    Manual for new version
    renderpluginsextensions
    10 Posts 5 Posters 1.1k Views 5 Watching
    • john2J Offline
      john2
      there is a 33 page user manual for new version. It doesn't give tips in detail. πŸ˜› is there any detailed manual for version 1.49 as well??
      Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
        For detailed info on V-Ray, look at this manual: http://www.spot3d.com/vray/help/150SP1/
        Got lots of examples and description.
        V-Ray is V-Ray regardless of the host application, don't be afraid to look at resources on V-Ray set in another 3d app.
        • john2J Offline
          john2
          whoa pretty detailed stuff. you know any link for a pdf? i want to dowload this , or any workaround to download the whole html linkable site in one go hehe!?
            marcel.forum
            Hi, try search for "VRay 1.5 SP5 Offline Help.chm"
            Regards
            Marcel
            • V Offline
              valerostudio
              Here is the 1.48 manual that came out a while back
              VfSU_v1.48_UserGuide.pdf
              • V Offline
                valerostudio
                And here is the original manual for the older version, but a bunch of the material is still relevant.
                V-Ray for SketchUp Manual.pdf
                • john2J Offline
                  john2
                  Regards
                  Marcel
                  is there a better link/book/website for vray for sketchup tutorials.?? [ i tried videos, they aren't good]. I figured out that i wont be needing too much of technicalities, just simple plain settings information. like just changing some settings and rest keeping to default. reading too much will actually be a detailed research information overload bomb blast ! πŸ˜†
                  • V Offline
                    valerostudio
                    V-ray really is not a simple rendering engine. I would say that if you can get through the PDFs I posted and all the YouTube videos that Chaos has posted, you will be in good shape. There is still a lot more to learn after that though. It's really just the tip of the iceberg. CG School has some pay videos which really explain the engine in detail. If you are looking for simple, I would suggest one of the less complicated engines such as Podium or Light Up.
                    • andybotA Offline
                      andybot
                      If you see any video tutorial, I would recommend starting with this one
                      http://www.youtube.com/watch?v=ZnrC9-c3cgI
                      There are lots more from chaosgroup and asgvis, but I think this one helps explain lighting very well.
                      • john2J Offline
                        john2
                        @valerostudio said:
                        V-ray really is not a simple rendering engine. I would say that if you can get through the PDFs I posted and all the YouTube videos that Chaos has posted, you will be in good shape. Up.
                        where are the pdfs that you've posted.?? ..link please. Im mostly interested in lighting, coz that's the chief thing in renders, materials i know and r easy 2 setup πŸ˜‰
