    [Tutorial] Industrial staircase handrail.
    28 Posts 9 Posters 15.1k Views 9 Watching
    • daleD
      dale
      Hey Simon
      Thanks as usual. You are such a great contributor.
      Cheers
        Cool tut variations! 👍
        I have discovered the possibility to edit nicely a pdf into Open Office.
        I am interested by this sort of operation ☀
        "How to modify an existing PDF"
        • jeff hammondJ
          so i tried what i was thinking earlier and it does work.. i did this curve in 10 seconds using fredo's BezierSpline.rb (Uniform B-Spline)
          railBend.skp
          a little different than the example .skp... this one uses shorter extensions and an order 4 b-spline.. (see skp above)
          • ely862meE
            ely862me
            No plugin used,just native tools.
            Elisei (sketchupper)
            Come and See EliseiDesign
            • simon le bonS
              simon le bon
              10seconds!!!!
              I am on phone i need to see that this evening!
              Hey Jeff, you've also killed my tut 👊 in 10 seconds 🤣
              simon
              • jeff hammondJ
                lol..
                that's how they would probably be built as well.. straight tubes with 90 deg bends on the ends then welded together on site.
                • jeff hammondJ
                  @simon le bon said:
                  Hi Jeff,
                  I have Su6 & Su7 and can't read your Su8 skp solution 😞
                  But I guess you have used something like this way:
                  oops.. once again i forgot to save as something that everyone can view 😳 .. here's a v6 file.
                  railBend_v6.skp
                  it's pretty much what you've imagined it to be except i only used 4 points to define the curve. (as you only need 2 points to make a tangent blend to a line)..
                  it's something i discovered about the uniform b-spline..(in part due to eli's problem solving in a different thread).. here's a post of mine in which i do the same thing to create a tangent (and somewhat editable) complex surface blend using uniform b-splines..
                  404 Not Found
                  (forums.sketchucation.com)
                  [the video from that thread:]
                  [flash=660,405:20ue0pp6]http://www.youtube.com/v/8B0RXSW66no?fs=1&hl=en_US&rel=0&color1=0x2b405b&color2=0x6b8ab6&border=1[/flash:20ue0pp6]
                  • simon le bonS
                    simon le bon
                    Hi Jeff,
                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thhandrail025.jpg
                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thhandrail026.jpg
                    Hi Eli,
                    I recognize with great pleasure your special spirit which works to find the simplest way. Your solution is very clever in its simplicity 👍 👍 . I agree with Jeff to think that this way has been used usually in construction.
                    Hi Bob,
                    I ask myself if we need a pdf right now? Or may be one including Jeff and Eli solutions !?
                    Hi Pilou,
                    In fact I haven't found the possibility to "edit" or modify a pdf within Open Office! 😞 I have just found that we can edit a complex text with pictures and links(+-?) and record it as a decent pdf. Hum! this is not exactly the same.
                    ++simon.
                    • simon le bonS
                      simon le bon
                      Dear Jeff,
                      you show the interest of Uniform B-Spline I have missed until now!!
                      here page 4 from pdf tutorial relatives to B-Spline and Order parameter:
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/B_Spline_Title.jpg
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_B_Splinep4.jpg
                      I know your video I have already watched several times 😉
                      But your tritubes shows also very well the extension of your technique.
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_Jeff_tubblend.jpg
                      (Re I wanted to relate your realization in wood but the pictures are no more available 😞 )
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_Jeff_recentwork.jpg
                      a tip: when the curve is drawn, right clic and edit curve. Then use tab to call Order parameter and change it without leaving the edit mode until you find the good one 😉
                      ++simon
                        Jim
                        Maybe too simple for accuracy?
                        http://i.min.us/jbiByo.png
                        http://i.min.us/jbjaXQ.png
                        rail.skp
                        • simon le bonS
                          simon le bon
                          Hey hey! Dear Jim,
                          You win with the "synthetic" (is it the good word?) simplicity of your solution.
                          Now that we see it, we ask ourself how can it be possible to have missed it!!
                          I think I have initiate with the worst solution 😕 . Noway it is a good tutorial thread. Very instructive for each one I guess.
                          ++simonlebon
                            Last Jim's solution is perfect if you want not a blend progressive jonction between the 2 ends straight cylindric lines 😉
                            • irwanwrI
                              irwanwr
                              i was thinking the way Jim did it too, before i got my eyes onto his post.
                              did i miss something there? like the vertical tube joining that rail and the stair below it?
                              i mean shouldn't that curvy rail on the joining plane have horizontal alignment to each other?
                              test rel tangga.skp
                              • simon le bonS
                                simon le bon
                                Hi Irwan,
                                it is silly but I don't understand exactly what you mean (I'm french with low english language)
                                I have initiated something which is an unnecessary complex solution, and each one had bring his own one, that bringing the interest of the thread.
                                Whatever, I am still pleased with the result of this unique curve that I had tried to make fitting artistically to the rails...
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EscalierIndustriel_rampeMetal_Suite2-750.jpg
                                and also a bit proud of the UV mapping of these barrels made with a little series of phone pictures 😉
                                Happy New Year ☀
                                simon>.
                                • irwanwrI
                                  irwanwr
                                  hi Simon 😄
                                  i know you are French. i always win easily if i play for French in Sid Meier's Pirates 😛 (irrelevant)
                                  yes, it's a good image indeed. what rendering application did you use for it?
                                  by the way, how is your graphic adapter now? any luck with the artifacts on the screen yet?
                                  happy new year, Simon.
                                  [ed] i think what Elisei did up there is the same thing that Jim did.
                                  • simon le bonS
                                    simon le bon
                                    Hi Irwan 😄
                                    ❓ 😒 😎 No rendering in this case. All is simply SketchUp!
                                    I'm still searching.
                                    With your Video Memory Test (which is a portable handy little app) I know that my GPU ram is clean
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/VideoMemoryTest_2012-01-01.jpg
                                    I'm now going to upgrade my video drivers..
                                    Hum! 😒 You still haven't the reply to your previous question..
                                    With my best, simon.
                                    • irwanwrI
                                      irwanwr
                                      [ed] congratulation with the test result, Simon. the next step for more comprehensive diagnose then 😉
                                      what question?
                                      • 2 / 2
