    [Plugin] Circle from edge (2-pt circle,Updated 15/02/2016)
    29 Posts 10 Posters 65.7k Views 10 Watching
    • kenK Offline
      ken
      This is looking like a keeper of a plugin. However, it does not make a circle or any geometry that Sketchup can input a center mark. Now, I know this does not seem important now, but later after push pulling, adding multiple circles, you will want to add dimensions or find the center and the geometry this plugin make you can not accomplish that task.
      There is another 2 point circle plugin that does make geometry that you can get the dimensions and add a center point. Just pointing this out, as right now it makes more work later down the road than it should.
      However, thanks for the plugin.
      Ken
        boilingsnow
        "Up arrow - adds one hemisphere at the top
        Down arrow - adds one side of the bottom"
        These two options don't work in my sketchup 8...
          sahi
          Updated the script in the first message (krug-10.zip)
            boilingsnow
            That was really quick! Thanks a lot. But sadly... the problem unsolved.
            Am I doing anything wrong? After drawing the circle press the up arrow key.
            By the way,the left and right arrow keys are working.
              sahi
              In previous versions it was impossible to move the mouse, then press worked.
              I fixed it in version krug-11.zip
              Updated the script in the first message (krug-11.zip)
                boilingsnow
                Did you test it in Sketchup 8? I'm sorry I still can't get it working.
                  sahi
                  The archive video
                  video_krug_4.rar
                    boilingsnow
                    @sahi said:
                    The archive video
                    [attachment=0:12b25ek5]<!-- ia0 -->video_krug_4.rar<!-- ia0 -->[/attachment:12b25ek5]
                    Yes I can see it works well in your video. And the anwsers of other Members can also confirm that it works.
                    I know it's a little annoying now but the krug_11 also does't work by creating the hemispheres with up- and down arrow key. I've tested it in my notebook and in PC of the office, neither can work.
                    I also tested your krug_4, I can only draw the first circle, but none of the arrow key can work. (with krug_11 I can create the second and third circles with left and right keys but not the hemispheres.
                    I'm using sketchup 8.0.3117 and win XP with a german keyboard. But I don't think it has anything to do with the keyboard, right? What do you mean with your words 'In previous versions it was impossible to move the mouse'? Should I move the mouse to a certain position before I press the up arrow key?
                    • mitcorbM Offline
                      mitcorb
                      For me, it appears that I must press the arrow keys within say 5 seconds to get the results. I can't go back to a circle and use the arrow keys. Is this correct?
                        sahi
                        No. While you are using a script and did not select another tool or until set again the starting point of the circle - you can use the arrow to the left, right, up, and the bottom
                        Yes.
                        NO
                        I think the problem is the keyboard.
                          boilingsnow
                          I think the problem is the keyboard.[/quote]
                          Yes, you are right.
                          I find out that every plugin that need to use up and down arrow key doesn't work in my notebook. (Such as Artisan uses up and down key to change the displacement vector. and "edge follow me" tool of sdmich uses up+down to change the direction of the curve).
                          BUT finally I figured out that up and down work in all these plugins if I press ctrl+up or ctrl+down, I don't know why.
                          Thank you again for your plugin and your help.
                            Michaelv
                            Great plugin.
                            Crashes SU8 free on MAC (don't know why yet)
                            Modifiers don't work on MAC (as expected), working on it.
                            Check PM
                            Also the "add face circle" context menu doesn't seem to do anything. Is it active? What is it supposed to do?
                            I can trigger it picking one edge of an arc or circle, but then nothing happens.
                              sahi
                              @michaelv said:
                              Check PM
                              Yes
                              I just forgot to remove it.
                              But it works, watch the video archive
                              video_2.zip
                                Michaelv
                                Got it. I didn't try to pick 2 points. In any case I use the "create face" tool from SU or it works by closing the curve or retracing one edge in the core sketchup. It works for all faces regarding of shapes (as long as they are closed and coplanar). I also tried both on your circles and it works fine. So I think it can be discarded.
                                Michael
                                  Will be nice : a circle between 2 point different in the 3D Space! ☀
                                    sahi
                                    Updated the plug-in in the first message
                                    • 2 / 2
