    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Scale 2D and perpendicular plane
    10 Posts 6 Posters 428 Views 6 Watching
    • N Offline
      nikola87
      Hey, I have two questions I can't seem to google out... first when I use scale tool (and that is a lot) I have problem: when I have a 2D object (lets say circle) and it isn't in red, blue nor green plane scaling can be tricky. Is there a way to scale in certain plane?
      Second is about finding perpendicular plane for a random line, I know how to find it by drawing two planes that have my custom line and then finding normals to it in each surface but it is not fun when you have to do it more than two-three times. help
      I think these problems are really basic so I posted them here, but maybe I was wrong... sorry for that
      • Rich O BrienR Online
        Have you tried Fredo's Fredoscale plugin?
        It can adjust the scaling via numerous methods
          The 'Scale' Tool's handles follow the current axes, so if your 2d shape [circle etc] is not on one of the axial planes then you get a 'box' with many handles, not a simple rectangle ๐Ÿ˜ฎ
          Then it's awkward to do what you want ๐Ÿ˜ž
          Help is at hand... ๐Ÿ˜„
          Use the 'Axes' Tool and reset the axes... picking points so that two of the axes are on the same plane as the shape in question... โ˜€
          Now the 'Scale' Tool forms a rectangle of handles, making adjustments easy. ๐Ÿ˜„
          This works for other axis dependent tools too...
          To reset the axes back to the original set, have axes visible, hover over an axis line and right-click context-menu 'reset axes'. ๐Ÿค“
          • N Offline
            nikola87
            thanks a lot, I thought about making an object component and defining it's own axes and then edit it, but this is much cleaner solution
            now i just have problem with finding an orthogonal plane for random line.
              For a single 'line' you can readily set the origin and Red-axis from the line's two ends, the Green-axis can be any other point in space, as you only want to make a 2d Scaling anyway; reset the axes when you are done !
              If there are two non-colinear lines to Scale you can always get three points from their ends, to define the origin and Red/Green axis plane ?
              I fail to see the issue here ???
                Perhaps WorkPlane, ToolsOnSurface etc ?
                • N Offline
                  nikola87
                  The other "problem" had nothing to do with scaling, I was just wondering is there a plugin or some tool that draws a polygon or circle in perpendicular plane of the selected line on witch the centre of that circle/polygon lies or something like that... but now ๐ŸŽ‰ I can solve that with axis tool as well so it is ok... and thanks again, axis tools is basic it will help me a lot in future - I don't know how I missed it when I started learning sketchup
                  • gillesG Offline
                    gilles
                    Look at this one:
                    http://forums.sketchucation.com/viewtopic.php?t=17396#p139064
                      @gilles said:
                      Look at this one:
                      That's it.
                      Aligning the axes to the line also works of course but that plugin is so useful!
                      • Jean LemireJ Offline
                        Jean Lemire
                        Hi folks.
                        For an idea about how to create a plane that is perpendicular to any line, see this SU file.
                        Plane perpendicular to line.skp
