of times but just couldn't get it to work..
                        Any ideas what i may be doing wrong?
                        Happy new year 2012 to all of you!
                        still sketchin'
                        • gillesG
                          gilles
                          Could you post a .skp ?
                          • H
                            harnstein
                            Hey,
                            here's the skp-file. I could't reproduce the problem i mentioned above when SU has a problem with substracting a solid
                            made by "outer shell" from another solid saying it's not a solid.. (and, not showing a volume in entity info as well)
                            But here's the problem attached concerning disappearing groups when using outer shell on tubes created with "cylinder along line" plug.
                            Problem is explained inside of the file.
                            Thanks 😉
                            Outer shell makes no solid problem.skp
                            still sketchin'
                            • sdmitchS
                              sdmitch
                              For anyone interested in this problem, I invite you to visit my plugins blog and check out Bevel Maker.
                              http://sdmitch.blogspot.com/
                              • charly2008C
                                charly2008
                                Hi Sam,
                                Your "Bevel Maker" works well. But for many geometries I get a "BugSplat".
                                Charly
                                Works well
                                Bugsplat
                                Bugsplat
                                • sdmitchS
                                  sdmitch
                                  Yes I have had the same problems with circles and arcs not sure why. Sometimes it works better choosing 1 face at a time in these cases.
                                    I'm just talking out of my hat because I don't know but... Does the plugin actually do a "move" operation and do the Auto fold thing? Is it failing on arcs and circles due to small faces?
                                    • sdmitchS
                                      sdmitch
                                      Yes it moves the face created by the offset using a transform with results in an autofold creating the bevel.
