    [Plugin] CleanUp
    974 Posts 217 Posters 834.4k Views 217 Watching
    • kingsiK Offline
      kingsi
      I am very new to Sketchup (1st week) and also one of those annoying people that never says thanks on forums. I plan on being neither from now on. So on that note many thanks for the cleanup script
      kingsi
      Noobtastic
        πŸ‘
          Boumbastique
          Zip file don't want to unpack, it says - "unknown format or an error in archive" tt_cleanup.zip 😒 (other zip files works correct on my pc)
            Try downloading again
              Boumbastique
              I tried many times, it didn't work, unfortunately.
                Boumbastique
                I have found it on other resource. Work's great. thomthom thank you very much, you're cool man πŸ‘
                  And where exactly is this other resource?
                  • john2J Offline
                    john2
                    i cant load cleanup properly. however if i create a separate folder with required ttlib, this plugin works perfectly.
                    http://i.imgur.com/9af9A.jpg
                    my plugins list is here
                    http://www.sendspace.com/file/jwyz90
                    Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                    • sumasterS Offline
                      sumaster
                      CHK it out your Internet Explorer Version
                      I think you have old internet explorer
                      Install New internet explorer this problem is sold
                      Thank you,
                      SUmaster
                        Can you open the Ruby Console and try to use CleanUp? See if you get any error messages.
                        • john2J Offline
                          john2
                          clean with last settings works
                          the first option in which the menu should come "clean..." doesnt work. no error messages. iget the same blank box
                          http://i.imgur.com/hHE4i.jpg
                          all the options accessed via the drop down menu are taking my command. the first one in which the black menu comes isn't working. what is the conflict?
                          http://i.imgur.com/mJjmt.jpg
                          • john2J Offline
                            john2
                            i have version 8. and this cleanup plugin works perfectly when kept in isolation in a separate folder. πŸ˜•
                              What do you mean by this? Can I see a screenshot of the plugins folder?
                              • john2J Offline
                                john2
                                check the html file in the previous post that i made
                                • john2J Offline
                                  john2
                                  in isolation i mean if i create a new plugins folder, and install all the requisite ttlib and support files , the plugin works perfect
                                    The window works as well?
                                    Then it must be something in the way it was unpacked in your original folder.
                                    I see that in the HTML list you have that you had a TT_Lib2 - 2.5.5.zip - what is the version of TT_Lib2 you had installed in your main plugin folder? The latest is 2.6.0 - and CleanUp 3.1.8 requires at least TT_Lib 2.5.8.
                                    From the HTML list you sent there seemed to me some unusual files in your plugins folder. I saw several files with same name, but in .rb and. rbs format. Looked very odd. And there was a set of ui.html, ui.js and ui.css in the root plugins folder, which also looks very unusual. Normal convention is that any additional file is located within a subfolder. So I wonder if you might have a few rouge files in your plugin folder that might need cleaning up.
                                    Btw, are you running Vista or Windows7? There has been some issues where files copied to the plugins folder has ended up in a compatibility folder - casing problems. In which case you should see a "Compatibility Files" button in Explorer when you browse the plugins folder.
                                      I see you also have files such as:
                                      extensions.rb
                                      sketchup.rb
                                      These are files that comes with SketchUp and they should be in the Tools folder. I think there might have been a time where they did come in the Plugins folder, but that's a while back. So if you have copied your plugins folder every time you have upgraded SketchUp you have dragged along these old files. And that means that SU loads the old versions you have in the Plugins folder instead of the more recent ones in the Tools folder.
                                      Your plugins folder definitely needs some cleaning up.
                                      • john2J Offline
                                        john2
                                        well i didnt delete those files..just deleted ttlib and ttlib2 folders, reinstalled from the net and cleanup is working fine now πŸ˜„
                                          TT_Lib - version 1.x - is only related to Selection Toys. TT_Lib2 does not replace it.
                                          But you really should clean up your plugins folder - as them files I mentioned should not be there and can cause issues.
                                          • irwanwrI Offline
                                            irwanwr
                                            hi Thomas,
                                            i'd like to ask about what could probably went wrong when i got this later,
                                            the interface look a bit messy.
                                            and how to prevent it to happen ever again later.
                                            thank you, Thomthom.
                                            • 48
                                            • 49
                                            • 2 / 49
