    [Tutorial] Industrial staircase handrail.
    28 Posts 9 Posters 14.9k Views 9 Watching
    • simon le bonS Offline
      simon le bon
      Hi Jeff,
      I have Su6 & Su7 and can't read your Su8 skp solution 😞
      But I guess you have used something like this way:
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thhandrail025.jpg
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thhandrail026.jpg
      πŸ‘ πŸ‘
      Hi Eli,
      I recognize with great pleasure your special spirit which works to find the simplest way. Your solution is very clever in its simplicity πŸ‘ πŸ‘ . I agree with Jeff to think that this way has been used usually in construction.
      Hi Bob,
      I ask myself if we need a pdf right now? Or may be one including Jeff and Eli solutions !?
      Hi Pilou,
      I have discovered the possibility to edit nicely a pdf into Open Office.
      I am interested by this sort of operation β˜€
      "How to modify an existing PDF"
      In fact I haven't found the possibility to "edit" or modify a pdf within Open Office! 😞 I have just found that we can edit a complex text with pictures and links(+-?) and record it as a decent pdf. Hum! this is not exactly the same.
      ++simon.
        simon le bon
        Dear Jeff,
        you show the interest of Uniform B-Spline I have missed until now!!
        here page 4 from pdf tutorial relatives to B-Spline and Order parameter:
        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/B_Spline_Title.jpg
        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_B_Splinep4.jpg
        I know your video I have already watched several times πŸ˜‰
        But your tritubes shows also very well the extension of your technique.
        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_Jeff_tubblend.jpg
        (Re I wanted to relate your realization in wood but the pictures are no more available 😞 )
        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_Jeff_recentwork.jpg
        a tip: when the curve is drawn, right clic and edit curve. Then use tab to call Order parameter and change it without leaving the edit mode until you find the good one πŸ˜‰
        ++simon
          Jim
          Maybe too simple for accuracy?
          http://i.min.us/jbiByo.png
          http://i.min.us/jbjaXQ.png
          rail.skp
            simon le bon
            Hey hey! Dear Jim,
            You win with the "synthetic" (is it the good word?) simplicity of your solution.
            Now that we see it, we ask ourself how can it be possible to have missed it!!
            I think I have initiate with the worst solution πŸ˜• . Noway it is a good tutorial thread. Very instructive for each one I guess.
            ++simonlebon
              Last Jim's solution is perfect if you want not a blend progressive jonction between the 2 ends straight cylindric lines πŸ˜‰
              • irwanwrI Offline
                irwanwr
                i was thinking the way Jim did it too, before i got my eyes onto his post.
                did i miss something there? like the vertical tube joining that rail and the stair below it?
                i mean shouldn't that curvy rail on the joining plane have horizontal alignment to each other?
                test rel tangga.skp
                  simon le bon
                  Hi Irwan,
                  it is silly but I don't understand exactly what you mean (I'm french with low english language)
                  I have initiated something which is an unnecessary complex solution, and each one had bring his own one, that bringing the interest of the thread.
                  Whatever, I am still pleased with the result of this unique curve that I had tried to make fitting artistically to the rails...
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EscalierIndustriel_rampeMetal_Suite2-750.jpg
                  and also a bit proud of the UV mapping of these barrels made with a little series of phone pictures πŸ˜‰
                  Happy New Year β˜€
                  simon>.
                  • irwanwrI Offline
                    irwanwr
                    hi Simon πŸ˜„
                    i know you are French. i always win easily if i play for French in Sid Meier's Pirates πŸ˜› (irrelevant)
                    yes, it's a good image indeed. what rendering application did you use for it?
                    by the way, how is your graphic adapter now? any luck with the artifacts on the screen yet?
                    happy new year, Simon.
                    [ed] i think what Elisei did up there is the same thing that Jim did.
                      simon le bon
                      Hi Irwan πŸ˜„
                      ❓ πŸ˜’ 😎 No rendering in this case. All is simply SketchUp!
                      I'm still searching.
                      With your Video Memory Test (which is a portable handy little app) I know that my GPU ram is clean
                      http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/VideoMemoryTest_2012-01-01.jpg
                      I'm now going to upgrade my video drivers..
                      Hum! πŸ˜’ You still haven't the reply to your previous question..
                      With my best, simon.
                      • irwanwrI Offline
                        irwanwr
                        [ed] congratulation with the test result, Simon. the next step for more comprehensive diagnose then πŸ˜‰
                        what question?
                        • 2 / 2
