    [Plugin] Circle from edge (2-pt circle,Updated 15/02/2016)
    29 Posts 10 Posters 64.9k Views 10 Watching
      Cool ๐Ÿ˜Ž
      Not yet tested ๐Ÿ˜ณ
      But are you sure that you draw the good circle?
      On the video we can see that you take 2 quasi oposites points but are you sure that is a diameter?
      Or have you an algorithm who avoid that?
        Tested โ˜€ (all with 24 segments as default)
        Cool but don't work if you don't take an "end point" on the original circle ๐Ÿ˜‰
        (midpoint for example)
        Circles will be not directly overlapsed ๐Ÿ˜‰
          Perhaps see my 2Dtool's 2Dcircle code for some cribs... they make circles by center+radius, three-points and diameter [two points]; with typed in dimensions and segmentation...
          Its 2Dpolygon sibling is similar but also has polygon by side length option - useful for making pseudo-circles with a fixed segment length...
            sahi
            In the first report script focuses on the endpoint bindings. What kind of plane it points parallel to the plane and added to the face
            In this script focuses on the initial anchor point.
            krug_4.zip
            • kenK Offline
              ken
              Not sure this plugin draw a circle. I have two other plugin, draw circle by two points, and draw a circle by 3 points and both of these plugin the circles drawn will have a diameter if dimension by the dimensioning tool. Using this plugin the drawn circle is a group of straight lines in a circle an can not be dimensioned.
              Useful, however not a circle. And thank you for you work.
              Ken
                sahi
                Updated the script in the first message
                Added
                Shift left - the direction of drawing a circle blocks
                Shift right - blocking the diameter of the circle
                <- Left Arrow - Draw a circle perpendicular to x axis
                -> arrow to the right - draw a circle perpendicular to the axis of
                Up arrow - adds one hemisphere at the top
                Down arrow - adds one side of the bottom
                • mitcorbM Offline
                  mitcorb
                  Hi, sahi:
                  I was hoping for a little more explanation of the tool. I am not a good tester.
                  Edit 05/19/11. Your latest update video explains well. ๐Ÿ‘
                  • boofredlayB Offline
                    boofredlay
                    This is looking great, thanks.
                    • kenK Offline
                      ken
                      This is looking like a keeper of a plugin. However, it does not make a circle or any geometry that Sketchup can input a center mark. Now, I know this does not seem important now, but later after push pulling, adding multiple circles, you will want to add dimensions or find the center and the geometry this plugin make you can not accomplish that task.
                      There is another 2 point circle plugin that does make geometry that you can get the dimensions and add a center point. Just pointing this out, as right now it makes more work later down the road than it should.
                      However, thanks for the plugin.
                      Ken
                        boilingsnow
                        "Up arrow - adds one hemisphere at the top
                        Down arrow - adds one side of the bottom"
                        These two options don't work in my sketchup 8...
                          sahi
                          Updated the script in the first message (krug-10.zip)
                            boilingsnow
                            That was really quick! Thanks a lot. But sadly... the problem unsolved.
                            Am I doing anything wrong? After drawing the circle press the up arrow key.
                            By the way,the left and right arrow keys are working.
                              sahi
                              In previous versions it was impossible to move the mouse, then press worked.
                              I fixed it in version krug-11.zip
                              Updated the script in the first message (krug-11.zip)
                                boilingsnow
                                Did you test it in Sketchup 8? I'm sorry I still can't get it working.
                                  sahi
                                  The archive video
                                  video_krug_4.rar
                                    boilingsnow
                                    @sahi said:
                                    The archive video
                                    [attachment=0:12b25ek5]<!-- ia0 -->video_krug_4.rar<!-- ia0 -->[/attachment:12b25ek5]
                                    Yes I can see it works well in your video. And the anwsers of other Members can also confirm that it works.
                                    I know it's a little annoying now but the krug_11 also does't work by creating the hemispheres with up- and down arrow key. I've tested it in my notebook and in PC of the office, neither can work.
                                    I also tested your krug_4, I can only draw the first circle, but none of the arrow key can work. (with krug_11 I can create the second and third circles with left and right keys but not the hemispheres.
                                    I'm using sketchup 8.0.3117 and win XP with a german keyboard. But I don't think it has anything to do with the keyboard, right? What do you mean with your words 'In previous versions it was impossible to move the mouse'? Should I move the mouse to a certain position before I press the up arrow key?
                                    • mitcorbM Offline
                                      mitcorb
                                      For me, it appears that I must press the arrow keys within say 5 seconds to get the results. I can't go back to a circle and use the arrow keys. Is this correct?
                                        sahi
                                        No. While you are using a script and did not select another tool or until set again the starting point of the circle - you can use the arrow to the left, right, up, and the bottom
                                        Yes.
                                        NO
                                        I think the problem is the keyboard.
                                          boilingsnow
                                          I think the problem is the keyboard.[/quote]
                                          Yes, you are right.
                                          I find out that every plugin that need to use up and down arrow key doesn't work in my notebook. (Such as Artisan uses up and down key to change the displacement vector. and "edge follow me" tool of sdmich uses up+down to change the direction of the curve).
                                          BUT finally I figured out that up and down work in all these plugins if I press ctrl+up or ctrl+down, I don't know why.
                                          Thank you again for your plugin and your help.
                                            Michaelv
                                            Great plugin.
                                            Crashes SU8 free on MAC (don't know why yet)
                                            Modifiers don't work on MAC (as expected), working on it.
                                            Check PM
                                            Also the "add face circle" context menu doesn't seem to do anything. Is it active? What is it supposed to do?
                                            I can trigger it picking one edge of an arc or circle, but then nothing happens.
