    [Plugin] Simple Plugin Installer
    83 Posts 29 Posters 190.9k Views 29 Watching
      If only the Ruby API wasn't so limited...
      I'd ideally like to be able to select multiple files and/or folders. Also wish the file pattern filter wasn't bugged so one could combine multiple file patterns... 😞
      http://t2.gstatic.com/images?q=tbn;ANd9GcT-Lte9Hn5FR_s2nxrJ2-H9YOb7Nfz6ldyO5GGl1lbyUIIwKATTAw
        Idea... β˜€ ...using HTML5, a webdialog can act as a drop pad for files. Just dump a selection of files, rbz, zip or plain rb files and install in bulk!!
          Thomas, this is a great idea! Is it possible for the plugin to also run load"plugin_name.rb" after copying the file and installing it into the Plugins folder?
            Capital idea ol' chum!
              Jim
              Yep, but it would make a better stand-alone "Drop Pad" plugin that can dispatch various file types to user-configurable plugins.
                You mean being able to configure what plugin to handle what fileformat?
                  Jim
                  Yeah, but the downside is that the plugins that handle the file types would likely all need modified to handle the Drop Pad dispatcher.
                    Well, it won't be doable until IE10 is released anyway... 😞
                      hm... you meant for the pad to dispatch to existing plugins...?
                      • john2J
                        john2
                        any plans to further advance this into a full fledged plugin manager that allows u to uninstall plugins too?
                        Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                          Nope! It's too big of a project - I have too many other projects on my hand. But Dana is working such a manager. πŸ˜„
                          • john2J
                            john2
                            where's that plugin any idea ❓
                              It is under development - along side with a plugin repository.
                              • irwanwrI
                                irwanwr
                                Requirements
                                SketchUp 8M2 or newer - ( Other versions untested )
                                oops...
                                • john2J
                                  john2
                                  no beta version ..link 4 download??
                                    πŸ˜’
                                    Just relax. It'll be available when it is available.
                                      Keep an eye on this site: http://www.extendsketchup.com/
                                      As Dave said - it's done when it's done. He's working on it along side his full time job - like I do. Making it very hard to promise a deadline. (It's hard even if it is your full time job any way... 😞 )
                                        Hmm.... IE10 might not come until Windows8 is out... I hope it comes earlier - as I think Windows 8 comes late this year.
                                        • guanjinG
                                          guanjin
                                          Really good, but can not load the RB file, tried many, will not work!
                                            That's mostly useless if you're asking for help. You have given nothing for anyone to help you with. Go back to the first post and make sure you've installed the plugin so it shows as described under "Footprint"
                                            Footprint
                                            http://forums.sketchucation.com/download/file.php?id=53762
                                            <Sketchup>/Plugins/
                                            http://forums.sketchucation.com/download/file.php?id=53763
                                            tt_simple_installer.rb
                                            If you don't get it to work, post a screen shot of your Plugins directory or give something useful so you can be helped.
                                            • 1 / 5
